Home » Modeling » TMF (Xtext) » XText 2.17 + eclipse 2019-03 + maven build problem(Maven Build )
XText 2.17 + eclipse 2019-03 + maven build problem [message #1805717] Mon, 22 April 2019 12:19 Go to next message
Hello all
in case I create simple xtext project with maven as based builder and try to build. The following error is observed.
[ERROR] Failed to resolve target definition C:\Users\agorlov\Documents\projects\workspaces\flexprod\atom\dev_6.400.00_FXPST_27656\implementaion\com.psl.atom.target\com.psl.atom.target.target: Failed to load p2 metadata repository from location http://download.eclipse.org/releases/2019-03: Unable to read repository at http://download.eclipse.org/releases/2019-03. Unable to connect to repository https://download.eclipse.org/technology/epp/packages/2019-03/content.xml: Connection timed out: connect -> [Help 1]
In case I changed
<repository location="http://download.eclipse.org/releases/2019-03/" />
to
<repository location="http://download.eclipse.org/releases/2019-03/201903201000" />
The error is disappeared. Is it correct correction?
[Updated on: Mon, 22 April 2019 12:20] by Moderator
Re: XText 2.17 + eclipse 2019-03 + maven build problem [message #1805718 is a reply to message #1805717] Mon, 22 April 2019 13:07 Go to previous messageGo to next message
http://download.eclipse.org/releases/2019-03/ is the correct location.
it may always be that eclipse servers have a bad day.
(you should open a bugzilla if problem persists for a longer day)
is also correct but does not include the stuff from the epp packages update site
Re: XText 2.17 + eclipse 2019-03 + maven build problem [message #1805720 is a reply to message #1805718] Mon, 22 April 2019 13:56 Go to previous messageGo to next message
By the way the story with
<unit id="org.junit" version="4.12.0.v201504281640"/>
<unit id="org.junit.jupiter.api" version="5.4.0.v20190212-2109"/>
<unit id="org.junit.jupiter.engine" version="5.4.0.v20190212-2109"/>
<unit id="org.junit.platform.commons" version="1.4.0.v20190212-2109"/>
<unit id="org.junit.platform.engine" version="1.4.0.v20190212-2109"/>
<unit id="org.junit.platform.launcher" version="1.4.0.v20190212-2109"/>
<unit id="org.junit.platform.runner" version="1.4.0.v20190212-2109"/>
I cannot find it on http://download.eclipse.org/modeling/tmf/xtext/updates/orbit/2019-03
Could you help me?
I try to open the site via "Install new software" feature and enter pattern junit
[ERROR] Failed to resolve target definition C:\Users\agorlov\Documents\projects\workspaces\flexprod\atom\dev_6.400.00_FXPST_27656\implementaion\com.psl.atom.target\com.psl.atom.target.target: Could not find "org.junit.jupiter.api/5.3.1.v201
81005-1442" in the repositories of the current location -> [Help 1]
[Updated on: Mon, 22 April 2019 14:06] by Moderator
Re: XText 2.17 + eclipse 2019-03 + maven build problem [message #1805725 is a reply to message #1805720] Mon, 22 April 2019 14:32 Go to previous messageGo to next message
Please try to hit the reload button
Our open a bug against eclipse download servers
Re: XText 2.17 + eclipse 2019-03 + maven build problem [message #1805726 is a reply to message #1805725] Mon, 22 April 2019 14:34 Go to previous messageGo to next message
also make sure that you use a otbit update site that matches stuff.
you can find many releases here
https://download.eclipse.org/tools/orbit/downloads/
and they all contain different versions for different eclipse versions
https://download.eclipse.org/modeling/tmf/xtext/updates/orbit/2019-03/compositeContent.xml
forwards to
https://download.eclipse.org/tools/orbit/downloads/drops/R20190226160451/repository/
(see https://download.eclipse.org/tools/orbit/downloads/drops/R20190226160451/ for a list of contents)
there is no 5.3.1
[Updated on: Mon, 22 April 2019 14:37] by Moderator
Re: XText 2.17 + eclipse 2019-03 + maven build problem [message #1805742 is a reply to message #1805726] Tue, 23 April 2019 00:21 Go to previous messageGo to next message
Note that you can use the Repository Explorer to find an Eclipse-hosted update site for a specific installable unit version:
https://wiki.eclipse.org/Eclipse_Oomph_Authoring#How_to_find_a_P2_repository_at_Eclipse_using_the_Repository_Explorer
Re: XText 2.17 + eclipse 2019-03 + maven build problem [message #1805743 is a reply to message #1805726] Tue, 23 April 2019 00:38 Go to previous messageGo to next message
Always, I use a simple project after migration to a new version of eclipse and XText for smoke testing. All links to repositories are generated or saved by XText. Maybe my eclipse distribution is not up to date.
In any case, thank you for support
Re: XText 2.17 + eclipse 2019-03 + maven build problem [message #1805745 is a reply to message #1805743] Tue, 23 April 2019 01:50 Go to previous message
maybe simply a server was down
Previous Topic:Terminal rules vs parser rules priority
Next Topic:On adding XtextAntlrGeneratorFragment2 in Workflow .Iam getting exception
Current Time: Sun Jul 20 10:43:48 EDT 2025
Powered by FUDForum. Page generated in 0.04875 seconds
