Home » Eclipse Projects » Eclipse Platform » Extension Point for Java Breakpoints
Extension Point for Java Breakpoints [message #180073] Wed, 14 January 2004 15:18 Go to next message
Originally posted by: rhubarb.mailinator.com
I've written this before way back in the 2.1 days, and am hoping things
have changed since then.
I have a hack that adds sounds to breakpoints - when the breakpoint is hit
you hear a sound - very handy, stole it from other IDEs.
The problem is in turning my hack into a plugin. Its a very simple hack
but it needs to add itself as a breakpoint listener to work.
Is there some extension point I could use for this.
I requested a breakpoint extension point that would load extensions and
add them as bp listeners but the feature request in bugzilla seems to have
been shelved.
Someone suggested I use the startup extension point, but will that work?
Is there anything better?
Re: Extension Point for Java Breakpoints [message #180560 is a reply to message #180073] Thu, 15 January 2004 13:08 Go to previous messageGo to next message
I recall this feature request. The Java debugger does not support a
breakpoint listener extension point - still, just a listener API. Someone
else will need to comment on the "startup extension point" - I'm not
familiar with it.
Perhaps you would consider contributing your "breakpoint sound" feature to
the Java debugger, to be included as part of the SDK?
Darin
"rhubarb" <rhubarb@mailinator.com> wrote in message
news:bu487a$ipm$1@eclipse.org...
> been shelved.
Re: Extension Point for Java Breakpoints [message #180613 is a reply to message #180560] Thu, 15 January 2004 14:07 Go to previous messageGo to next message
I'd be happy to. I'd don't want to make any money of this thing - I just
want to have sounds without having to hack every new release of Eclipse.
(Hence getting a plug-in going).
How do I go about contributing the feature?
> familiar with it.
> Darin
> > been shelved.
Re: Extension Point for Java Breakpoints [message #180739 is a reply to message #180613] Thu, 15 January 2004 18:20 Go to previous messageGo to next message
Originally posted by: jaredburns.acm.org.nospam
File a bug report in bugzilla (bugs.eclipse.org/bugs) requesting the
feature, then attach your contribution to the bug.
Just a reminder: Uploading content to our bugzilla means you're providing it
to us under the CPL.
- Jared
>> to the Java debugger, to be included as part of the SDK?
>> familiar with it.
>> Darin
>> > hit you hear a sound - very handy, stole it from other IDEs.
>> > have been shelved.
>> > work? Is there anything better?
Re: Extension Point for Java Breakpoints [message #180784 is a reply to message #180739] Thu, 15 January 2004 19:14 Go to previous messageGo to next message
Thanks I'll do that.
In that case Id better clean it up a bit.
For one thing I should make it optional I guess.
For another, while I've been a professional java programmer for 7 years,
this is the first time I've had to load a wav file (or done anything with
audio). So I just copied some example from the sun java tutorial that uses
media-tracker. Is there a proper way to do this in eclipse? Is there a
proper location for the wav files - or is the package with the debug stuff
Im adding okay.
-rhubarb
> - Jared
> >> familiar with it.
> >> Darin
> >> > have been shelved.
Re: Extension Point for Java Breakpoints [message #180811 is a reply to message #180784] Thu, 15 January 2004 20:43 Go to previous message
Submitting Sun code to Eclipse might be a problem. Before you submit
anything, please look into licensing/copyright issues to make sure your
code is clean.
- Jared
> Im adding okay.
> -rhubarb
>> it to us under the CPL.
>> - Jared
>> >> feature to the Java debugger, to be included as part of the SDK?
>> > just want to have sounds without having to hack every new release of
>> > Eclipse. (Hence getting a plug-in going).
>> >> Someone else will need to comment on the "startup extension point" -
>> >> I'm not familiar with it.
>> >> Darin
>> >> > things have changed since then.
>> >> > is hit you hear a sound - very handy, stole it from other IDEs.
>> >> > hack but it needs to add itself as a breakpoint listener to work.
>> >> > and add them as bp listeners but the feature request in bugzilla
>> >> > seems to have been shelved.
Previous Topic:What is the id of the tasks view?
Next Topic:Performances on linux
Current Time: Fri Oct 10 05:45:58 EDT 2025
Powered by FUDForum. Page generated in 0.07450 seconds
