Home » Modeling » TMF (Xtext) » Multiple unittest files to be executed by Maven(Execute multiple unittest files when working with Maven)
Multiple unittest files to be executed by Maven [message #1805444] Mon, 15 April 2019 07:34 Go to next message
I have an Xtext project, say org.xtext.example.mydsl. I try to convert it to a headless one. In particular, I would like it to be built and tested based on Maven.
Given I want to maintain the unittests of sub-project org.xtext.example.mydsl.tests in the form of multiple files. For example, given I have the following two files
  1. MyDslParsingTest.xtend (Generated during workflow execution)
  2. MyDslWHATEVERTest.xtend (Manual copy paste of the file above)
When I run
 mvn clean verify
in the directory of the parent project, org.xtext.example.mydsl.parent
Then only the tests of the first file, MyDslParsingTest.xtend, are executed.
What do I have to do in order to let Maven also execute the tests of the manually crafted file, MyDslWHATEVERTest.xtend?
Re: Multiple unittest files to be executed by Maven [message #1805520 is a reply to message #1805444] Tue, 16 April 2019 11:56 Go to previous messageGo to next message
Can you please provide a complete minimal sample
(Also have a look what the wizard creates if you select maven)
[Updated on: Tue, 16 April 2019 11:57] by Moderator
Re: Multiple unittest files to be executed by Maven [message #1805567 is a reply to message #1805520] Wed, 17 April 2019 10:00 Go to previous messageGo to next message
At least, I solved the symptoms of my issue. However, I have to admit that I do not understand the solution. Here is the review:
The symptom was that only those unittests were executed by Maven which were part of the original (auto generated) file, e.g. MyDslParsingTest.xtend.
Unittests of other files, e.g. MyDslWHATEVERTest.xtend, were not considered by Maven at all. Eventually, I compared the two file types and discovered differences in the "setup" (I mean: imports and injections).
Unittests in this file are executed by Maven: MyDslParsingTest.xtend
import com.google.inject.Inject
import org.eclipse.xtext.testing.InjectWith
import org.eclipse.xtext.testing.extensions.InjectionExtension
import org.eclipse.xtext.testing.util.ParseHelper
import org.example.hellomaven.helloMaven.Model
import org.junit.jupiter.api.Assertions
import org.junit.jupiter.api.Test
import org.junit.jupiter.api.^extension.ExtendWith
@ExtendWith(InjectionExtension)
@InjectWith(HelloMavenInjectorProvider)
class HelloMavenParsingTest {
	@Inject ParseHelper<Model> parseHelper
        @Test
Unittests in this file are NOT executed by Maven: MyDslWHATEVERTest.xtend
import org.eclipse.xtext.testing.XtextRunner
import org.eclipse.xtext.xbase.testing.CompilationTestHelper
import org.junit.Test
import org.junit.runner.RunWith
import static org.junit.Assert.*
@RunWith(typeof(XtextRunner))
@InjectWith(typeof(SismicInjectorProvider))
class HelloMavenWHATEVERTest {
	@Inject extension CompilationTestHelper
        @Test
The "setup" of the latter, I finally modified it to the following:
Unittests in this file ARE now executed by Maven: MyDslWHATEVERTest.xtend
@InjectWith(SismicInjectorProvider)
class SismicGenerationTest implements completeScenarioWithFrancaReferences {
  @Test
The thrilling thing for me was that in the Eclipse IDE, I could launch all tests from all files. Everything was working. However, Maven had a different perspective ...
Re: Multiple unittest files to be executed by Maven [message #1805569 is a reply to message #1805567] Wed, 17 April 2019 10:03 Go to previous messageGo to next message
looks like you mix junit4 and junit5.
is there any reason?
if you want junit4 use it everywhere
if you want junit5 use it everywhere
otherwise you should research
how to to both with maven and or tycho
[Updated on: Wed, 17 April 2019 10:04] by Moderator
Re: Multiple unittest files to be executed by Maven [message #1805571 is a reply to message #1805569] Wed, 17 April 2019 10:14 Go to previous messageGo to next message
When I "experimented" with the test files today, from time to time I got error messages from Eclipse which support your statement.
No, there is no specific reason for mixing junit4 and junit5. When I developed the tests, I was so involved in my "domain specific problems" that I did not notice.
Thanks for your time and your hint, Christian.
Re: Multiple unittest files to be executed by Maven [message #1805572 is a reply to message #1805571] Wed, 17 April 2019 10:15 Go to previous message
=> you use junit5 for all.
or recreate and use junit4 everywhere
Previous Topic:Parsing doxygen with xtext
Next Topic:1001 tips and tricks for Xtext
Current Time: Thu Jul 24 21:45:52 EDT 2025
Powered by FUDForum. Page generated in 0.08103 seconds
