Home » Eclipse Projects » Kura » Kura Driver
Kura Driver [message #1805509] Tue, 16 April 2019 09:29 Go to next message
Hi guys, I have develop a driver but when I setted the channel records in READ_WRITE way the List of channel records went in the read method and I want that the driver call the write method.
Can you help me?
Re: Kura Driver [message #1805521 is a reply to message #1805509] Tue, 16 April 2019 12:01 Go to previous messageGo to next message
sorry, could you please detail better your issue?
Thanks.
Matteo
Re: Kura Driver [message #1805546 is a reply to message #1805521] Wed, 17 April 2019 03:26 Go to previous messageGo to next message
I try.
I followed more or less the same procedure as the opc-ua driver.
In the main class I implemented the driver and ConfigurableComponent interfaces.
I created the ChannelDescriptor based on what I need to use.
In the driver class I inserted some logs in the read and write methods.
On kura, I create a channel and set it in read_write mode. I expect the logger to print the write part to me, but instead I print the one related to the read.
public final class Eu63Driver implements Driver, ConfigurableComponent {
    public void read(List<ChannelRecord> records) throws
    ConnectionException {
		logger.info("READ");
    public void write(List<ChannelRecord> records) throws
		logger.info("WRITE");
I entered the parts of the class I told you about.
I think something is missing because opcua instead does it.
  • Attachment: Capture.JPG
    (Size: 18.87KB, Downloaded 108 times)
Re: Kura Driver [message #1805561 is a reply to message #1805546] Wed, 17 April 2019 08:48 Go to previous messageGo to next message
The write operation is performed only if the request that triggers the asset is associated with a metric that has the same name and type of the channel defined in the asset.
Matteo
Re: Kura Driver [message #1805576 is a reply to message #1805561] Wed, 17 April 2019 11:09 Go to previous messageGo to next message
Yes I did, but it only works in the case where I put the channel-1 in WRITE mode, but if I set it in read_write mode it won't work.
Re: Kura Driver [message #1805639 is a reply to message #1805576] Fri, 19 April 2019 06:20 Go to previous message
That is strange.
Could you please compare your code with existing Driver implementations?
Matteo
Previous Topic:Unable to update kura build's minor version
Next Topic:How to downgrade an installed library version in linux
Current Time: Thu Jul 24 04:59:10 EDT 2025
Powered by FUDForum. Page generated in 0.05048 seconds
