Eclipse application won't run with OpenJDK 11 [message #1805247] |
Wed, 10 April 2019 07:42  |
Hi together,
I am stuck with this issue for days now, maybe someone can help me here...
I have an application that I am able to run with Oracle Java 8 jre. Now we got the information, that due to the changes in licensing, we should migrate to OpenJDK and that these two JREs should be interchangeable. I now added the OpenJRE to the installed JREs and in the run configurations selected it as my runtime JRE. When I now run this application I get the error message which can be found in the attached log.. I used to develop in Eclipse 4.9 but also tested it with Eclipse 4.11.0 which results in the same error...
What do I have to change in my configuration, to be able to run the same application with OpenJRE? I don't really know hot to deal with the errors in the log.
Any help would be appreciated...
Best regards
[Updated on: Wed, 10 April 2019 08:42] by Moderator
FUDForum. Page generated in 0.15539 seconds
