Home » Eclipse Projects » NatTable » Filtering combo box filtering
Filtering combo box filtering [message #1737481] Fri, 08 July 2016 11:00 Go to next message
I'm using excel like ComboBoxFilterRowHeaderComposite , When I filter some columns, filters in other columns are not getting modified based on the current selection(It always show the initial filter list). Are there any work around available for this?
Re: Filtering combo box filtering [message #1737536 is a reply to message #1737481] Sat, 09 July 2016 09:50 Go to previous messageGo to next message
IIRC you need to use the FilterList as the base list on creating the filter header. Please check the Javadoc
Re: Filtering combo box filtering [message #1738365 is a reply to message #1737536] Tue, 19 July 2016 05:58 Go to previous messageGo to next message
Hello Dirk,
I'm also using the Filter list as the base list.
new ComboBoxFilterRowHeaderComposite(
bodyLayerStack.getFilterList(),
bodyLayerStack.getGlazedListsEventLayer(),
bodyLayerStack.getSortedList(),
columnPropertyAccessor,
columnHeaderLayer,
columnHeaderDataProvider,
configRegistry);
My Desired Behaviour is
No | baseValue | Sub Value |
1 | A | AA |
2 | A | AB |
3 | B | BA |
4 | B | BB |
1) If I select the combo box value of A in base value, I need to get filter values of AA and AB in subvalue. (Right now its displaying the always AA, AB, BA &BB irrespective of selection.)
2) if I select AA in subvalue, then I need to get A alone in the base value. (Rightnow it displays A& B irrespective of selection).
Kindly let me know, how to get this desired behaviour.
Re: Filtering combo box filtering [message #1738380 is a reply to message #1738365] Tue, 19 July 2016 06:59 Go to previous messageGo to next message
I already gave the answer to solve your issue.
If you would have checked the javadoc, you would have seen this:
     * @param baseCollection
     *            The base collection that is used to fill the body. Needed to
     *            determine the values to show in the filter comboboxes and
     *            initially pre-select them.
baseCollection is the third parameter. You are talking about the first parameter, which is filterList. And that is required to be able to filter.
If you change your code to the following snippet, it should work the way you desire
    columnHeaderLayer,
    configRegistry);
Re: Filtering combo box filtering [message #1738386 is a reply to message #1738380] Tue, 19 July 2016 07:53 Go to previous messageGo to next message
Thank you. I have modified the code as you suggested. Now I'm getting Index out of bounds error at some "StandaloneNatExampleRunner.run(new _6034_ExcelLikeFilterRowExample());".
 * Copyright (c) 2013, 2015 Dirk Fauth and others.
 * All rights reserved. This program and the accompanying materials
 * are made available under the terms of the Eclipse Public License v1.0
 * which accompanies this distribution, and is available at
 * http://www.eclipse.org/legal/epl-v10.html
 * Contributors:
 *    Dirk Fauth  - initial API and implementation
import java.util.Date;
import java.util.HashMap;
import java.util.List;
import java.util.Map;
import org.eclipse.jface.layout.GridDataFactory;
import org.eclipse.nebula.widgets.nattable.NatTable;
import org.eclipse.nebula.widgets.nattable.config.AbstractRegistryConfiguration;
import org.eclipse.nebula.widgets.nattable.config.ConfigRegistry;
import org.eclipse.nebula.widgets.nattable.config.DefaultNatTableStyleConfiguration;
import org.eclipse.nebula.widgets.nattable.config.IConfigRegistry;
import org.eclipse.nebula.widgets.nattable.config.IEditableRule;
import org.eclipse.nebula.widgets.nattable.data.ExtendedReflectiveColumnPropertyAccessor;
import org.eclipse.nebula.widgets.nattable.data.IColumnPropertyAccessor;
import org.eclipse.nebula.widgets.nattable.data.IDataProvider;
import org.eclipse.nebula.widgets.nattable.data.ListDataProvider;
import org.eclipse.nebula.widgets.nattable.dataset.person.Address;
import org.eclipse.nebula.widgets.nattable.dataset.person.Person.Gender;
import org.eclipse.nebula.widgets.nattable.dataset.person.PersonService;
import org.eclipse.nebula.widgets.nattable.dataset.person.PersonWithAddress;
import org.eclipse.nebula.widgets.nattable.edit.EditConfigAttributes;
import org.eclipse.nebula.widgets.nattable.examples.AbstractNatExample;
import org.eclipse.nebula.widgets.nattable.examples.runner.StandaloneNatExampleRunner;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.GlazedListsEventLayer;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.filterrow.ComboBoxFilterRowHeaderComposite;
import org.eclipse.nebula.widgets.nattable.freeze.CompositeFreezeLayer;
import org.eclipse.nebula.widgets.nattable.freeze.FreezeLayer;
import org.eclipse.nebula.widgets.nattable.grid.data.DefaultColumnHeaderDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.data.DefaultCornerDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.data.DefaultRowHeaderDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.layer.ColumnHeaderLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.CornerLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.DefaultColumnHeaderDataLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.DefaultRowHeaderDataLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.GridLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.RowHeaderLayer;
import org.eclipse.nebula.widgets.nattable.layer.AbstractLayerTransform;
import org.eclipse.nebula.widgets.nattable.layer.DataLayer;
import org.eclipse.nebula.widgets.nattable.layer.ILayer;
import org.eclipse.nebula.widgets.nattable.persistence.command.DisplayPersistenceDialogCommandHandler;
import org.eclipse.nebula.widgets.nattable.selection.SelectionLayer;
import org.eclipse.nebula.widgets.nattable.ui.menu.HeaderMenuConfiguration;
import org.eclipse.nebula.widgets.nattable.ui.menu.PopupMenuBuilder;
import org.eclipse.nebula.widgets.nattable.viewport.ViewportLayer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import ca.odell.glazedlists.EventList;
import ca.odell.glazedlists.FilterList;
import ca.odell.glazedlists.GlazedLists;
import ca.odell.glazedlists.SortedList;
import ca.odell.glazedlists.TransformedList;
 * Example showing how to add the filter row to the layer composition of a grid
 * that looks like the Excel filter.
public class _6034_ExcelLikeFilterRowExample extends AbstractNatExample {
    public static void main(String[] args) throws Exception {
    public String getDescription() {
        return "This example shows the usage of the filter row within a grid that looks like the Excel"
                + " filter row.";
    public Control createExampleControl(Composite parent) {
        Composite container = new Composite(parent, SWT.NONE);
        container.setLayout(new GridLayout());
        // create a new ConfigRegistry which will be needed for GlazedLists
        // handling
        ConfigRegistry configRegistry = new ConfigRegistry();
        // property names of the Person class
        String[] propertyNames = { "firstName", "lastName", "gender",
                "married", "birthday", "address.street", "address.housenumber",
                "address.postalCode", "address.city" };
        // mapping from property to label, needed for column header labels
        Map propertyToLabelMap = new HashMap();
        propertyToLabelMap.put("firstName", "Firstname");
        propertyToLabelMap.put("lastName", "Lastname");
        propertyToLabelMap.put("gender", "Gender");
        propertyToLabelMap.put("married", "Married");
        propertyToLabelMap.put("birthday", "Birthday");
        propertyToLabelMap.put("address.street", "Street");
        propertyToLabelMap.put("address.housenumber", "Housenumber");
        propertyToLabelMap.put("address.postalCode", "Postal Code");
        propertyToLabelMap.put("address.city", "City");
        IColumnPropertyAccessor columnPropertyAccessor =
                new ExtendedReflectiveColumnPropertyAccessor(propertyNames);
        final BodyLayerStack bodyLayerStack =
                new BodyLayerStack(
                        PersonService.getPersonsWithAddress(50),
                        columnPropertyAccessor);
        // build the column header layer
        IDataProvider columnHeaderDataProvider =
                new DefaultColumnHeaderDataProvider(propertyNames, propertyToLabelMap);
        DataLayer columnHeaderDataLayer =
                new DefaultColumnHeaderDataLayer(columnHeaderDataProvider);
        ILayer columnHeaderLayer =
                new ColumnHeaderLayer(
                        columnHeaderDataLayer,
                        bodyLayerStack,
                        bodyLayerStack.getSelectionLayer());
        ComboBoxFilterRowHeaderComposite filterRowHeaderLayer =
                        columnHeaderLayer,
                        configRegistry);
        // build the row header layer
        IDataProvider rowHeaderDataProvider =
                new DefaultRowHeaderDataProvider(bodyLayerStack.getBodyDataProvider());
        DataLayer rowHeaderDataLayer =
                new DefaultRowHeaderDataLayer(rowHeaderDataProvider);
        ILayer rowHeaderLayer =
                new RowHeaderLayer(
                        rowHeaderDataLayer,
                        bodyLayerStack,
        // build the corner layer
        IDataProvider cornerDataProvider =
                new DefaultCornerDataProvider(
        DataLayer cornerDataLayer =
                new DataLayer(cornerDataProvider);
        ILayer cornerLayer =
                new CornerLayer(
                        cornerDataLayer,
                        rowHeaderLayer,
                        filterRowHeaderLayer);
        // build the grid layer
        GridLayer gridLayer =
                new GridLayer(
                        bodyLayerStack,
                        filterRowHeaderLayer,
                        rowHeaderLayer,
                        cornerLayer);
        // turn the auto configuration off as we want to add our header menu
        // configuration
        NatTable natTable = new NatTable(container, gridLayer, false);
        // as the autoconfiguration of the NatTable is turned off, we have to
        // add the DefaultNatTableStyleConfiguration and the ConfigRegistry
        // manually
        natTable.setConfigRegistry(configRegistry);
        natTable.addConfiguration(new DefaultNatTableStyleConfiguration());
        natTable.addConfiguration(new HeaderMenuConfiguration(natTable) {
            protected PopupMenuBuilder createCornerMenu(NatTable natTable) {
                return super.createCornerMenu(natTable)
                        .withStateManagerMenuItemProvider();
        natTable.addConfiguration(new AbstractRegistryConfiguration() {
            public void configureRegistry(IConfigRegistry configRegistry) {
                configRegistry.registerConfigAttribute(
                        EditConfigAttributes.CELL_EDITABLE_RULE,
                        IEditableRule.ALWAYS_EDITABLE);
        natTable.configure();
        natTable.registerCommandHandler(
                new DisplayPersistenceDialogCommandHandler(natTable));
        GridDataFactory.fillDefaults().grab(true, true).applyTo(natTable);
        Button button = new Button(container, SWT.PUSH);
        button.setText("Add Row");
        button.addSelectionListener(new SelectionAdapter() {
            public void widgetSelected(SelectionEvent e) {
                Address address = new Address();
                address.setStreet("Some Street");
                address.setHousenumber(42);
                address.setPostalCode(12345);
                address.setCity("In the clouds");
                PersonWithAddress person = new PersonWithAddress(42, "Ralph",
                        "Wiggum", Gender.MALE, false, new Date(), address);
                bodyLayerStack.getSortedList().add(person);
        return container;
     * Always encapsulate the body layer stack in an AbstractLayerTransform to
     * ensure that the index transformations are performed in later commands.
     * @param
    class BodyLayerStack extends AbstractLayerTransform {
        private final SortedList sortedList;
        private final FilterList filterList;
        private final IDataProvider bodyDataProvider;
        private final DataLayer bodyDataLayer;
        private final GlazedListsEventLayer glazedListsEventLayer;
        private final SelectionLayer selectionLayer;
        public BodyLayerStack(List values, IColumnPropertyAccessor columnPropertyAccessor) {
            // wrapping of the list to show into GlazedLists
            // see http://publicobject.com/glazedlists/ for further information
            EventList eventList = GlazedLists.eventList(values);
            TransformedList rowObjectsGlazedList = GlazedLists.threadSafeList(eventList);
            // use the SortedList constructor with 'null' for the Comparator
            // because the Comparator will be set by configuration
            this.sortedList = new SortedList(rowObjectsGlazedList, null);
            // wrap the SortedList with the FilterList
            this.filterList = new FilterList(this.sortedList);
            this.bodyDataProvider =
                    new ListDataProvider(this.filterList, columnPropertyAccessor);
            this.bodyDataLayer = new DataLayer(getBodyDataProvider());
            // layer for event handling of GlazedLists and PropertyChanges
            this.glazedListsEventLayer =
                    new GlazedListsEventLayer(this.bodyDataLayer, this.filterList);
            this.selectionLayer = new SelectionLayer(getGlazedListsEventLayer());
            ViewportLayer viewportLayer = new ViewportLayer(getSelectionLayer());
            FreezeLayer freezeLayer = new FreezeLayer(this.selectionLayer);
            CompositeFreezeLayer compositeFreezeLayer =
                    new CompositeFreezeLayer(freezeLayer, viewportLayer, this.selectionLayer);
            setUnderlyingLayer(compositeFreezeLayer);
        public SelectionLayer getSelectionLayer() {
            return this.selectionLayer;
        public SortedList getSortedList() {
            return this.sortedList;
        public FilterList getFilterList() {
            return this.filterList;
        public IDataProvider getBodyDataProvider() {
            return this.bodyDataProvider;
        public DataLayer getBodyDataLayer() {
            return this.bodyDataLayer;
        public GlazedListsEventLayer getGlazedListsEventLayer() {
            return this.glazedListsEventLayer;
Re: Filtering combo box filtering [message #1738417 is a reply to message #1738386] Tue, 19 July 2016 11:15 Go to previous messageGo to next message
Then it seems to be broken now or I can't remember correctly
Re: Filtering combo box filtering [message #1780184 is a reply to message #1738417] Thu, 18 January 2018 08:12 Go to previous messageGo to next message
For this issue I have created a bug "https://bugs.eclipse.org/bugs/show_bug.cgi?id=522287". Are there any way to handle this issue?
Re: Filtering combo box filtering [message #1780193 is a reply to message #1780184] Thu, 18 January 2018 09:05 Go to previous messageGo to next message
Have you tried with the latest SNAPSHOT version? Not sure if I already worked on that part. About half a year has passed since you last wrote here.
Re: Filtering combo box filtering [message #1780200 is a reply to message #1780193] Thu, 18 January 2018 10:00 Go to previous messageGo to next message
Latest snapshot also having the issue. :(
Re: Filtering combo box filtering [message #1780207 is a reply to message #1780200] Thu, 18 January 2018 10:35 Go to previous messageGo to next message
I suppose it is some sort of concurrency issue. Not sure when I will be able to look for a fix.
Actually IMHO your request is bad in terms of usability. If you reduce the shown items to what is currently visible everytime you uncheck an item, it leads to the situation that a user has to completely clear the filter in that column. He is not able to check single items afterwards again.
Re: Filtering combo box filtering [message #1802886 is a reply to message #1780207] Mon, 18 February 2019 08:57 Go to previous messageGo to next message
Bringing up this topic again, as we also use the combobox filter list. It would be very handy, to have the available filter values on the remaining filters, reduced to the actual visible values. See also example attached:
index.php/fa/34911/0/
index.php/fa/34912/0/
index.php/fa/34913/0/
When the list has more values, the filter is getting very confusing, showing values, which you actiually can´t select, as they re already filtered out.
Re: Filtering combo box filtering [message #1802889 is a reply to message #1802886] Mon, 18 February 2019 09:20 Go to previous messageGo to next message
It's an open source project ... so if you think it would be a cool feature that should be added, feel free to contribute. In the development I phased several issues with that approach, like synchronisation issues as can be seen above.
If there is a high need on this, you are not able to contribute and you are willing to sponsor the development, feel free to contact me.
Re: Filtering combo box filtering [message #1805261 is a reply to message #1802889] Wed, 10 April 2019 09:57 Go to previous messageGo to next message
Hey Dirk,
we did some deeper investigation on the topic and want to present our findings and possible approach.
Problem1: For a big Nattable of size > 1000 rows, when user applies filters, sorting and delete a row the filters are lost.
Solution1: We were able to re-load the Nattable state before deletion, this maintained the filters and column sorting
BUT introduced a new problem.
Problem2_In_Solution1: The problem is that after restoring the Nattable state, the focus is set back to row 1 i.e. if user
Selects row 500 and deletes it, restoring the state will move the focus on row 1. i.e. the Nattable is scrolled back to row 1.
Solution_Of_Problem2: We tried to scroll back to the row number which is selected for deletion and we got success.
But we got success by using deprecated API "ShowRowInViewportCommand"
Below code is to get the row number that is selected for deletion:-
TreeMap<Integer,V4BPCPtiTableRow> selectedRows = tableviewer.getNatTableView().getSelectedRows();
Set<Integer> keys = selectedRows.keySet();
Integer rownumber=selectedRows.firstKey();
Below code is to select a particular row of the nattable (this scrolls the Nattable to 'rownumber'
Properties prop = userState.get(V4BPCMessages.CONFIG_DEFAULT);
natTable.loadState(V4BPCMessages.CONFIG_DEFAULT,prop);
natTable.doCommand(new ShowRowInViewportCommand(tableviewer.getNatTableView().getBodyLayerStack().getViewportLayer(), rownumber));
natTable.doCommand(new SelectRowsCommand(tableviewer.getNatTableView().getGlazedListsGridLayer().getBodyLayer(), 0, rownumber, false, false));
Findings: We observed that the Solution_Of_Problem2 works only when using both "ShowRowInViewportCommand" and "SelectRowsCommand" together.
Using only "SelectRowsCommand" does not work.
Help : Please help us to achieve our goal.
We are using below nattable jars.
org.eclipse.nebula.widgets.nattable.core_1.6.0.201810101910.jar
org.eclipse.nebula.widgets.nattable.extension.glazedlists_1.6.0.201810101910.jar
org.eclipse.nebula.widgets.nattable.extension.poi_1.5.1.201810101910.jar
Re: Filtering combo box filtering [message #1805265 is a reply to message #1805261] Wed, 10 April 2019 10:43 Go to previous messageGo to next message
In addition:
Could you send me a PM on the procedure for sponsoring the development, because there is a need for furter fixes and enhancements.
Re: Filtering combo box filtering [message #1805275 is a reply to message #1805265] Thu, 11 April 2019 01:36 Go to previous messageGo to next message
thanks for the observation results. Some comments:
1. Like I tried to explain before, the issue is a concurrency issue. When sorting a bigger table, even with GlazedLists, the sorting may take some time. But we refresh every 100ms from the GlazedListsEventLayer. So it can happen that because of the refresh at such an interval the list seems to be empty. And an empty list is handled which results in clearing the filter as it looks like the values do not exist in the list anymore.
2. With regards to reloading, well reload is first clearing all states and then applies the stored ones. Could either also be a concurrency issue that the table shows from the top (not sure what you mean with focus, as NatTable has no focus on cells) or the selection is lost because of the StructuralChangeEvent. And filtering and sorting is surely a structural change.
3. The ShowRowInViewportCommand is not deprecated API. Only the constructor you are using is deprecated. And I deprecated the constructor with layer parameter because actually this is pretty nonsense. If you specify a layer and a position, then the position is related to the layer. But with using the ViewportLayer the row position can only be something that is currently visible (remember that the ViewportLayer is used to only handle visible cells). So you are not able to bring a row into the viewport that is currently not visible, because the command is not processed. I introduced a constructor that only takes a row position as parameter. And that position has to be related to the layer that is underlying the ViewportLayer (typically the SelectionLayer). This way the command is processed definitely and you are able to bring a cell in the viewport that is currently not visible.
Another option could be to use the PreserveSelectionModel, although I am not sure if you would phase also the issue that the selection is lost because of concurrency issues. I think the concurrency topic is something that needs to be looked at really closely.
Unfortunately I can't send a PM via forum because that feature is disabled for the Eclipse forum. But you should be able to drop me an email to get in contact. My email address should be visible in many NatTable classes in the copyright header. ;)
[Updated on: Thu, 11 April 2019 01:43] by Moderator
Re: Filtering combo box filtering [message #1805342 is a reply to message #1805275] Fri, 12 April 2019 02:11 Go to previous messageGo to next message
Thanks for your comments.
As suggested by you we performed three use cases with change of constructor "ShowRowInViewportCommand" on the nattable with > 1000 rows.
Use Case 1:
Logical implementation through code:
1. Store the nattable state
2. Get the row number that is selected for deletion
3. Load the Nattable state and
4. Select the same row number of the nattable which was deleted (this should scroll the Nattable to 'rownumber')
Below code is to save table state and get the row number that is selected for deletion:-
NatTable natTable = tableviewer.getTable();
natTable.saveState(V4BPCMessages.CONFIG_DEFAULT, currenProp);
userState.put(V4BPCMessages.CONFIG_DEFAULT, currenProp);
Below code is to load the table state and select a particular row of the nattable (this scrolls the Nattable to 'rownumber')
natTable.doCommand(new ShowRowInViewportCommand(rownumber));
User actions on Nattable:
1. Select row number 600 and delete the row 600.
Result: the nattable table was set from row number 600 at the bottom.
2. Now, select row number 590 and delete the row 590.
Result: The row deletion worked as expected i.e. the table was reset correctly, i.e. visually we saw that only row number 590 got deleted and rest of the table remained as it is.
3. Scroll up or down 20 or 30 rows, perform 1, we get the same result.
Use Case 2:
3. Select the same row number of the nattable which was deleted (this should scroll the Nattable to 'rownumber')
Please note nattable state is NOT loaded
Below code is to select a particular row of the nattable (this scrolls the Nattable to 'rownumber')
// Commented out the below code which loads the state.
/*Properties prop = userState.get(V4BPCMessages.CONFIG_DEFAULT);
natTable.loadState(V4BPCMessages.CONFIG_DEFAULT,prop);*/
User actions on Nattable: This behavior is different from use case 1.
Result: the nattable table was visible from row number 600 +1 from the TOP i.e. from row 601.
3. Scroll up or down 20 or 30 rows, perform 1, we get the same result as that of step 1.
Observation: The filters were not cleared when the table state is stored but table state is not re-loaded through code.
Use Case 3:
1. Get the row number that is selected for deletion
2. Select the same row number of the nattable which was deleted (this should scroll the Nattable to 'rownumber')
Please note nattable state is NOT stored and not loaded.
Test performed on the > 1000 rows of nattable.
Result: the nattable table was visible from row number 600 +1 from the top i.e from row 601.
Observation: The filters were cleared when the table state was NOT Stored and NOT re-loaded.
Important NOTE:
In all of the above testing it was observed that the command "SelectRowsCommand" never selected the Row number which is passed to it, it only scrolls the Nattable to that particular index.
We are expecting that the row will ALSO get selected.
The table, in the first place, was never visible with the correct row number in reference to the visible screen, either it was scrolled to the top or to the bottom, see scenario 1 and 2. Only when the scrolling was not changed, it worked well, see steps 2 in scenario 1 and 2.
Please let us know your comments on this.
Re: Filtering combo box filtering [message #1805348 is a reply to message #1805342] Fri, 12 April 2019 03:39 Go to previous messageGo to next message
It looks like you are using the SelectRowsCommand not correctly. If my understanding is correct the rowNumber is the position based on the SelectionLayer (since you abstracted this via tableviewer.getNatTableView().getSelectedRows() I can't tell for sure). But you are trying to select it with tableviewer.getNatTableView().getGlazedListsGridLayer().getBodyLayer() as layer reference. I don't know your layer composition, but if you have a typical layer composition you either have an AbstractLayer as body layer stack, or the ViewportLayer on top. So the layer does not match the position. Therefore the selection won't work as the command won't be processed to the SelectionLayer.
Keep in mind that the position needs to match the layer, as a position is always related to a layer. And especially with the ViewportLayer this is a very important correlation.
Re: Filtering combo box filtering [message #1805602 is a reply to message #1805348] Thu, 18 April 2019 09:06 Go to previous messageGo to next message
With your hints, the following scenario works:
    1. Do a structural change (delete row)
      [~]Load the Nattable state SelectRowsCommand based on the row number
Observation:
This works well, also the previously deleted line is in the selection after table is reloaded
But: The line is scrolled to the bottom of my visible screen, each time I change the scrolling field.
Any advice to on how to set correct scrolling?
Re: Filtering combo box filtering [message #1805610 is a reply to message #1805602] Thu, 18 April 2019 13:15 Go to previous messageGo to next message
what do do you mean with "correct scrolling"?
Re: Filtering combo box filtering [message #1805758 is a reply to message #1805610] Tue, 23 April 2019 04:49 Go to previous messageGo to next message
After my custom delete and reset tablestate is executed, the scrolling is set in a way, that the last selected line is always at the bottom of my visible table view section, regardless the previous position in relation to my visible section.
Example:
1. Table with 1000 lines scrolled, so lines 300 - 500 are in the view
2. Select line 400
3. Do our custom delete function for line 400, restore table state and do a select of line 400
4. Table scrolled, so lines 200-400 are visible with line 400 selected, as the last visible line in the view
Expectation:
Scrolling section is still set for lines 300-500.
Re: Filtering combo box filtering [message #1805935 is a reply to message #1805758] Mon, 29 April 2019 01:24 Go to previous message
The SelectRowsCommand selects the rows and shows at maximum the last selected cell. If you want to show some rows in the viewport that are not selected, you need to execute the ShowRowInViewportCommand and for that you need to know which row position (based on the SelectionLayer) is shown as last row in the viewport at that time.
IMHO you are trying hardly to work around an issue in NatTable. Not sure if that is the correct way.
Previous Topic:Filter column values using custom FILTER_DISPLAY_CONVERTER
Next Topic:Duplicate elements created on sorting a tree implemented using Nattable
Current Time: Sun Nov 09 12:11:35 EST 2025
Powered by FUDForum. Page generated in 0.07329 seconds
