Home » Modeling » EMF » Save Emf probleme with many reference to save(EMF Ecore save)
Save Emf probleme with many reference to save [message #1804842] Tue, 02 April 2019 04:04 Go to next message
I use a Ecore model for generate domain code for my application.
In this model i have many Reference to a Object locate in a other file whom i don't know the path before i start the application.
This is a exemple of the persisting file,
index.php/fa/35186/0/
I use save provide by emf on ecore
		Resource resource = resourceSet.getResource(uri, true);
		resource.getContents().clear();
		resource.getContents().add(this.model);
		final Map<Object, Object> saveOptions = new HashMap<Object, Object>();
		try {
			String timeColonPattern = "HH:mm:ss SSS";
			DateTimeFormatter timeColonFormatter = DateTimeFormatter.ofPattern(timeColonPattern);
			LocalTime localTime = LocalTime.now();
			System.out.println("begin save :" + localTime.format(timeColonFormatter));
			resource.save(saveOptions);
			System.out.println("end save :" + localTime.format(timeColonFormatter));
		} catch (IOException e) {
			e.printStackTrace();
When i have a little model , there no problem the saving is quick and work, but when i have to save a bigger model, as the example the file write 50 000 lines and it's take 10/15 min .
So i remove all the reference, i replace by a string and it's take less than 1 sec to save.
The problem is that i need this reference to the object, but i don't want to wait 15min all the time i want to save, same for the load.
How can i do that ? if is possible to not change the Ecore model ?
  • Attachment: exemple.png
    (Size: 13.00KB, Downloaded 258 times)
Re: Save Emf probleme with many reference to save [message #1805013 is a reply to message #1804842] Thu, 04 April 2019 11:10 Go to previous messageGo to next message
You should measure it with a profiler such as YourKit. A poor-man's approach is to periodically stop the thread and see what it's doing at that point and hope you find the slow thing because it's so long/often on the stack. You're hrefs suggest that each referenced object is in the root of a separate resource so are there really such a huge number of resources involved?
Re: Save Emf probleme with many reference to save [message #1805021 is a reply to message #1805013] Thu, 04 April 2019 11:51 Go to previous messageGo to next message
Your model looks to be very flat so you may be experiencing the quadratic URI allocation reported in https://bugs.eclipse.org/bugs/show_bug.cgi?id=544951
You can workaround the problem by allocating the URIs yourself in linear time in a Save helper. org.eclipse.ocl.pivot.internal.resource.PivotSaveImpl uses an AS2ID class to assign xmi:id values in a deterministic semantically sensitive fashion. It may give you some ideas for a simple allocation. (You only need a complicated allocator if you want auto-generated xmi:id values to be substantially unchanged after a model change.)
Ed Willink
Re: Save Emf probleme with many reference to save [message #1805027 is a reply to message #1805021] Thu, 04 April 2019 12:18 Go to previous messageGo to next message
How can his save operation in any way relate to a bug about an unload operation? I don't see any use of IDs, xmi or otherwise in his example. This just seems like unhelpful noise from your soap box...
Re: Save Emf probleme with many reference to save [message #1805040 is a reply to message #1805027] Thu, 04 April 2019 13:55 Go to previous message
Both save and unload allocate all the URIs.
Ed Willink
Previous Topic:Loading different models concurrently synchronisation.
Next Topic:Is there a "CanAdd" API?
Current Time: Thu Jul 24 20:42:16 EDT 2025
Powered by FUDForum. Page generated in 0.25113 seconds
