HelloWorld Scout 9 not working [message #1804924] |
Wed, 03 April 2019 07:37  |
Hey Guys,
so i wanted to migrate my Scout 8 Project to Scout 9.
I did the things described in the Migration guide and then i got some Errors.
So i thought fine, maybe i skipped something important and started a fresh helloworld project of scout 9 and i got the same Error.
If it is important i use Eclipse Scout Version 2019-03(4.11.0).
The Properties of the pom.xml (helloworld) :
<parent>
<groupId>org.eclipse.scout</groupId>
<artifactId>maven_rt_plugin_config-master</artifactId>
<version>3.1.0</version>
<relativePath></relativePath>
</parent>
<groupId>org.eclipse.scout.apps</groupId>
<artifactId>helloworld</artifactId>
<version>1.0.0-SNAPSHOT</version>
<packaging>pom</packaging>
<name>My Application Parent Module</name>
<properties>
<org.eclipse.scout.apps.helloworld.version>${project.version}</org.eclipse.scout.apps.helloworld.version>
<jdk.source.version>1.8</jdk.source.version>
<org.eclipse.scout.rt.version>9.0.0.009_Simrel_2019_03</org.eclipse.scout.rt.version>
</properties>
And here is the Error:
2019-04-03 13:19:52,692 ERROR [scout-platform-starter] org.eclipse.scout.rt.platform.internal.PlatformImplementor.start(PlatformImplementor.java:144) - Error during platform startup - MDC[]
java.lang.NoClassDefFoundError: org/jboss/jandex/IndexView
at org.eclipse.scout.rt.platform.inventory.ClassInventory.<clinit>(ClassInventory.java:36)
at org.eclipse.scout.rt.platform.internal.PlatformImplementor.createBeanManager(PlatformImplementor.java:215)
at org.eclipse.scout.rt.platform.internal.PlatformImplementor.start(PlatformImplementor.java:133)
at org.eclipse.scout.rt.platform.internal.PlatformStarter.run(PlatformStarter.java:30)
Caused by: java.lang.ClassNotFoundException: org.jboss.jandex.IndexView
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
... 4 common frames omitted
Exception in thread "scout-platform-starter" java.lang.NoClassDefFoundError: org/jboss/jandex/IndexView
... 4 more
2019-04-03 13:19:52,695 WARN [main] org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:554) - Failed startup of context o.e.s.d.j.P_WebAppContext@15bfd87{My Application Server,/,file:///C:/Dev/Projects/ScoutTest/helloworld/helloworld.server.app.dev/src/main/webapp/,UNAVAILABLE} - MDC[]
org.eclipse.scout.rt.platform.exception.PlatformException: The platform is in an invalid state.
at org.eclipse.scout.rt.platform.internal.PlatformImplementor.throwOnPlatformInvalid(PlatformImplementor.java:94)
at org.eclipse.scout.rt.platform.internal.PlatformImplementor.awaitPlatformStarted(PlatformImplementor.java:84)
at org.eclipse.scout.rt.server.commons.WebappEventListener.contextInitialized(WebappEventListener.java:47)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:957)
at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:552)
at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:922)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:364)
at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1497)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1459)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:852)
at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:278)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:545)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:138)
at org.eclipse.jetty.server.Server.start(Server.java:415)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:108)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:113)
at org.eclipse.jetty.server.Server.doStart(Server.java:382)
at org.eclipse.scout.dev.jetty.JettyServer.start(JettyServer.java:95)
at org.eclipse.scout.dev.jetty.JettyServer.main(JettyServer.java:56)
2019-04-03 13:19:52,714 INFO [main] org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:292) - Started ServerConnector@c540f5a{HTTP/1.1,[http/1.1]}{0.0.0.0:8080} - MDC[]
Exception in thread "main" org.eclipse.scout.rt.platform.exception.PlatformException: The platform is in an invalid state.
Thank you for your advice in advance.
Re: HelloWorld Scout 9 not working [message #1804978 is a reply to message #1804976] |
Thu, 04 April 2019 03:47  |
Hi Matthias
Well, that did the trick.
I forgot to screenshot it, but there were 2 versions located in that folder. I deleted the jandex folder and updated the Maven as you suggested.
Now the HelloWorld runs without any problems.
Thx for the help, now im confident to update the real application and enjoy the new Scout version!
Have a great one all of you!
FUDForum. Page generated in 0.06100 seconds
