Home » Eclipse Projects » Eclipse Titan » Patch submission procedure for repositories on git.eclipse.org
Patch submission procedure for repositories on git.eclipse.org [message #1783804] Sun, 18 March 2018 06:46 Go to next message
Hi!
I'm wondering what is the procedure to submit patches against the git.eclipse.org repositories. For the github repositories it's clear and I've successfully sent some pull requests.
But what about those on git.eclipse.org? Should I use git send-email? To where? Or are you using a gerrit instance somewhere?
Currently I have two actual bug fixes for titan.ProtocolEmulations.SCCP, see
https://github.com/osmocom/titan.ProtocolEmulations.SCCP/commit/5f926d43f224f15f9b3ca77a1ea379906cef9354
and https://github.com/osmocom/titan.ProtocolEmulations.SCCP/commit/6189ffb5325f79ebd0830e53211255816234ce54
If there's some public information about this (I suppose it should be the 1+1 of every FOSS project), my apologies, and thanks for pointing me in the right direction.
Harald
Re: Patch submission procedure for repositories on git.eclipse.org [message #1783805 is a reply to message #1783804] Sun, 18 March 2018 07:20 Go to previous messageGo to next message
Ok, even in absence of any documentation that I could find I found gerrit.eclipse.org, signed the ECA, added signed-off-by and pushed the changes. see https://git.eclipse.org/r/119627 https://git.eclipse.org/r/119628
I think it's still a good suggestion to have a page somewhere summarizing the steps on how to contribute to TITAN, indicating the differences on github and eclipse hosted repositories.
And btw, I'm curious to hear why that dualism exists in the first place. Thanks!
Re: Patch submission procedure for repositories on git.eclipse.org [message #1783810 is a reply to message #1783805] Sun, 18 March 2018 08:05 Go to previous messageGo to next message
Hi Harald,
please see:
https://docs.google.com/presentation/d/15zA7HjTlvEOshSb5W9qFQ7e4zIAU6Blk3_EV8ewYy_Y/edit#slide=id.p
as linked from https://github.com/eclipse/titan.core
The reason for splitting the project between github and Eclipse git is apparently that creating/maintaining etc. repos on github was too much work for
the admins so we've been given space on Eclipse git.
In honesty, as Titan has now over one hundred repos in total, I sort of understand this approach...
BR
Elemer
Re: Patch submission procedure for repositories on git.eclipse.org [message #1804945 is a reply to message #1783810] Wed, 03 April 2019 10:30 Go to previous messageGo to next message
From what I can tell the instructions are missing the step where you 'scp' the commit-msg hook from the gerrit server to your local repo, i.e. in general terms
scp -P $PORT $USER@$HOST:hooks/commit-msg .git/hooks
Without that, the "Change-Id" line is not added to the commit, and without that gerrit will refuse to accept the push.
Re: Patch submission procedure for repositories on git.eclipse.org [message #1804946 is a reply to message #1804945] Wed, 03 April 2019 10:43 Go to previous messageGo to next message
Another difference compared to other projects (I know) is that the submitter manually has to add reviewers to the patch. That's rather cumbersome. The submitter typically knows none of the people nor their responsibilities. This is much better solved by having gerrit add "default reviewers" for the titan.* projects.
This is possible using the "reviewers" plugin of gerrit, see https://gerrit.googlesource.com/plugins/reviewers/
If that plugin is not available on the eclipse.org gerrit instance, it may be possible to request its installation. It allows to define a set of reviewers for each "project", which then get added automatically for each new changeset on that project. This way the burden of adding them manually as per the google document is removed from the contributor.
Re: Patch submission procedure for repositories on git.eclipse.org [message #1805063 is a reply to message #1804946] Fri, 05 April 2019 02:52 Go to previous message
Hi Harald,
we have added the scp command to the workflow, thanks for the hint.
I will look into adding default reviewers, this may take some time though as I will need to go through maybe 50 repositories .
Best regards
Elemer
Previous Topic:how to get previous version titan core and eclipse plugin
Next Topic:Message segmentation in the IPL4 test port used in TCP mode
Current Time: Fri Jul 25 02:05:15 EDT 2025
Powered by FUDForum. Page generated in 0.05702 seconds
