Home » Modeling » OCL » NPE due to null source
NPE due to null source [message #1804731] Sat, 30 March 2019 13:51 Go to next message
I have an OCL that is failing with an NPE in EcoreEvaluationEnvironment#callOperation since the source argument is null. AFAIK null is only valid for static methods for method.invoke.
When tracing through the code, the issue is that a reference is not found in EvaluationVisitorImpl#visitOperationCallExp as shown in the attached image.
Question: Why isn't the sourceVal being tested for isUndefined when the body is null?
Alain
Re: NPE due to null source [message #1804733 is a reply to message #1804731] Sat, 30 March 2019 14:06 Go to previous messageGo to next message
You don't provide nearly enough of a repro to go on. No stack trace. Not even an OCL version, which means I don't know whether it's fixed. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=483246#c3 The code seems familiar, so I think I did fix something , possibly a better diagnostic, but IIRC you only actually get down the problem path if you use an unregistered method.
Ed Willink
Re: NPE due to null source [message #1804734 is a reply to message #1804733] Sat, 30 March 2019 14:51 Go to previous messageGo to next message
Ed,
Thanks for the quick reply.
First I checked the current code and nothing in any of the relevant part of the stack trace has changed, so I can pretty surely say that it is not fixed/changed, other than as you said reporting the method that failed to be invoked in the error message.
Right now I am using a pretty old version, 3.5.0_v20150521-1211
My OCL is: self.measuredCharacteristics->select(mc | mc.characteristicDefinition.getSingleMeasure().name = 'Business Capability Criticality').measurements->size()
and the failure point is that: mc.characteristicDefinition return null resulting in a call to getSingleMeasure() eOperation via method.invoke to fail.
I am not sure about the meaning of your statement "IIRC you only actually get down the problem path if you use an unregistered method".
Here is the relevant part of the stacktrace:
!ENTRY org.eclipse.ocl 4 10 2019-03-30 14:45:10.926
!MESSAGE ERROR in (calloperation): (null)
!STACK 0
	at org.eclipse.ocl.AbstractEvaluationEnvironment.callOperation(AbstractEvaluationEnvironment.java:198)
	at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.callOperation(EcoreEvaluationEnvironment.java:159)
	at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.callOperation(EcoreEvaluationEnvironment.java:1)
	at org.eclipse.ocl.EvaluationVisitorImpl.visitOperationCallExp(EvaluationVisitorImpl.java:271)
	at org.eclipse.ocl.ecore.impl.OperationCallExpImpl.accept(OperationCallExpImpl.java:384)
	at org.eclipse.ocl.EvaluationVisitorImpl.visitPropertyCallExp(EvaluationVisitorImpl.java:2298)
	at org.eclipse.ocl.ecore.impl.PropertyCallExpImpl.accept(PropertyCallExpImpl.java:232)
	at org.eclipse.ocl.AbstractEvaluationVisitor.safeVisitExpression(AbstractEvaluationVisitor.java:569)
	at org.eclipse.ocl.EvaluationVisitorImpl.visitOperationCallExp(EvaluationVisitorImpl.java:232)
	at org.eclipse.ocl.AbstractEvaluationVisitor.visitExpression(AbstractEvaluationVisitor.java:242)
	at org.eclipse.ocl.internal.evaluation.IterationTemplate.evaluate(IterationTemplate.java:81)
	at org.eclipse.ocl.EvaluationVisitorImpl.evaluateSelectIterator(EvaluationVisitorImpl.java:2013)
	at org.eclipse.ocl.EvaluationVisitorImpl.visitIteratorExp(EvaluationVisitorImpl.java:1814)
	at org.eclipse.ocl.ecore.impl.IteratorExpImpl.accept(IteratorExpImpl.java:108)
	at org.eclipse.ocl.EvaluationVisitorImpl.visitIteratorExp(EvaluationVisitorImpl.java:1798)
	at org.eclipse.ocl.internal.evaluation.QueryImpl.evaluate(QueryImpl.java:123)
	at org.eclipse.ocl.ecore.QueryImpl.evaluate(QueryImpl.java:64)
	at com.castortech.iris.models.query.ocl.BaseOclQueryHandler.run(BaseOclQueryHandler.java:89)
Re: NPE due to null source [message #1804741 is a reply to message #1804734] Sat, 30 March 2019 17:17 Go to previous messageGo to next message
Well that seems precisely in line with the Bug 483246 fix. Navigating from null is invalid. If you use the latest code you will get a clean invalid rather than a dirty NPE and consequential invalid.
If you use a more recent OCL editor you can enable null safe validation so that such hazards are avoided.
Ed Willink
Re: NPE due to null source [message #1804756 is a reply to message #1804741] Sun, 31 March 2019 11:10 Go to previous messageGo to next message
Ed,
Thanks so much. I updated to the latest release and got the changes.
I would just recommend changing the message binding since when logged it still shows up as an error due to binding with OCLMessages.ErrorMessage_ERROR_, instead of a version that would provide a WARNING log entry message.
Alain
Re: NPE due to null source [message #1804758 is a reply to message #1804756] Sun, 31 March 2019 13:16 Go to previous messageGo to next message
Your use case seems slightly different to the bug. It would be really helpful to have the repro / screen shots so that I can understnad haow poor the ergonomics is.
Ed Willink
Re: NPE due to null source [message #1804760 is a reply to message #1804758] Sun, 31 March 2019 13:27 Go to previous messageGo to next message
Ed,
Here are 2 screenshots, First is the query from our UI and 2nd is the result with the breakpoint. I highlighted the problematic part.
In this case, as mentioned yesterday, "mc.characteristicDefinition" can return null in some cases, which leads to the exception.
Alain
Re: NPE due to null source [message #1804772 is a reply to message #1804760] Mon, 01 April 2019 01:48 Go to previous message
You really don't give me anything to go on.
I don't know what tool you are using. I don't know how you execute the OCL. I don't know how the error arises, except it appears to be a custom caller which strongly suggests that the custom caller is badly coded.
All I see is bad OCL gives bad result. Correct. Poor custom error handling gives user dissatisfaction. Pity, but that's not an OCL problem.
Ed Willink
Previous Topic:Announce OCL 6.7.0
Next Topic:Tuple type availability in Acceleo OCL
Current Time: Sat Jul 26 13:25:03 EDT 2025
Powered by FUDForum. Page generated in 0.37713 seconds
