Home » Modeling » TMF (Xtext) » Issues updating Eclipse | 2018-12 → 2019-03 (Issue updating eclipse)
Issues updating Eclipse | 2018-12 → 2019-03 [message #1804619] Fri, 29 March 2019 11:25 Go to next message
I've posted this already here: https://www.eclipse.org/forums/index.php/m/1804618/#msg_1804618
and someone mentioned I should reach out to this forum.
Updating eclipse causes all sorts of issues for my workspace. Is there a fix for these things related to what is in my log file?
Thank you.
  • Attachment: 201903.log
    (Size: 698.29KB, Downloaded 98 times)
Re: Issues updating Eclipse | 2018-12 → 2019-03 [message #1804621 is a reply to message #1804619] Fri, 29 March 2019 11:28 Go to previous messageGo to next message
the asm version you need
and the one provided by eclipse might not match
=> you need to find out which asm stoneage old xtext wants and pick it from some orbit where it is available
https://download.eclipse.org/tools/orbit/downloads/
[Updated on: Fri, 29 March 2019 11:30] by Moderator
Re: Issues updating Eclipse | 2018-12 → 2019-03 [message #1804626 is a reply to message #1804621] Fri, 29 March 2019 12:54 Go to previous messageGo to next message
No, as discussed on https://www.eclipse.org/forums/index.php/m/1804624/#msg_1804624 the problem is much more likely that JDT needs a new ASM for Java 9, but the upgrade has left an old one in place. Xtext, like many projects, seems to make use of ASM in a simple way and so the newer ASM 5 or greater versions for the latest Java support seem immaterial to Xtext. I'm using Xtext with ASM 7 quite happily.
Ed Willink
Re: Issues updating Eclipse | 2018-12 → 2019-03 [message #1804629 is a reply to message #1804626] Fri, 29 March 2019 13:08 Go to previous messageGo to next message
current Xtext uses asm 7 as we support java 11 too.
but stoneage old xtext 2.12 wants asm 5.0.1 upto exclusive 6
asm is not a singleton afaik
https://github.com/eclipse/xtext-extras/blob/v2.12.0/org.eclipse.xtext.common.types/META-INF/MANIFEST.MF
[Updated on: Fri, 29 March 2019 13:10] by Moderator
Re: Issues updating Eclipse | 2018-12 → 2019-03 [message #1804649 is a reply to message #1804629] Fri, 29 March 2019 14:04 Go to previous messageGo to next message
Even having used Eclipse for so long, I have never heard of ASM or know why I should be even interested in how it works.
Re: Issues updating Eclipse | 2018-12 → 2019-03 [message #1804716 is a reply to message #1804649] Sat, 30 March 2019 01:39 Go to previous message
The delights of big Open Source. Re-use occurs where possible. There are many low level re-uses that you don't need to care about. Just look at the Eclipse plugins. I'm always intrigued by org.hamcrest; no idea what it does.
ASM provides facilities for accessing Java byte code, so since you probably don't do that, you don't use it. But JDT and other tools do, in many cases just to get access to facilities such as annotations with a poor/no standard Java API.
Ed Willink
Previous Topic:Update label of search page
Next Topic:Release of Xtext and Xtend 2.17.1
Current Time: Mon Jul 21 07:49:26 EDT 2025
Powered by FUDForum. Page generated in 0.05844 seconds
