Home » Modeling » TMF (Xtext) » Update label of search page
Update label of search page [message #1804611] Fri, 29 March 2019 09:26 Go to next message
Hi, Is there a way to update the label of search page with number of matches after find references operation
Re: Update label of search page [message #1804613 is a reply to message #1804611] Fri, 29 March 2019 09:48 Go to previous messageGo to next message
If you mean the "Xtext References to" label, customize org.eclipse.xtext.ui.editor.findrefs.ReferenceQueryExecutor and bind it into the UI module.
Re: Update label of search page [message #1804615 is a reply to message #1804613] Fri, 29 March 2019 10:52 Go to previous messageGo to next message
It helps to change the message itself, but label does not change after query execution
I want to show number of matches so I need to update Label of search page after finishing query execution
Re: Update label of search page [message #1804617 is a reply to message #1804615] Fri, 29 March 2019 11:10 Go to previous messageGo to next message
hi,
am not sure if i can follow you,
labels are given by ReferenceSearchResultLabelProvider
which delegates to
GlobalDescriptionLabelProvider
[Updated on: Fri, 29 March 2019 11:20] by Moderator
Re: Update label of search page [message #1804625 is a reply to message #1804617] Fri, 29 March 2019 12:53 Go to previous messageGo to next message
I need to find a way to add number of matches beside existing label e.g(1 match in workspace)
as Karsten Thoms said , customizing org.eclipse.xtext.ui.editor.findrefs.ReferenceQueryExecutor would help to change the label
what I'm asking about, how to change this label with correct number of matches
  • Attachment: xtextRef.PNG
    (Size: 1.34KB, Downloaded 123 times)
Re: Update label of search page [message #1804630 is a reply to message #1804625] Fri, 29 March 2019 13:11 Go to previous messageGo to next message
did you debug at exactly that place i gave you
Re: Update label of search page [message #1804635 is a reply to message #1804630] Fri, 29 March 2019 13:28 Go to previous messageGo to next message
Yes, ReferenceSearchResultLabelProvider provide a label for each element of search result, I need to update the label of ReferenceSearchViewPage itself
After debugging , I found that I have to call org.eclipse.search.ui.ISearchResultViewPart.updateLabel(). but I don't know where to call it !
Re: Update label of search page [message #1804642 is a reply to message #1804635] Fri, 29 March 2019 13:45 Go to previous messageGo to next message
i am not sure if you should call that. you should customize/subclass the provider shouldnt you?
Re: Update label of search page [message #1804647 is a reply to message #1804642] Fri, 29 March 2019 13:56 Go to previous messageGo to next message
see (patched in xtext codebase
public class ReferenceSearchResultLabelProvider extends org.eclipse.jface.viewers.LabelProvider {
	@Inject
	private GlobalDescriptionLabelProvider globalDescriptionProvider;
	public String getText(Object element) {
		if (element instanceof ReferenceSearchViewTreeNode) {
			return "patched" + globalDescriptionProvider.getText(((ReferenceSearchViewTreeNode) element).getLabelDescription());
index.php/fa/35158/0/
Re: Update label of search page [message #1804650 is a reply to message #1804611] Fri, 29 March 2019 14:04 Go to previous messageGo to next message
I think we are taking about different labels :)
I need to add total number of matches beside basic label to be as attached:
Xtext Refrences to A (resource ) - (<number of matches> matches )
  • Attachment: Label.png
    (Size: 22.55KB, Downloaded 106 times)
Re: Update label of search page [message #1804654 is a reply to message #1804650] Fri, 29 March 2019 14:13 Go to previous messageGo to next message
that is org.eclipse.xtext.ui.editor.findrefs.ReferenceQueryExecutor.getLabel(EObject)
Re: Update label of search page [message #1804656 is a reply to message #1804654] Fri, 29 March 2019 14:21 Go to previous messageGo to next message
+ a patch for org.eclipse.xtext.ui.editor.findrefs.ReferenceSearchViewPage.createQueryListener().new IQueryListener() {...}.() that calls part.updateLabel on finish
or in showBusyLabel when false
Re: Update label of search page [message #1804657 is a reply to message #1804654] Fri, 29 March 2019 14:22 Go to previous messageGo to next message
Great, how "org.eclipse.xtext.ui.editor.findrefs.ReferenceQueryExecutor.getLabel(EObject)"
be called after finding all references ?
Re: Update label of search page [message #1804658 is a reply to message #1804656] Fri, 29 March 2019 14:22 Go to previous messageGo to next message
(that might be even something to be fixed in xtext itself.
Re: Update label of search page [message #1804662 is a reply to message #1804658] Fri, 29 March 2019 14:41 Go to previous messageGo to next message
Is there a workaround ?
Re: Update label of search page [message #1804663 is a reply to message #1804662] Fri, 29 March 2019 14:43 Go to previous messageGo to next message
i assume everything can be overriden.
here is how it looks like now
protected IQueryListener createQueryListener() {
		return new IQueryListener() {
			public void queryStarting(ISearchQuery query) {
				showBusyLabel(true);
			public void queryRemoved(ISearchQuery query) {
				showBusyLabel(false);
			public void queryFinished(ISearchQuery query) {
				Display.getDefault().asyncExec(new Runnable() {
					public void run() {
						ReferenceSearchViewPage.this.part.updateLabel();
			public void queryAdded(ISearchQuery query) {
(am not sure which stuff is visible from a subclass, in doubt reflection)
we would also need a github issue at eclipse/xtext-eclipse for that
[Updated on: Fri, 29 March 2019 14:49] by Moderator
Re: Update label of search page [message #1804681 is a reply to message #1804663] Fri, 29 March 2019 15:20 Go to previous message
Thank you for all your assistance
Previous Topic:Xtend code generation: include library
Next Topic: Issues updating Eclipse | 2018-12 → 2019-03
Current Time: Sun Jul 20 22:28:25 EDT 2025
Powered by FUDForum. Page generated in 0.08623 seconds
