Home » Newcomers » Newcomers » Continual problem updating or installing new features(Updating or installing new tools/features often blocked with error "No repository found...")
Continual problem updating or installing new features [message #1804295] |
Thu, 21 March 2019 21:45  |
Running Eclipse version 2019-12R CDT variant on iMac with macOS Sierra 10.12.6 has a problem installing or updating tools, features or plugging with a resultant error of "No Repository found..."
For example on installing latest update request of Git 5.4 and Java Git support 5.4, I get the following error report.
An error occurred while collecting items to be installed
session context was:(profile=_Users_maddog_Eclipse_Eclipse 2018-12R_cpp-2018-12_Eclipse.app_Contents_Eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.bouncycastle.bcpkix,1.60.0.v20181210-2057
No repository found containing: osgi.bundle,org.bouncycastle.bcprov,1.60.0.v20181210-2057
No repository found containing: osgi.bundle,org.eclipse.egit,5.4.0.201903212153
No repository found containing: osgi.bundle,org.eclipse.egit.core,5.4.0.201903212153
No repository found containing: osgi.bundle,org.eclipse.egit.doc,5.4.0.201903212153
No repository found containing: osgi.bundle,org.eclipse.egit.gitflow,5.4.0.201903212153
No repository found containing: osgi.bundle,org.eclipse.egit.gitflow.ui,5.4.0.201903212153
No repository found containing: osgi.bundle,org.eclipse.egit.mylyn.ui,5.4.0.201903212153
No repository found containing: osgi.bundle,org.eclipse.egit.ui,5.4.0.201903212153
No repository found containing: osgi.bundle,org.eclipse.jgit,5.4.0.201903210039
No repository found containing: osgi.bundle,org.eclipse.jgit.archive,5.4.0.201903210039
No repository found containing: osgi.bundle,org.eclipse.jgit.http.apache,5.4.0.201903210039
No repository found containing: osgi.bundle,org.eclipse.jgit.lfs,5.4.0.201903210039
No repository found containing: osgi.bundle,org.eclipse.jgit.lfs.server,5.4.0.201903210039
No repository found containing: osgi.bundle,org.eclipse.jgit.ssh.apache,5.4.0.201903210039
No repository found containing: osgi.bundle,org.apache.httpcomponents.httpclient,4.5.6.v20190213-1430
No repository found containing: osgi.bundle,org.apache.httpcomponents.httpcore,4.4.10.v20190123-2214
No repository found containing: osgi.bundle,org.bouncycastle.bcpg,1.60.0.v20181210-2057
No repository found containing: org.eclipse.update.feature,org.eclipse.egit,5.4.0.201903212153
No repository found containing: org.eclipse.update.feature,org.eclipse.egit.gitflow.feature,5.4.0.201903212153
No repository found containing: org.eclipse.update.feature,org.eclipse.egit.mylyn,5.4.0.201903212153
No repository found containing: org.eclipse.update.feature,org.eclipse.jgit,5.4.0.201903210113
No repository found containing: org.eclipse.update.feature,org.eclipse.jgit.http.apache,5.4.0.201903210113
No repository found containing: org.eclipse.update.feature,org.eclipse.jgit.lfs,5.4.0.201903210113
No repository found containing: org.eclipse.update.feature,org.eclipse.jgit.ssh.apache,5.4.0.201903210113
On previous attempts, I have had succes by down loading the project from Eclipse Project website for a project like WindowBuilder Pro 1.9.2. Doing this did allow the update. When I tracked the flow of the install by pulling from the download site, I found it timed out and couldn't complete the install. My internet connect is 25 Mbps download. I am wondering if this could be because of blockage from my antiviral security software.
What I was wondering are the logs I can go read on install history. Maybe I can trace through there. Alternately, is there some quasi-rule that Eclipse can only grow so big and no bigger (number of installed projects??).
I do remember of earlier versions of Eclipse (Photon and before) had a problem with directory depth of pluggins (more a problem of Windows). Didn't know if I'm
still suffering from that.
Also, I checked my Eclipse.ini file saw that max Heap is 1024k. Didn't know if I should double that... Any suggestions.
More if this isn't the proper location for this topic. What Forum would such question be better located in. Let me know for the future.
Current Time: Mon Jul 21 02:31:51 EDT 2025
Powered by FUDForum. Page generated in 0.13298 seconds
