Home » Modeling » TMF (Xtext) » How to validate through all objects
How to validate through all objects [message #1804307] Fri, 22 March 2019 03:29 Go to next message
Hi everyone! I just started learning Xtext and Xtend so please have patience with me :)
I have written a following grammar:
Model:
	'Program' name=ID ';'
	'START'
		model+=(Student | Course | Enroll)*
	'FINISH'
Student:
	'Student' name=ID
	// personal info
	'(' firstName=STRING lastName=STRING 'born' 'in' ageOfBirth=INT ')'
	// student faculty - only fixed choices
	'studies' faculty=('Informatics' | 'Computing' | 'Electrotehnics') ';'
Course:
	'Course' name=ID '(' 'ECTS' ects=INT ')' (students+=[Student])?  ';'
Enroll:
	'Enroll' students+=[Student](',' students+=[Student])* 'to' course=[Course] ';'
and I use the following validation to prevent duplicates:
	@Check
	def checkDuplicateCourseEnrollement(Enroll enroll) {
		val names = newHashSet;
		for(i : enroll.students)
			if(!names.add(i.name))
				error("Duplicate entry: " + "\'" + i.name + "\'!",
					MyDslPackage.Literals.ENROLL__STUDENTS, enroll.students.lastIndexOf(i));
The problem is that my validation only works in this case:
Enroll John, Mark, Mark to Mathematics; // duplicate 'Mark'
but the following does not report an error:
Enroll John to English;
Enroll John, Mark to English;  // I would like to have error here since John is already enrolled to English course
Help would be appreciated!
Re: How to validate through all objects [message #1804413 is a reply to message #1804307] Mon, 25 March 2019 15:15 Go to previous messageGo to next message
i am not sure if i can follow you. but if you want to check multiple enrolls you should do so
	@Check
	def checkDuplicateCourseEnrollement(Model model) {
		val names = HashMultimap.<String,String>create;
		for (enroll : model.model.filter(Enroll))
			for (i : enroll.students)
				if (!names.put(enroll.course.name, i.name))
					error("Duplicate entry: " + "\'" + i.name + "\'!", enroll, MyDslPackage.Literals.ENROLL__STUDENTS,
Re: How to validate through all objects [message #1804418 is a reply to message #1804413] Mon, 25 March 2019 16:06 Go to previous messageGo to next message
That's what I was looking for. Thanks!
[Updated on: Mon, 25 March 2019 16:07] by Moderator
Re: How to validate through all objects [message #1805189 is a reply to message #1804307] Tue, 09 April 2019 10:43 Go to previous messageGo to next message
Hi!
I would like to ask for help regarding code generator for the grammar I already posted.
For generator, I wrote this method:
	override void doGenerate(Resource resource, IFileSystemAccess2 fsa, IGeneratorContext context) {
        fsa.generateFile("generator.txt", '''
            «FOR student : resource.allContents.filter(Student).toIterable»
            Student «student.name»("«student.firstName»", "«student.lastName»", «student.ageOfBirth», "«student.faculty»");
            «ENDFOR»
            «FOR course : resource.allContents.filter(Course).toIterable»
            Course «course.name»(«course.ects»«FOR student : course.students», «student.name»«ENDFOR»);
            «ENDFOR»
For the following application
Program StudentDSL_Test;
START
	Course English (ECTS 6);
	Student John ("John" "Johnston" born in 2000) studies Computing;
	Course Mathematics (ECTS 0) enroll John;
	Student Mark ("Mark" "Markston" born in 2002) studies Informatics;
FINISH
it will generate:
Student John("John", "Johnston", 2000, "Computing");
Student Mark("Mark", "Markston", 2002, "Informatics");
Course English(6);
Course Mathematics(0, John);
The result is as expected; first Student code is generated and then Course code. BUT, how do I rewrite my generator example to respect the order of created objects? In the DSL example above, I would like to have the following generated code:
Course English(6);
I suspect I need to iterate through StudentDSL, but don't know how..
[Updated on: Tue, 09 April 2019 10:46] by Moderator
Re: How to validate through all objects [message #1805190 is a reply to message #1805189] Tue, 09 April 2019 11:45 Go to previous messageGo to next message
simply follow the ast as you do it in the validation.
starting tipp
resource.contents.get(0) as Model
will give you the root
[Updated on: Tue, 09 April 2019 11:46] by Moderator
Re: How to validate through all objects [message #1805192 is a reply to message #1805190] Tue, 09 April 2019 12:18 Go to previous messageGo to next message
Ok. I did this:
		val root = resource.contents.get(0) as StudentDSL;
            «FOR i : root.studentDSL»
            «i.eClass.name»
            «ENDFOR»
This gives object types in correct order. But, I don't know how to access object name and its attributes like firstName, secondName etc.?
[Updated on: Tue, 09 April 2019 12:18] by Moderator
Re: How to validate through all objects [message #1805195 is a reply to message #1805192] Tue, 09 April 2019 13:37 Go to previous messageGo to next message
i cannot follow you without a grammar.
the question is: which type is i of
depending you either can do
«i.someattr»
or
«IF i instanceof SomeSubType»
«i.someattr»
«ENDIF»
Re: How to validate through all objects [message #1805199 is a reply to message #1805195] Tue, 09 April 2019 15:15 Go to previous messageGo to next message
Please check my first post in this topic. It contains the grammar I use.
Re: How to validate through all objects [message #1805200 is a reply to message #1805199] Tue, 09 April 2019 15:20 Go to previous messageGo to next message
(1) there is no studentDSL
(2) the model has model+=(Student | Course | Enroll)* , which want you to look at, maybe the enrolls as in the validation?
use a for loop
«IF e : model.model.filter(Enroll)»
// todo do something with e
«ENDFOR»
Re: How to validate through all objects [message #1805201 is a reply to message #1805200] Tue, 09 April 2019 15:20 Go to previous messageGo to next message
Yes. I just wanted to edit my post :) I renamed Model to StudentDSL in the meantime.
Re: How to validate through all objects [message #1805202 is a reply to message #1805201] Tue, 09 April 2019 15:31 Go to previous messageGo to next message
again: i still dont know along which paths you want to traverse the model
Re: How to validate through all objects [message #1805203 is a reply to message #1805201] Tue, 09 April 2019 15:33 Go to previous messageGo to next message
Please let me revise:
Grammar:
StudentDSL:
	'START'
		studentDSL+=(Student | Course | Enroll)*
	'FINISH'
Student:
	'Student' name=ID
	// personal info
Course:
	'Course' name=ID
	// how many ECTS?
	// enroll students (optional)
	('enroll' students+=[Student](',' students+=[Student])*)?
Enroll:
This is the test DSL application:
START
	Enroll John, Mark to Mathematics;
FINISH
And this is what I am trying to get with the code generator:
    Course English(6);
    Mathematics.Enroll(John, Mark);
I appreciate your time & help :) Please let me know if you need me to clarify anything else.
[Updated on: Tue, 09 April 2019 15:34] by Moderator
Re: How to validate through all objects [message #1805204 is a reply to message #1805203] Tue, 09 April 2019 15:38 Go to previous messageGo to next message
simply iterate over root.studentDSL
do instanceofs for Student else if instanceof Course else if instanceof Enroll
Re: How to validate through all objects [message #1805206 is a reply to message #1805204] Tue, 09 April 2019 15:40 Go to previous messageGo to next message
Thanks! Will be doing battles with this tonight :)
Re: How to validate through all objects [message #1805207 is a reply to message #1805204] Tue, 09 April 2019 15:41 Go to previous messageGo to next message
«FOR item : root.studentDSL»
«IF item instanceof Course»
Course: «item.name»
«ELSEIF item instanceof Student»
Student: «item.name»
«ELSEIF item instanceof Enroll»
«ELSE»
something bad happend. did not expect «item.eClass.name»
«ENDIF»
«ENDFOR»
Re: How to validate through all objects [message #1805208 is a reply to message #1805207] Tue, 09 April 2019 15:41 Go to previous messageGo to next message
no battles. straight forward
Re: How to validate through all objects [message #1805209 is a reply to message #1805208] Tue, 09 April 2019 15:45 Go to previous messageGo to next message
Thanks again! :) Will now try to finish the rest myself.
Re: How to validate through all objects [message #1805212 is a reply to message #1805209] Tue, 09 April 2019 16:29 Go to previous message
Did it!
		fsa.generateFile("program_cpp.txt", '''
		«IF item instanceof Student»
		Student «item.name»("«item.firstName»", "«item.lastName»",«item.ageOfBirth»);
		«ELSEIF item instanceof Course»
		Course «item.name»(«item.ects»);
		«item.course.name».Enroll(«FOR stud : item.students SEPARATOR ', '»«stud.name »«ENDFOR»);
		«ELSE»
		Unrecognized type: «item.eClass.name»
		«ENDIF»
		«ENDFOR»
Previous Topic:Dynamic Elements of Language
Next Topic:Formatter is triggered on quickfix
Current Time: Tue Nov 04 03:40:33 EST 2025
Powered by FUDForum. Page generated in 0.08584 seconds
