Home » Modeling » TMF (Xtext) » Validation (warning) when object is not used
Validation (warning) when object is not used [message #1804343] Fri, 22 March 2019 13:35 Go to next message
I would like to give warning for the variable (object) that was declared but never used in code. Any example for this?
Re: Validation (warning) when object is not used [message #1804416 is a reply to message #1804343] Mon, 25 March 2019 15:32 Go to previous messageGo to next message
do you want to do this locally or globally.
if locally: simply traverse the file for references
if globally: this will be hard. you have to do this in the index. and do it as expensive validation which is explicitely triggered
Re: Validation (warning) when object is not used [message #1804417 is a reply to message #1804416] Mon, 25 March 2019 16:05 Go to previous messageGo to next message
Locally will do for now. Your answer in my previous topic helped me to understand how to traverse the file for references.
Thanks!
Re: Validation (warning) when object is not used [message #1804419 is a reply to message #1804417] Mon, 25 March 2019 16:08 Go to previous messageGo to next message
well i would be doing basically the same.
traverse the tree. looks where references are.
maybe use org.eclipse.xtext.EcoreUtil2.findCrossReferences(EObject, Set<? extends EObject>, ElementReferenceAcceptor)
Re: Validation (warning) when object is not used [message #1804420 is a reply to message #1804419] Mon, 25 March 2019 16:18 Go to previous messageGo to next message
Yes. I understood that I need to traverse but didn't know how.
Like I said, I am just a beginner :)
Re: Validation (warning) when object is not used [message #1804422 is a reply to message #1804420] Mon, 25 March 2019 16:30 Go to previous message
the esiest is to traverse your model along the structure
ask model for its models
have a look if there are student, course, enroll.
have a looks at the references within these
Previous Topic:Space validation
Next Topic:Troubles understanding Qualified Name
Current Time: Sun Jul 20 22:27:10 EDT 2025
Powered by FUDForum. Page generated in 0.11882 seconds
