Home » Eclipse Projects » RCP Testing Tool » Checking graph contents
Checking graph contents [message #1804220] Wed, 20 March 2019 11:51 Go to next message
Can you please help me with the best approach that I can use to verify a graph. The application under tests produces graph that I need to check the formality of the graph as well as its contents. So how can I perform these checks using RCPTT 2.2.0 version.
Re: Checking graph contents [message #1805054 is a reply to message #1804220] Fri, 05 April 2019 00:37 Go to previous message
We support multiple diagram frameworks like GEF and GMF.
If graph uses one of supported frameworks, RCPTT could inspect it.
If it doesn't help, could you please explain your question in more details.
Previous Topic:Unwanted conversion to float when passing a string to a proc
Next Topic:Configure Drak Mode Problem
Current Time: Thu Sep 25 20:59:58 EDT 2025
Powered by FUDForum. Page generated in 0.03305 seconds
