paho async c++ client, no timeout on MQTTAsync_sendMessage? [message #1804174] |
Tue, 19 March 2019 18:01 |
I'm implementing an mqtt client interface for my application using the paho library. When making the MQTTAsync_sendMessage call there does not appear to be any way to specify a timeout so... should it be assumed that until either a callback is received to either the MQTTAsync_sendMessage "onSuccess" or "onFailure" callback functions (or to the MQTTAsync_connectionLost callback function specified via MQTTAsync_setCallbacks) that the underlying code is retrying the send indefinitely? Is there maybe just some hard timeout after which I'll get an "onFailure" callback? Since I require fairly low throughput I'm keeping it simple and only sending one message at a time so I assume if I just start doing my own resends after some period I could end up getting multiple "onSuccess"/"onFailure" callbacks eventually which I'd rather not have to deal with if possible. I know I can use the tokens to keep track but sending only one message at a time I'm hoping to avoid that...
FUDForum. Page generated in 0.02929 seconds
