Home » Archived » BIRT » JBoss, birt.war - deploy own report - how?
JBoss, birt.war - deploy own report - how? [message #103570] Tue, 03 January 2006 10:33 Go to next message
I finally got the JBoss working successfully. Also to deploy the birt.war
was successfull and I got the test.rptdesign report working properly.
My question now, how can I deploy my own BIRT report now?
Do I have to add it to the birt.war archieve and deploy the birt.war to
JBoss again?
Whats the right way?
Thanks for any help!
Re: JBoss, birt.war - deploy own report - how? [message #103681 is a reply to message #103570] Tue, 03 January 2006 14:12 Go to previous messageGo to next message
Originally posted by: to.sreddy.gmail.com
As per the documentation you have to put your .rptdesign file in WEB-INF
folder and redeploy it. By the why how did you deploy it in jboss? Can you
write down the step by step procedure? including which versions of s/w you
are using like jdk,birt,jboss...etc.
Srini
Re: JBoss, birt.war - deploy own report - how? [message #103824 is a reply to message #103681] Wed, 04 January 2006 04:28 Go to previous messageGo to next message
Hello Srini,
not really helpful what you wrote. But thanks anyway.
The birt.war comes with the installation of BIRT and contains only the
test.rptdesign.
This I can deploy easily to JBoss. But how can I deploy my own report?
Should I modify the original birt.war and delete the test.rptdesign file and
add my own *.rptdesign file and deploy to JBoss again?
Should I copy my *.rptdesign file in the temporary folder where JBoss
extracted the birt.war?
So what is the correct way to do?
To answer your question, I use
Java 1.5.0_03
JBoss 4.0.3SP1
BIRT 2.0M2
Eclipse 3.1.0 Build ID I20050627-1435
I installed the JBoss under SuSE Linux 9.3 like described in the
documentation on www.jboss.org. I used the shell sript in the jboss/bin
directory, modified it like described in the skript to run it as demon.
Then, when JBoss is running you can just copy the birt.war into the
jboss/server/default/deploy directory.
(where jboss is the path to your JBoss root directory from installation)
After a few seconds JBoss recognized this new application automatically and
you can access BIRT using a webbrowser with following URL:
http://yourlocalhostip:8080/birt
where yourlocalhostip is the IP of your JBoss server IP
Hope that helps,
best regards,
Mr. Burns
"srini" <to.sreddy@gmail.com> schrieb im Newsbeitrag
news:2100d9e67ed4fc358caa42fa0dceceb5$1@www.eclipse.org...
> Srini
Re: JBoss, birt.war - deploy own report - how? [message #104223 is a reply to message #103570] Wed, 04 January 2006 13:58 Go to previous messageGo to next message
You should be able to specify a location ie
/myreports/myfirstreport.rptdesign in the URL.
It should be in relation to your context.
Jason
"Mr. Burns" <Mr._Burns@web.de> wrote in message
news:dpe5gf$n1d$1@utils.eclipse.org...
> Hello,
> JBoss again?
Re: JBoss, birt.war - deploy own report - how? [message #104912 is a reply to message #104223] Thu, 05 January 2006 10:52 Go to previous messageGo to next message
Hello Jason,
thanks for your reply, bt (sorry) I cannot really follow.
I have the birt.war deployed to JBoss, and I can find the birt directory
somewhere like D:\bossroot\deploy\tmp\deploy\tmp38339birt-exp.war
But this directory is temporary and disappears after I stop the JBoss server
again, so if I use a absolute path like you wrote my *.rptdesign file is
deleted as well after I stop the JBoss.
Sorry for bothering you again, but can you explain more detailed or give an
example?
Thanks a lot!
"Jason Weathersby" <jweathersby@actuate.com> schrieb im Newsbeitrag
news:dph5to$qd6$1@utils.eclipse.org...
> Jason
>> Hello,
>> JBoss again?
Re: JBoss, birt.war - deploy own report - how? [message #105130 is a reply to message #104912] Thu, 05 January 2006 17:07 Go to previous messageGo to next message
Sorry for the confusion.
I have not used JBoss that much.
If you use the path as I explained earlier it uses where the context is
mapped to.
On JBoss this may be temp. You may have to rewar the birt.war file, but I
would think there would be an easier way.
Next week I will try this with JBoss.
Jason
news:dpjfdp$qph$1@utils.eclipse.org...
> Hello Jason,
> server again, so if I use a absolute path like you wrote my *.rptdesign
> file is deleted as well after I stop the JBoss.
> an example?
> Thanks a lot!
>> Jason
>>> Hello,
>>> birt.war was successfull and I got the test.rptdesign report working
>>> properly.
>>> JBoss again?
Re: JBoss, birt.war - deploy own report - how? [message #105328 is a reply to message #105130] Fri, 06 January 2006 05:06 Go to previous messageGo to next message
Hello Jason,
thanks a lot, this would be great!
Re: JBoss, birt.war - deploy own report - how? [message #1804116 is a reply to message #105328] Mon, 18 March 2019 13:11 Go to previous message
mr. burns,
I need an answer to your good question also.
Did you find in meanwhile an easier way for deploying a report instead of the time consuming manual replacement of the report file in the war and restarting the JBoss server?
Previous Topic:Report parameter /Link
Next Topic:BIRT Chart color manipulation
Current Time: Sun Jul 27 14:16:27 EDT 2025
Powered by FUDForum. Page generated in 0.25025 seconds
