Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » compiling error with ev3dev parameters code(compiling error with ev3dev parameters code)
compiling error with ev3dev parameters code [message #1803754] Fri, 08 March 2019 06:35 Go to next message
Hi All,
I am facing a problem during compiling the code of a SIFB with a cross compiler. How can I include the parameter features in a right way for ev3dev into SIFB because the cross compiler don't know about outB,motor,enable,QX etc. (https://www.eclipse.org/4diac/en_help.php?helppage=html/parameters/parameters.html#ev3). Should I add some wiring features or what should I add? The SIFB code and compiling error is shown in the attached pictures.
I would be nice if someone can upload an example project for ev3dev with 4diac FBs. Thanks.
Regard
Adeel
  • Attachment: 1.png
    (Size: 64.91KB, Downloaded 227 times)
  • Attachment: 2.png
    (Size: 85.20KB, Downloaded 220 times)
Re: compiling error with ev3dev parameters code [message #1803755 is a reply to message #1803754] Fri, 08 March 2019 06:42 Go to previous messageGo to next message
Hi Adeel,
based on what I see from your screenshots you have two errors,
The first is, that INs and OUTs are not direct variables, but hidden behind function calls. So instead of
outB.motor.enable(QX);
you have to write
outB().motor.enable(QX());
, assuming outB is also a IN or OUT of your FB.
The other thing is, that you FB definition seems to be wrong. Could it be that your INs and OUTs of your FB are missing from the C++ file? If yes first check our FB definition in 4diac-IDE and then reexport it.
Martin
Re: compiling error with ev3dev parameters code [message #1803764 is a reply to message #1803755] Fri, 08 March 2019 11:34 Go to previous messageGo to next message
Thanks dear Martin for your quick response. Do you have some idea why the fuction blocks (BUTTON, MOTOR) are not initiating/starting? as you can see in attached screenshot 3. ev3 device is connected and forte is running on it.
  • Attachment: 3.png
    (Size: 74.81KB, Downloaded 212 times)
  • Attachment: 4.png
    (Size: 20.03KB, Downloaded 205 times)
Re: compiling error with ev3dev parameters code [message #1803767 is a reply to message #1803764] Fri, 08 March 2019 12:50 Go to previous messageGo to next message
hi,
I would recommend to not automatically start the E_CYCLE directly from the E_RESTART. The many E_CYCLE events are shadowing any other error message from init. Better for testing do not connect the START event of E_CYCLE and invkoe the START later from 4diac IDE with the trigger event feature. Regarding the initlisation problem: is the sensor or the actuature connected to your EV3?
Re: compiling error with ev3dev parameters code [message #1804019 is a reply to message #1803767] Fri, 15 March 2019 17:40 Go to previous messageGo to next message
Thnaks dear Alois for your response,
I have found the reason that why the function block was not initialing.
Now, the FB is working and forte is also running on it. Thanks for your comments.
[Updated on: Sat, 16 March 2019 07:01] by Moderator
Re: compiling error with ev3dev parameters code [message #1804079 is a reply to message #1804019] Sun, 17 March 2019 14:35 Go to previous messageGo to next message
You are welcome. I'm sorry I've worked with EV3 yet, therefore I have no idea.
Re: compiling error with ev3dev parameters code [message #1804095 is a reply to message #1804079] Mon, 18 March 2019 06:23 Go to previous messageGo to next message
Can you explain what the problem was in case someone else has the same problem? An example with ev3dev can be found here:
https://www.eclipse.org/4diac/en_help.php?helppage=html/examples/pidMotor.html
Re: compiling error with ev3dev parameters code [message #1804106 is a reply to message #1804095] Mon, 18 March 2019 10:04 Go to previous messageGo to next message
There was actually two problems:
1.It is required to configure, generate and build the ev3 environment into the forte executable. if you are working with cmake then you will find a tick mark of FORTE_MODULE_LMS_EV3.
2.There is needed to correct the implementation code of processinterface.cpp file in /forte/src/modules/lms_ev3. The function name "pushBack" is needed to replace with standard call "push_back" from the c++ "vector" library.
if you do this then hopefully the function blocks will initialize.
Regard
Adeel
Re: compiling error with ev3dev parameters code [message #1804277 is a reply to message #1804106] Thu, 21 March 2019 13:11 Go to previous messageGo to next message
thanks for the feedback. Yes we also noticed your 2nd problem. I'll try to get a fix into the 1.10.2 maintainence release.
BR,
Alois
Re: compiling error with ev3dev parameters code [message #1804766 is a reply to message #1804277] Sun, 31 March 2019 17:42 Go to previous messageGo to next message
Hi dear Alois,
There is one more thing if you like to modify in the next release.
The output function block "QW" from "io" of general typelibrary of 4diac IDE has an input variable "OUT" of WORD type which accepts only positive values and not the negative. For example in case of ev3 Lego Mindstorm, if you want to use PWM (OUT= -100 to 100) for output signal then QW does not accept negative values by showing zero by default and the motor doesn't move in the reverse direction.
I have covered up this issue by changing the variable type from WORD to SINT in 4diac IDE and in forte corresponding replacing WORD by SINT in the QW.cpp and QW.h at forte/src/stdfblib/io.
Regard
Muhammad Adeel
Re: compiling error with ev3dev parameters code [message #1804841 is a reply to message #1804766] Tue, 02 April 2019 03:55 Go to previous messageGo to next message
thanks for pointing that out. This is important to know. However the W in QW stands for WORD and is based on semantics defined in IEC 61131-3. Maybe we need to introduce more Q and I blocks for better handling such use cases.
Alois
Re: compiling error with ev3dev parameters code [message #1804975 is a reply to message #1804841] Thu, 04 April 2019 03:23 Go to previous message
Try using a F_INT_TO_WORD before the QW FB. This should do the conversion and later QW should do the backwards conversion.
Previous Topic:Access 4diac-IDE on browser
Next Topic:c++ SIFB code monitoring
Current Time: Sun Oct 19 20:24:53 EDT 2025
Powered by FUDForum. Page generated in 0.06310 seconds
