Bug: MySQL Connection only works in connection dialog [message #1804072] |
Sun, 17 March 2019 10:24  |
Hi All,
I'm experimenting a weird error regarding connections.
I'm using Eclipse IDE for Java and Report Developers, Version: Neon. 3 Release (4.6.3) Build id: 20170314-1500, on macOS Mojave 10.14.3; BIRT Framework 4.6.0.v201606072122.
I configure a new MySQL connection with the data source dialog window, using the driver com.mysql.jdbc.Driver (v5.1), which is already downloaded.
I test the connection and it shows the "Connection Successful" message.
But after I close the dialog, and try to use the data source in a new or existing data set, I get the following error message:
Access denied for user 'redacted'@'localhost' (using password: YES)
If I go back to edit the connection and test it again, I get a "Failed to create a connection. Please verify the connection properties" error message. If I re-enter the password, the error goes away and I'm back to step 1, that is, every time I try to use the data source I get an access denied error.
Any ideas why this is happening and how it can be resolved?
Many thanks in advance.
FUDForum. Page generated in 0.03630 seconds
