Home » Eclipse Projects » Eclipse Kapua » Failed to start kapua-broker(Failed to start kapua-broker caused by "Failed to configure ElasticSearch rest client")
Failed to start kapua-broker [message #1803512] Fri, 01 March 2019 21:14 Go to next message
Trying to start the kapua with the "latest" version. "kapua-broker" could not start with the following error. "elasticsearch:5.4.0" is used by the kapua and it also failed to start without any log.
*** kapua-broker error log ***
10:00:41.392 [main] WARN o.a.a.xbean.XBeanBrokerFactory$1 - Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dataStorageMessageProcessor' defined in class path resource [camel.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.eclipse.kapua.broker.core.listener.DataStorageMessageProcessor]: Constructor threw exception; nested exception is com.google.inject.ProvisionException: Unable to provision, see the following errors:
1) Error injecting constructor, java.lang.ExceptionInInitializerError
at org.eclipse.kapua.service.datastore.internal.MessageStoreServiceImpl.<init>(MessageStoreServiceImpl.java:88)
while locating org.eclipse.kapua.service.datastore.internal.MessageStoreServiceImpl
at org.eclipse.kapua.locator.guice.KapuaModule.configure(KapuaModule.java:120)
while locating org.eclipse.kapua.service.datastore.MessageStoreService
Caused by: org.eclipse.kapua.service.datastore.client.ClientUnavailableException: Error: Failed to configure ElasticSearch rest client
at org.eclipse.kapua.service.datastore.client.rest.EsRestClientProvider.<init>(EsRestClientProvider.java:218)
at org.eclipse.kapua.service.datastore.client.rest.EsRestClientProvider.<init>(EsRestClientProvider.java:202)
at org.eclipse.kapua.service.datastore.client.rest.EsRestClientProvider.<init>(EsRestClientProvider.java:192)
at org.eclipse.kapua.service.datastore.client.rest.EsRestClientProvider.init(EsRestClientProvider.java:108)
at org.eclipse.kapua.service.datastore.client.rest.RestDatastoreClient.initClientProvider(RestDatastoreClient.java:179)
at org.eclipse.kapua.service.datastore.client.rest.RestDatastoreClient.<init>(RestDatastoreClient.java:168)
at org.eclipse.kapua.service.datastore.client.rest.RestDatastoreClient.getInstance(RestDatastoreClient.java:141)
... 77 more
I don't think there is a bug in the system source code, but more about the configuration.
Following is my system configuration:
OS: macOS High Sierra 10.13.6
Docker Desktop Community: 2.0.0.3 (31259)
Java: 1.8.0_201
Please advise on possible cause of the error, or a walkthrough document will be very helpful. Thank you!!!
Re: Failed to start kapua-broker [message #1804062 is a reply to message #1803512] Sun, 17 March 2019 00:56 Go to previous messageGo to next message
The cause was insufficient memory allocated to the docker container:
- The default memory allocation for docker container is 1GB
- elasticsearch requires more than 2GB
After increasing the docker to 4GB, the elasticsearch container starts successfully, and kapua-broker container is able to run succesfully.
Re: Failed to start kapua-broker [message #1808772 is a reply to message #1804062] Mon, 01 July 2019 06:44 Go to previous message
Hi Entao,
Yes, some containers are a bit memory hungry.
6GB of memory assigned to Docker is recommended.
- Alberto
Previous Topic:Unable to login Eclipse Kapua web console
Next Topic:lose class?why?
Current Time: Mon Jul 21 08:35:00 EDT 2025
Powered by FUDForum. Page generated in 0.04514 seconds
