Home » Language IDEs » ServerTools (WTP) » preferred mechanism for putting jars into shared/lib
preferred mechanism for putting jars into shared/lib [message #180312] Sat, 30 September 2006 09:31 Go to next message
What is the preferred method for loading jars that will ultimately sit
in CATALINA_BASE/shared/lib
It seems a bit perverse to manually copy them to the strange directory
inside .metadata/.plugins
Re: preferred mechanism for putting jars into shared/lib [message #180405 is a reply to message #180312] Mon, 02 October 2006 07:31 Go to previous message
The default is that "shared/lib" is relative to catalina.base, which is
why it would normally need to go under ".metadata/.plugins/...". You
could import the catalina.properties in your installation's "conf"
directory into the same folder containing your server.xml under the
Servers project in your workspace. You could modify the "shared.loader"
setting in this file to be what you want. The catalina.properties file
will get copied to the "tmp?/conf" directory under
".metadata/.plugins/..." when the server gets published.
Larry
Previous Topic:EclipseCon 2007 Call for Participation
Next Topic:Automatically generating a JAR in a WAR
Current Time: Sat Jul 26 09:45:36 EDT 2025
Powered by FUDForum. Page generated in 0.06272 seconds
