Null properties of the EObject in the ScopeProvider [message #1804006] |
Fri, 15 March 2019 08:24  |
Hi all. I have make the grammar and the ScopeProvider(please, see it below) and get the null pointer exception.
class foo { key k: integer; mutable name; }
operation op() {
update foo @{foo.k == 122}(name = "new_name");
It means, that in the following rule classRef equals to null. But really it's not.
How to solve this problem?
Regards, Vladimir
0 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment '|2' failed.
at org.blockchain.rell.scoping.RellScopeProvider.getVarDeclList(RellScopeProvider.java:273)
at org.blockchain.rell.scoping.RellScopeProvider.getVariableDeclarationRefScope(RellScopeProvider.java:91)
at org.blockchain.rell.scoping.RellScopeProvider.getScope(RellScopeProvider.java:314)
grammar org.blockchain.rell.Rell with org.eclipse.xtext.common.Terminals
generate rell "http://www.blockchain.org/rell/Rell"
Model:
entities+=ClassDefinition*
operations+=Operation*;
ClassDefinition:
('class' | 'record') name=ID ('extends' superType=[ClassDefinition])? '{'
attributeListField+=AttributeListField*
AttributeListField:
mutable=Mutable? key=Key? index=Index? attributeList+=RelAttrubutesList ';';
Operation:
"operation" name=ID "(" parameters=RelAttrubutesList? ")" "{" statements+=Statement* "}";
Statement:
(methodCall=DotValue|relation=Update | variable=OperationVariable | varInitiation=VarInitiation) ';';
VarInitiation:
name=VariableDeclarationRef (('[' expr=Expression']')?) (ASSIGNMENT expression=Expression)?;
OperationVariable:
assessModificator=(Var | Val) variable=Variable;
Variable:
name=VariableDeclaration ((ASSIGNMENT expression=Expression)?);
Update:
'update' entity=TableNameWithAlias (('@' '{' ((conditions+=Expression (',' conditions+=Expression)*)?) '}')?) '('
createWhatPart+=CreateWhatPart (','
createWhatPart+=CreateWhatPart)*
CreateWhatPart:
(DOT? varDeclRef=VariableDeclarationRef ASSIGNMENT)?
condition+=Expression;
ClassMemberDefinition:
(classRef=[TableNameWithAlias])? DOT (variableDeclarationRef=VariableDeclarationRef);
TableNameWithAlias:
classRefDecl=ClassRefDecl |
justNameDecl=JustNameDecl;
ClassRefDecl:name=ID DOUBLE_QUOTE classDef=[ClassDefinition];
JustNameDecl:name=[ClassDefinition];
VariableDeclarationRef:
name=[VariableDeclaration|ValuableID];
AccessToList:
'[' expr=Expression ']';
Expression:
or=Or;
Or returns Expression:
And ({Or.left=current} "or" right=And)*;
And returns Expression:
Equality ({And.left=current} "and" right=Equality)*;
Equality returns Expression:
Comparison ({Equality.left=current} op=EQUALS
right=Comparison)*;
Comparison returns Expression:
PlusOrMinus ({Comparison.left=current} op=EQUALS
right=PlusOrMinus)*;
PlusOrMinus returns Expression:
MulOrDiv (({Plus.left=current} PlusChar | {Minus.left=current} MinusChar)
right=MulOrDiv)*;
MulOrDiv returns Expression:
Primary ({MulOrDiv.left=current} op=(MulChar | DivChar)
right=Primary)*;
Primary returns Expression:
'(' Expression ')' |
{Not} "not" expression=Primary |
DotValue;
Atomic returns Expression:
{IntConstant} value=IntWithMinus
|{StringConstant} value=STRING |
{ByteArrayConstant} value=BYTE_ARRAY_VALUE |
{BoolConstant} value=('true' | 'false')
| {TheNull} value=NULL
|{ClassMemberDef} value=ClassMemberDefinition
| {VariableDeclarationRef} value=VariableDeclarationRef
DotValue:
atom=Atomic ((accesToList=AccessToList?) DOT dotPart=DotValue)?;
MapCreationPart:
exprKey=Expression DOUBLE_QUOTE exprValue=Expression;
RelAttrubutesList:
value+=Variable (',' value+=Variable)*;
VariableDeclaration:
name=ValuableID ((DOUBLE_QUOTE type=TypeReference)?);
TypeReference:
type=PrimitiveType | entityType=[ClassDefinition] ;
PrimitiveType:
Text | Tuid | Pubkey | Name | Integer | Boolean;
ValuableID:
PrimitiveType | ID;
IntWithMinus:
MinusChar? INT;
Name:
'name';
Pubkey:
'pubkey';
Timestamp:
'timestamp';
Tuid:
'tuid';
Boolean:
'boolean';
Integer:
'integer';
Text:
'text';
Key:
'key';
Index:
'index';
Mutable:
'mutable';
Var:
'var';
Val:
'val';
PlusChar:
MinusChar:
MulChar:
DivChar:
terminal ASSIGNMENT:'=';
terminal EQUALS:
terminal DOUBLE_QUOTE:
terminal NULL:
'null';
terminal DOT:'.';
terminal BYTE_ARRAY_CHAR:
'0' | '1' | '2' | '3' | '4' | '5' | '6' | '7' | '8' | '9' | 'a' | 'b' | 'c' | 'd' | 'e' | 'f' | 'A' | 'B' | 'C' | 'D'
| 'E' | 'F';
terminal BYTE_ARRAY_PAIR:
BYTE_ARRAY_CHAR BYTE_ARRAY_CHAR;
terminal BYTE_ARRAY_VALUE:
'x' (('\'' BYTE_ARRAY_PAIR* '\'') | ('"' BYTE_ARRAY_PAIR* '"'));
* generated by Xtext 2.10.0
package org.blockchain.rell.scoping
import java.util.List
import javax.inject.Inject
import org.blockchain.rell.rell.AttributeListField
import org.blockchain.rell.rell.ClassDefinition
import org.blockchain.rell.rell.ClassMemberDef
import org.blockchain.rell.rell.ClassMemberDefinition
import org.blockchain.rell.rell.CreateWhatPart
import org.blockchain.rell.rell.DotValue
import org.blockchain.rell.rell.Expression
import org.blockchain.rell.rell.JustNameDecl
import org.blockchain.rell.rell.Operation
import org.blockchain.rell.rell.TableNameWithAlias
import org.blockchain.rell.rell.Update
import org.blockchain.rell.rell.VariableDeclaration
import org.blockchain.rell.rell.VariableDeclarationRef
import org.blockchain.rell.typing.RellClassType
import org.blockchain.rell.typing.RellModelUtil
import org.blockchain.rell.typing.RellTypeProvider
import org.eclipse.emf.common.util.EList
import org.eclipse.emf.ecore.EObject
import org.eclipse.emf.ecore.EReference
import org.eclipse.xtext.EcoreUtil2
import org.eclipse.xtext.scoping.IScope
import org.eclipse.xtext.scoping.Scopes
import org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider
* This class contains custom scoping description.
* See https://www.eclipse.org/Xtext/documentation/303_runtime_concepts.html#scoping
* on how and when to use it.
class RellScopeProvider extends AbstractDeclarativeScopeProvider {
@Inject extension RellTypeProvider
def IScope getVariableDeclarationRefScope(VariableDeclarationRef variableDeclarationRef, EReference ref) {
val container = variableDeclarationRef.eContainer;
switch (container) {
case (container instanceof VariableDeclarationRef): {
if (container.eContainer instanceof DotValue) {
val dotValue = container.eContainer as DotValue
val parent = dotValue.eContainer
switch (parent ) {
case (parent.eContainer instanceof CreateWhatPart): {
val scope = makeWhatPartVariableDeclarations(parent.eContainer)
val operation = EcoreUtil2.getContainerOfType(variableDeclarationRef, Operation)
if (operation !== null) {
var operationVars = RellModelUtil.usedVariables(operation as Operation).filter [ variableInfo |
variableInfo.declared
].map[variableInfo|variableInfo.variableDeclaration]
scope.addAll(operationVars)
return Scopes::scopeFor(scope)
case (container instanceof ClassMemberDefinition): {
val classMemberDefinition = container as ClassMemberDefinition;
val classRef = classMemberDefinition.classRef;
if (classRef !== null) {
val varDeclList = classRef.getVarDeclList
return Scopes::scopeFor(varDeclList)
} else {
val relContainer = variableDeclarationRef.relationalContainer
switch (relContainer) {
case (relContainer instanceof Update): {
return (relContainer as Update).getVariableDeclarationRefScope
case (container instanceof CreateWhatPart): {
return Scopes::scopeFor(makeWhatPartVariableDeclarations(container))
return super.getScope(variableDeclarationRef, ref)
protected def IScope variableDeclarationRefScope(VariableDeclarationRef variableDeclarationRef, EObject container,
EReference ref) {
val notNotExprContainer = (container as ClassMemberDefinition).notClassMemberDefinition
switch (notNotExprContainer) {
case (notNotExprContainer instanceof DotValue): {
val parentDotValue = notNotExprContainer as DotValue;
val atom = parentDotValue.atom;
switch (atom) {
case (atom instanceof ClassMemberDefinition): {
val classMemberDefinition = atom as ClassMemberDefinition;
val variableDclarationRef = classMemberDefinition.variableDeclarationRef
if (variableDclarationRef != null) {
val typeFor = variableDclarationRef.typeFor
// EcoreUtil2.getContainerOfType()
if (typeFor instanceof RellClassType) {
val variableDeclarationList = (typeFor as RellClassType).rellClassDefinition.
attributeListField.makeVariableDeclarationList
return Scopes::scopeFor(variableDeclarationList)
case (container instanceof Update): {
val update = container as Update
return Scopes::scopeFor(update.entity.makeVariableDeclarationList)
return Scopes::scopeFor(container.makeWhatPartVariableDeclarations)
default: {
val scope = super.getScope(variableDeclarationRef, ref)
// println("scope"+scope.allElements)
return scope;
return scope;
protected def List<VariableDeclaration> makeWhatPartVariableDeclarations(EObject container) {
var ClassDefinition en;
switch (container.eContainer) {
case container.eContainer instanceof Update: {
en = (container.eContainer as Update).entity.getClassDefinitionByTableNameWithAlias
return en.attributeListField.makeVariableDeclarationList
protected def List<VariableDeclaration> makeVariableDeclarationList(EList<AttributeListField> attrubuteListField) {
val List<VariableDeclaration> variableDeclarationList = newArrayList;
attrubuteListField.forEach [ x |
if (x.attributeList !== null) {
x.attributeList.forEach [ attrList |
if (attrList !== null && attrList.value !== null) {
attrList.value.forEach [ variable |
if (variable !== null) {
variableDeclarationList.add(variable.name)
protected def getClassDefinitionByTableNameWithAlias(TableNameWithAlias tableNameWithAlias) {
switch (tableNameWithAlias) {
case (tableNameWithAlias.classRefDecl!==null): {
return (tableNameWithAlias.classRefDecl).classDef
case (tableNameWithAlias.justNameDecl!==null): {
return (tableNameWithAlias as JustNameDecl).name
protected def List<VariableDeclaration> makeVariableDeclarationList(TableNameWithAlias tableNameWithAlias) {
val attributeListField = tableNameWithAlias.getClassDefinitionByTableNameWithAlias.attributeListField
attributeListField.forEach [ x |
def IScope getClassMemberDefinition(ClassMemberDefinition classMemberDefinition, EObject processedObject,
EReference ref) {
val notExprConst = classMemberDefinition.eContainer.notExressionContainer
switch (notExprConst) {
case (notExprConst instanceof Update): {
return (notExprConst as Update).getClassMemberDefScope;
return super.getScope(processedObject, ref);
def getClassMemberDefScope(Update update) {
val List<TableNameWithAlias> classDefList = newArrayList
classDefList.add(update.entity)
return Scopes::scopeFor(classDefList);
* Return the variable declaration names scope for Update
def getVariableDeclarationRefScope(Update update) {
val List<VariableDeclaration> classDefList = makeVariableDeclarationList(update.entity.getClassDefinitionByTableNameWithAlias.attributeListField)
def getVarDeclList(TableNameWithAlias tableNameWithAlias) {
var EList<AttributeListField> attrubuteListField = tableNameWithAlias.getClassDefinitionByTableNameWithAlias.attributeListField
if (attrubuteListField === null) {
return newArrayList
return makeVariableDeclarationList(attrubuteListField);
def notExressionContainer(EObject context) {
var privateContainer = context
while (privateContainer instanceof Expression) {
privateContainer = privateContainer.eContainer
return privateContainer;
def relationalContainer(EObject context) {
while (!(privateContainer instanceof Update)) {
def notClassMemberDefinition(EObject context) {
while (privateContainer instanceof ClassMemberDefinition) {
override IScope getScope(EObject context, EReference reference) {
switch (context) {
case (context === null):
return IScope.NULLSCOPE
case (context instanceof VariableDeclarationRef): {
return getVariableDeclarationRefScope(context as VariableDeclarationRef, reference);
return super.getScope(context, reference);
Re: Null properties of the EObject in the ScopeProvider [message #1805469 is a reply to message #1804054] |
Mon, 15 April 2019 12:40  |
I have already implemented it, but some time name provider is not worked(Please, see my updated grammar bellow)
Consider this code
class user { firstName: text;}
query q1() { val t = user @ { .firstName == 'Bill' }; return t.firstName; }
I have the null pointer exception
And as I debug, it's happends because the "TableNameWithAlias" in this place has both fields equals to null
So this method return null
case (tableNameWithAlias.classRefDecl !== null): {
case (tableNameWithAlias.justNameDecl !== null): {
return tableNameWithAlias.justNameDecl.name
And I can't add to the scope field of the "t" i.e. t.firstName
I believe it's because compiler really doesn't know the type of t. Is it true? If yes, probably I need to add the type inference and get the type of t from it. So, may I ask you to give me the best architecture of this functionality?
org.eclipse.emf.common.util.WrappedException: java.lang.NullPointerException
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:244)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.doResolveLazyCrossReference(LazyLinkingResource.java:203)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReference(LazyLinkingResource.java:162)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReferences(LazyLinkingResource.java:148)
at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:500)
at org.eclipse.xtext.validation.ResourceValidatorImpl.resolveProxies(ResourceValidatorImpl.java:161)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:74)
at org.eclipse.xtext.testing.validation.ValidationTestHelper.validate(ValidationTestHelper.java:168)
at org.eclipse.xtext.testing.validation.ValidationTestHelper.assertNoErrors(ValidationTestHelper.java:178)
at org.eclipse.xtext.testing.validation.ValidationTestHelper.assertNoErrors(ValidationTestHelper.java:92)
at org.blockchain.rell.tests.WorkingTests.assertParsingTrue(WorkingTests.java:2210)
at org.blockchain.rell.tests.WorkingTests.testBuilkAssignOperatorInWhatPartMin(WorkingTests.java:45)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
at org.eclipse.xtext.testing.XtextRunner$1.evaluate(XtextRunner.java:49)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:89)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:41)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:541)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:763)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:463)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:209)
at org.blockchain.rell.scoping.RellScopeProvider.getVarDeclList(RellScopeProvider.java:430)
at org.blockchain.rell.scoping.RellScopeProvider.getVariableDeclarationRefScope(RellScopeProvider.java:136)
at org.blockchain.rell.scoping.RellScopeProvider.getScope(RellScopeProvider.java:528)
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getScope(DefaultLinkingService.java:58)
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getLinkedObjects(DefaultLinkingService.java:107)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:265)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:236)
... 35 more
Model:
operations+=(Operation | Query | Function)*;
ClassDefinition:
('class' | 'record' | 'object') name=ID ('extends' superType=[ClassDefinition])? LEFT_BRACE
RIGHT_BRACE;
AttributeListField:
Operation:
"operation" name=ID LEFT_BRACKET parameters=RelAttrubutesList? RIGHT_BRACKET LEFT_BRACE statements+=Statement*
('return'
returnExr=Expression ';')? RIGHT_BRACE;
Query:
"query" name=ID LEFT_BRACKET parameters=RelAttrubutesList? RIGHT_BRACKET
((ASSIGNMENT returnExr=Expression ';') |
(LEFT_BRACE
(('return' returnExr=Expression ';')?)
RIGHT_BRACE));
Function:
"function" name=ID LEFT_BRACKET parameters=RelAttrubutesList? RIGHT_BRACKET
(DOUBLE_QUOTE type=TypeReference QuestionChar?)?
(LEFT_BRACE
RIGHT_BRACE));
Statement:
(relation=Relational | variable=OperationVariable | varInitiation=VarInitiation | methodCall=DotValue) ';';
VarInitiation:
name=Expression ASSIGNMENT
expression=Expression;
OperationVariable:
Variable:
Relational:
AtOperator | Update | Delete | Create;
Update:
'update' (tableNameWithAlias+=TableNameWithAlias | LEFT_BRACKET tableNameWithAlias+=TableNameWithAlias (','
tableNameWithAlias+=TableNameWithAlias)* RIGHT_BRACKET) ((Ampersand LEFT_BRACE ((conditions+=Expression (','
conditions+=Expression)*)?) RIGHT_BRACE)?) LEFT_BRACKET
RIGHT_BRACKET;
Delete:
'delete' (tableNameWithAlias+=TableNameWithAlias | LEFT_BRACKET tableNameWithAlias+=TableNameWithAlias (','
tableNameWithAlias+=TableNameWithAlias)* RIGHT_BRACKET) Ampersand LEFT_BRACE conditions+=Expression (','
conditions+=Expression)* RIGHT_BRACE;
Create:
'create' (tableNameWithAlias+=TableNameWithAlias | LEFT_BRACKET tableNameWithAlias+=TableNameWithAlias (','
tableNameWithAlias+=TableNameWithAlias)* RIGHT_BRACKET) LEFT_BRACKET (createWhatPart+=CreateWhatPart (','
createWhatPart+=CreateWhatPart)*)? RIGHT_BRACKET;
//There are problem with record part. So will check it in the validatiie
CreateClassPart:
(entity=[ClassDefinition]) LEFT_BRACKET (createWhatPart+=CreateWhatPart (','
CreateWhatPart:
(ASSIGNMENT? DOT? varDeclRef=VariableDeclarationRef (ASSIGNMENT | PLUS_ASSGIN | MINUS_ASSGIN | DIV_ASSGIN |
MUL_ASSGIN))?
AtOperator:
(LEFT_BRACKET
tableNameWithAlias+=TableNameWithAlias (',' tableNameWithAlias+=TableNameWithAlias)*
RIGHT_BRACKET))
Ampersand
(ampersandModificator=AmpersandModificator?)
LEFT_BRACE
(ASSIGNMENT? conditions+=Expression (',' ASSIGNMENT? conditions+=Expression)*)?
RIGHT_BRACE
(tupleValue=TupleValue?);
TupleValue:
LEFT_BRACKET members+=TupleValueMember (',' tuplePart+=TupleValueMember)* RIGHT_BRACKET;
ListCreation:
LEFT_SQUARE_BRACE arguments=Arguments RIGHT_SQUARE_BRACE (DOT EMBEDDED_METHOD
listMethodArguments+=ArgumentsInBrackets)*;
MapCreation:
LEFT_SQUARE_BRACE mapPart+=MapCreationPart (',' mapPart+=MapCreationPart)* RIGHT_SQUARE_BRACE;
TupleValueMember:
(name=ValuableID ASSIGNMENT)? value=Expression;
TableNameWithAlias:
ClassRefDecl:
JustNameDecl:
MethodCall:
name=MethodName ((listSpec=ListSpecification | mapSpec=MapSpecification)?) arguments=ArgumentsInBrackets;
OperationQueryOFunctionCall:
(name=[Query] | name=[Operation] | name=[Function]) arguments=ArgumentsInBrackets;
Arguments:
listPart+=Expression (',' listPart+=Expression)*;
ArgumentsInBrackets:
LEFT_BRACKET arguments=Arguments? RIGHT_BRACKET;
MethodName:
EMBEDDED_METHOD;
AccessToList:
LEFT_SQUARE_BRACE expr=Expression RIGHT_SQUARE_BRACE;
Expression:
or=Or;
Comparison ({Equality.left=current} op=(EQUALS | NOT_EQUALS | EQUALSS | NOT_EQUALSS)
right=Comparison)*;
PlusOrMinus ({Comparison.left=current} op=(MORE_EQUAL | LESS_EQUAL | MORE | LESS | IN)
right=MulOrDiv)*;
Primary ({MulOrDiv.left=current} op=(MulChar | DivChar | Percent)
right=Primary)*;
DotValue;
UnaryOperation:
prefixChar=(PlusChar | MinusChar | MulChar | DivChar | NOT) expression=Primary;
ExprInBrackets:
(LEFT_BRACKET expr=Expression RIGHT_BRACKET);
DotValue:
atom=Atomic (accesToList=AccessToList?) ((DOT dotPart=DotValue)?);
{ExprInBrackets} value=ExprInBrackets
| {UnaryOperation} value=UnaryOperation
{BoolConstant} value=('true' | 'false') |
{SelectOp} value=AtOperator |
{CreateAtom} value=Create
| {TupleRes} value=TupleValue
| {ListCreation} value=ListCreation
| {MapCreation} value=MapCreation
| {OneParamMethodCall} value=OneParamMethodCall
| {TwoParamsMethodCall} value=TwoParamsMethodCall
| {MultiParamsMethodCall} value=MultiParamsMethodCall
| {MethodCall} value=MethodCall
| {OperationQueryOFunctionCall} value=OperationQueryOFunctionCall
| {CreateClassPart} value=CreateClassPart
| {VariableDeclarationRef} value=VariableDeclarationRef;
MapCreationPart:
RelAttrubutesList:
TupleVarDeclaration:
(name=ValuableID DOUBLE_QUOTE)? type=TypeReference;
TypeReference:
type=PrimitiveType | entityType=[ClassDefinition] | tuple=TupleType | list=ListType | set=SetType | map=MapType;
ListType:
List ListSpecification;
SetType:
Set ListSpecification;
MapType:
Map MapSpecification;
ListSpecification:
LESS listType=TypeReference (QuestionChar?) MORE (QuestionChar?);
MapSpecification:
LESS keySpec=TypeReference (QuestionChar?) ',' valSpec=TypeReference (QuestionChar?) MORE;
TupleType:
LEFT_BRACKET varDecl+=TupleVarDeclaration (QuestionChar?) (',' varDecl+=TupleVarDeclaration (QuestionChar?))*
RIGHT_BRACKET;
OneParamMethodCall:
methodName=ONE_PARAM_METHOD LEFT_BRACKET arg=Expression RIGHT_BRACKET;
TwoParamsMethodCall:
methodName=TWO_PARAMS_METHOD LEFT_BRACKET arg1=Expression ',' arg2=Expression RIGHT_BRACKET;
MultiParamsMethodCall:
methodName=MULTI_PARAMS_METHOD args=ArgumentsInBrackets;
PrimitiveType:
Text | Tuid | Pubkey | Name | Timestamp | Integer | Json | ByteArray | Boolean;
ValuableID:
PrimitiveType | ID;
AmpersandModificator:
PlusChar | MulChar | QuestionChar;
IntWithMinus:
MinusChar? INT;
Name:
'name';
Pubkey:
'pubkey';
Timestamp:
'timestamp';
Tuid:
'tuid';
Boolean:
'boolean';
Json:
'json';
Integer:
'integer';
Text:
'text';
ByteArray:
'byte_array';
List:
'list';
Map:
'map';
Set:
'set';
Key:
'key';
Index:
'index';
Mutable:
'mutable';
Var:
'var';
Val:
'val';
Ampersand:
QuestionChar:
PlusChar:
MinusChar:
MulChar:
DivChar:
Percent:
EMBEDDED_METHOD:
"add" | "addAll" | "contains" | "containsAll" | "removeAll" | "calculate" | "sub" | "size" |
"removeAt" | "clear" | "requireNotEmpty" | "upperCase" | "lowerCase" | "_map" | "map" | "_list" | "list" | "set" |
"_set" | "empty" | "get" |
"str" | "put" | "putAll" | "remove" | "keys" | "values";
ONE_PARAM_METHOD:
'abs' | 'is_signer' | 'json';
TWO_PARAMS_METHOD:
'max' | 'min';
MULTI_PARAMS_METHOD:
'log' | 'print';
terminal IN:
'in';
terminal RIGHT_SQUARE_BRACE:
terminal LEFT_SQUARE_BRACE:
terminal RIGHT_BRACE:
terminal LEFT_BRACE:
terminal RIGHT_BRACKET:
terminal LEFT_BRACKET:
terminal NOT:
'not';
terminal DIV_ASSGIN:
terminal MUL_ASSGIN:
terminal PLUS_ASSGIN:
terminal MINUS_ASSGIN:
terminal EQUALS:
terminal EQUALSS:
terminal NOT_EQUALS:
terminal NOT_EQUALSS:
terminal MORE_EQUAL:
terminal LESS_EQUAL:
terminal MORE:
terminal LESS:
terminal NULL:
'null';
terminal DOT:
| 'E' | 'F';
FUDForum. Page generated in 2.13942 seconds
