Home » Eclipse Projects » Mosquitto » csr fails at https://test.mosquitto.org/ssl/(the method for creating a signed client certificate is no longer working)
csr fails at https://test.mosquitto.org/ssl/ [message #1803738] Thu, 07 March 2019 19:22 Go to next message
test dot mosquitto dot org/ssl/
certificate signing requests return a zero length client.crt file
this used to work correctly a month or two ago
without it, there is no way to test the client certificate option as describe at test dot mosquitto dot org
8884 : MQTT, encrypted, client certificate required
Re: csr fails at https://test.mosquitto.org/ssl/ [message #1803927 is a reply to message #1803738] Wed, 13 March 2019 13:51 Go to previous messageGo to next message
That should be fixed now, thanks for the note.
Re: csr fails at https://test.mosquitto.org/ssl/ [message #1803935 is a reply to message #1803927] Wed, 13 March 2019 16:58 Go to previous message
Thanks!
I'm able to test using cert and client cert/key (8884) again... Super important (to me) as this is what I am using with several LTE CAT M1/NB1 modem vendors to get their on board TLS/MQTT clients checked out.
[Updated on: Wed, 13 March 2019 16:58] by Moderator
Previous Topic:How can we configure the topic access for each device dynamically
Next Topic:Install location of mosquitto in Linux
Current Time: Sun Jul 20 23:29:24 EDT 2025
Powered by FUDForum. Page generated in 0.23912 seconds
