GEF5 Moving anchorage of anchored Connections performances [message #1798541] |
Tue, 20 November 2018 04:45  |
After investigating for performance problem with moving anchorage of several connections, we noticed that the checkCursor of ListListenerHelperEx in the bundle org.eclipse.gef.common was the sticky point.
We are using this version: Eclipse-SourceReferences: scm:git:https://github.com/eclipse/gef.git;path="org.eclipse.gef.common";commitId=51a73027b7d9c631d94e98b0ac97ff7a1e83f51e
We simply removed it and all its calls and did not noticed any error until now. Is it a good cure or is there any reason of this check we shoudn't ignore ?
Title [/Edit]
[Updated on: Tue, 20 November 2018 05:16] by Moderator
Re: GEF5 Moving anchorage of anchored Connections performances [message #1802539 is a reply to message #1798541] |
Mon, 11 February 2019 11:34   |
Hi Patrick,
thank you very much for sharing!
As far as I can see, it should be safe to remove the checks. Only in the case when a change is not correctly iterated, then you would get an exception if the checks are enabled.
I will investigate w.r.t. the performance implications. However, due to the anchor architecture, I believe in many cases, this change will not be sufficient to resolve performance issues. Nonetheless, I will discuss this change for GEF with a colleague and experiment with it, too.
Matthias
Re: GEF5 Moving anchorage of anchored Connections performances [message #1803734 is a reply to message #1803720] |
Thu, 07 March 2019 14:50  |
In addition to the changes aforementioned, I noticed that the OrthogonalRouter is responsible for much of the slowness. Have you ever noticed this?
If I remove:
visual.setRouter(new OrthogonalRouter());
from doCreateVisual() or replace it by
visual.setInterpolator(new PolylineInterpolator());
the gef app gets way more responsive. However, I really wanted to make Orthogonal Connections....
FUDForum. Page generated in 0.18347 seconds
