GEF Layer Priorities [message #180130] |
Tue, 03 May 2005 13:16  |
Originally posted by: dnawrocki.prologic-inc.com
I'm having trouble determining what order each layer handled (ie,
painting, mouse/keyboard events, etc). What I need to do is have a set of
handles on an edit part that scale up or down with the zoom manager. It
makes the most sense to me to add my handles to the SCALABLE_LAYERS layer
so that I don't have to dynamically resize the handles on zoom changes.
Am I getting myself into trouble by directly adding handles to the
SCALABLE_LAYERS instead of the HANDLE_LAYER? If other
handles/figures/connections happened to be on top of my handle, will the
other handle/figure/connection grab mouse events?
Re: GEF Layer Priorities [message #180346 is a reply to message #180339] |
Wed, 04 May 2005 11:23   |
The palette can be made very small. You can display icons only, and not use
any drawers, just groups.
BTW, it is possible for the editpart's figure itself to be a handle, or to
contain handles.
"Dan Nawrocki" <dnawrocki@prologic-inc.com> wrote in message
news:e933052f5fe5510add19e3317d5e83b2$1@www.eclipse.org...
> Randy Hudson wrote:
>> Why do you want handles to scale? Scalable_Layers is not a layer but a
>> group of layers. Only more layers should be added to it.
>> Usually, you want handles to be on top of everything else, or at least
>> the contents of diagram. Can you post more details?
> Sure. I am trying to come up with a schematic editor (think Simulink). I
> would like the user to be able to create connections by moving the mouse
> over a block's input/ouput "port", clicking, and dragging to a new
> location. When the user zooms in, the figure becomes bigger and I need
> the area that can start a new connection to be bigger to compensate.
> I've already implemented it and it seems to work OK. I tried adding the
> handles to the primary layer but they seemed to be hidden behind the other
> figures. Is there a way to specify the z-order of figures in a layer?
> That should also give me the needed functionality.
> BTW, I'm doing this so that I don't have a palette showing - my
> application's usage doesn't justify the screen real estate for one.
Re: GEF Layer Priorities [message #180373 is a reply to message #180350] |
Wed, 04 May 2005 15:20  |
Hmm, maybe I spoke too soon. That bug has not been fixed, but is is
possible to override findHandleAt() in GraphicalViewerImpl (or subclass),
and get the behavior you want.
news:073ded9e78fbcd6377f8c73f63eeac60$1@www.eclipse.org...
>> use any drawers, just groups.
> Interesting...I didn't know this. May look into it in the future.
>> to contain handles.
> That's the more correct solution I was looking for. The way I did it
> before really felt hackish. Thanks!
FUDForum. Page generated in 0.06333 seconds
