Home » Eclipse Projects » Kura » Kura eclipse emulator and DS activation problems
Kura eclipse emulator and DS activation problems [message #1803237] Mon, 25 February 2019 09:28 Go to next message
I have a problem with running kura and other bundles in eclipse - when i start the emulator, many services are activated then deactivated, then activated again. This does not seem to happen when i deploy the same bundles in a kura instance running on a raspberry pi.
Is it possible that there are some configurations in "org.eclipse.kura.emulator" that might influence this behavior?
There is also a problem with dynamic, multiple references, as they get bound to a list, but then are all unbound from the list during the startup only. This also seem to only happen on the eclipse kura emulator.
Re: Kura eclipse emulator and DS activation problems [message #1803336 is a reply to message #1803237] Wed, 27 February 2019 00:54 Go to previous messageGo to next message
Ok, so it seems when you pass an int argument to the deactivator method, it tells you about the reason the service/component was deactivated:
0 - unspecified
1 - The component was disabled
2 - A reference became unsatisfied
3 - A configuration was changed
4 - A configuration was deleted
5 - The component was disposed
I figured out that one of the services was a configurable component and it's being modified, so all it's clients get restarted as well. For the other one i'm getting "0", so the problem is unspecified.
The dynamic reference bind problem disappeared when i changed the class from service to a simple component. Not sure why that would do anything, since on further inspection the service was not being used by anyone, but at least that seems to help.
[Updated on: Wed, 27 February 2019 00:59] by Moderator
Re: Kura eclipse emulator and DS activation problems [message #1803479 is a reply to message #1803336] Fri, 01 March 2019 06:13 Go to previous message
thank you for the update.
Matteo
Previous Topic:PTC Thingworx
Next Topic:Avoid DataService store
Current Time: Sun Jul 27 09:44:28 EDT 2025
Powered by FUDForum. Page generated in 0.24522 seconds
