Eclipse error on startup. Linux Mint. [message #1803174] |
Sun, 24 February 2019 14:20  |
Hi, I don't know how to open eclipse. I keep getting an error. Here is the log https://gist.github.com/adabo/ed272831d54e4515d0f9643ba49c06a2
I'm running linux mint 19 btw.
I've tried installing through software manager and through installer from elipse.org
Commandline after eclipse -clean: OpenJDK 64-Bit Server VM warning: Ignoring option MaxPermSize; support was removed in 8.0
Oddly enough, eclipse did actually run after the installer setup. But has not opened since.
The files:
eclipse.ini: #This configuration file was written by: org.eclipse.oomph.p2.internal.core.AgentImpl
#Sun Feb 24 10:43:56 CST 2019
eclipse.product=org.eclipse.platform.ide
osgi.splashPath=file\:/home/abel/.p2/pool/plugins/org.eclipse.platform_4.10.0.v20181206-0815
org.eclipse.equinox.simpleconfigurator.configUrl=file\:org.eclipse.equinox.simpleconfigurator/bundles.info
osgi.bundles.defaultStartLevel=4
eclipse.application=org.eclipse.ui.ide.workbench
osgi.instance.area.default=@user.home/workspace
osgi.bundles=reference\:file\:org.eclipse.equinox.simpleconfigurator_1.3.200.v20181101-1115.jar@1\:start
eclipse.p2.data.area=file\:/home/abel/.p2/
eclipse.p2.profile=_home_abel_eclipse_cpp-2018-12_eclipse
osgi.framework=file\:/home/abel/.p2/pool/plugins/org.eclipse.osgi_3.13.200.v20181130-2106.jar
osgi.framework.extensions=reference\:file\:org.eclipse.osgi.compatibility.state_1.1.300.v20181116-1550.jar
eclipse.buildId=4.10.0.I20181206-0815
config.ini: -startup
plugins/org.eclipse.equinox.launcher_1.5.200.v20180922-1751.jar
--launcher.library
/home/abel/.p2/pool/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.900.v20180922-1751
-product
org.eclipse.epp.package.cpp.product
-showsplash
org.eclipse.epp.package.common
--launcher.defaultAction
openFile
--launcher.appendVmargs
-vm
/usr/lib/jvm/java-11-openjdk-amd64/bin
-vmargs
-Dosgi.requiredJavaVersion=1.8
-Dosgi.instance.area.default=@user.home/eclipse-workspace
-XX:+UseG1GC
-XX:+UseStringDeduplication
--add-modules=ALL-SYSTEM
-Dosgi.dataAreaRequiresExplicitInit=true
-Xms256m
-Xmx1024m
-Declipse.p2.max.threads=10
-Doomph.update.url=http://download.eclipse.org/oomph/updates/milestone/latest
-Doomph.redirection.index.redirection=index:/->http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/
error log: !SESSION Sun Feb 24 11:05:05 CST 2019 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2019-02-24 11:05:05.610
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
at java.base/java.net.URLClassLoader.findClass(URLClassLoader.java:466)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:566)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:626)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Steps I've tried:
- stack overflow: link removed
- Tried sudo apt-get install --reinstall libequinox-osgi-java
- java -d32 -version:
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
- java -d64 -version:
Really appreciate any suggestions and assitance. Thanks.
FUDForum. Page generated in 0.09706 seconds
