Home » Newcomers » Newcomers » Another Eclipse update problem... (An error occurred while collecting items to be installed)
Another Eclipse update problem... [message #1802829] Sun, 17 February 2019 12:32 Go to next message
Another typical eclipse problem: when starting up my Photon installation I get an indication that updates are available. I click that popup and select the two available updates, accept the license and hit ok (or update?) - and what do I get?
Error updating software:
session context was:(profile=U__eclipse_dev_photon_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.epp.mpc.core,1.7.4.v20190206-1730
No repository found containing: osgi.bundle,org.eclipse.epp.mpc.core.win32,1.7.4.v20190206-1730
No repository found containing: osgi.bundle,org.eclipse.epp.mpc.help.ui,1.7.4.v20190206-1730
No repository found containing: osgi.bundle,org.eclipse.epp.mpc.ui,1.7.4.v20190206-1749
No repository found containing: osgi.bundle,org.eclipse.epp.mpc.ui.css,1.7.4.v20190206-1730
No repository found containing: org.eclipse.update.feature,org.eclipse.epp.mpc,1.7.4.v20190206-1749
I installed Photon using the eclipse installer by Oomph.
What am I missing? How do I get this thing to update itself?
[Updated on: Sun, 17 February 2019 12:42] by Moderator
Re: Another Eclipse update problem... [message #1803286 is a reply to message #1802829] Tue, 26 February 2019 05:11 Go to previous messageGo to next message
If you have older version of market place client installed already, then you can update it by opening it and click on the update link. If no update link, then search for Marketplace. It took me 2 weeks to find this.
If you don't have it installed, then you can install it first from 2018-09
repository(General tools) - it is v. 1.7.2. And after update it with the trick from above
Re: Another Eclipse update problem... [message #1803381 is a reply to message #1803286] Wed, 27 February 2019 10:25 Go to previous messageGo to next message
Sorry - I don't understand what you are saying here. This was an update attempt not of or via the market place but via the "traditional" Check for Updates. But automatic updating has been a major eclipse nightmare since years now!
Re: Another Eclipse update problem... [message #1803717 is a reply to message #1803381] Thu, 07 March 2019 08:34 Go to previous messageGo to next message
If you have marketplace installed, open it, and the first item should be the marketplace, with a handy update button.
Click on that. finish, and the update is applied correctly.
I got exactly the same errors as you did via standard Eclipse software update.
Re: Another Eclipse update problem... [message #1804003 is a reply to message #1803717] Fri, 15 March 2019 07:34 Go to previous messageGo to next message
More crystal clear explanation than this is impossible. Tks very much.
Re: Another Eclipse update problem... [message #1804341 is a reply to message #1802829] Fri, 22 March 2019 12:19 Go to previous messageGo to next message
Thanx Iliya, this tipp really helped!!!
[Updated on: Fri, 22 March 2019 12:20] by Moderator
Re: Another Eclipse update problem... [message #1810431 is a reply to message #1804341] Sun, 11 August 2019 09:24 Go to previous messageGo to next message
Coming back to this:
I may be crystal clear to others but not to me. When I open Marketplace I get the following:
index.php/fa/36080/0/
Where is here that mentioned "update button"? Pardon my ignorance - and maybe I should see an optician - but I can't see any here!
And the other point I still don't see: I hadn't been trying to update anything I had installed via marketplace but the basic Eclipse installation (Eclipse for Java developers). Why should I see marketplace for this?
[Updated on: Sun, 11 August 2019 09:31] by Moderator
Re: Another Eclipse update problem... [message #1810436 is a reply to message #1810431] Mon, 12 August 2019 00:27 Go to previous messageGo to next message
Updates can be done manually with Help -> Check for Updates (and automatic updates are just doing that automatically) Updates can fail depending on what software sites are listed under Window -> Preferences -> Install/Update -> Available Software sites. The things you install can automatically add to this list (via touch points in their installable units) and marketplace client (MPC) unfortunately added such a site that was modified to point at a newer version and that newer version could not be installed in the older version of Eclipse where the original older version of MPC was installed. (Or the version you had installed is no longer in that site they added.)
Re: Another Eclipse update problem... [message #1821795 is a reply to message #1803286] Thu, 20 February 2020 05:07 Go to previous messageGo to next message
Thanks a ton! for suggesting this.
It was a problem I was facing since long without any clue of how to rectify it.
Your resolution steps works as charm and I was able to update my eclipse version.
Thanks!! again.
Re: Another Eclipse update problem... [message #1822472 is a reply to message #1802829] Sat, 07 March 2020 13:18 Go to previous messageGo to next message
It works! Thank you.
Re: Another Eclipse update problem... [message #1823004 is a reply to message #1810436] Tue, 17 March 2020 21:23 Go to previous messageGo to next message
First, thanks to @Ed Merks for bothering to spend the time entering a more detailed description than just "it's obvious".
Just to be certain, my understanding of the issue (and resolution) is as follows:
-MarketPlace Client (MPC) added a reference to an update site to my/our Eclipse installation
-That update site was not being handled properly by the normal Eclipse update method
-The solution is to first update your MPC version, THEN re-do the Eclipse update.
Does this sound about right?
Re: Another Eclipse update problem... [message #1823009 is a reply to message #1823004] Wed, 18 March 2020 01:58 Go to previous message
Yes, that sounds about right. There was a long thread on this topic:
https://www.eclipse.org/lists/cross-project-issues-dev/msg17494.html
The underlying case was determined to be that MPC added the content metadata repository automatically but it did not add the artifact metadata repository automatically.
Previous Topic:Updated documentation for GitHub integration (HTTPS) on windows 10
Next Topic:Replacement for IPluginDescriptor
Current Time: Mon Sep 01 01:23:56 EDT 2025
Powered by FUDForum. Page generated in 0.15688 seconds
