Kura eclipse emulator and DS activation problems [message #1803237] |
Mon, 25 February 2019 09:28  |
I have a problem with running kura and other bundles in eclipse - when i start the emulator, many services are activated then deactivated, then activated again. This does not seem to happen when i deploy the same bundles in a kura instance running on a raspberry pi.
Is it possible that there are some configurations in "org.eclipse.kura.emulator" that might influence this behavior?
There is also a problem with dynamic, multiple references, as they get bound to a list, but then are all unbound from the list during the startup only. This also seem to only happen on the eclipse kura emulator.
FUDForum. Page generated in 0.03251 seconds
