Home » Eclipse Projects » Eclipse Titan » regarding mctr_cli(mctr_cli)
regarding mctr_cli [message #1803081] Thu, 21 February 2019 19:12 Go to next message
Hi Elemer,
I have a query regarding the ttcn3_start executable. The command works perfectly find in an ubuntu server, if we login and start it from the server directly.
But when i tried to remote login via SSH command and tried giving the same command it did not work saying that TTCN3_DIR environment variable is not set and it gave an error pointing to Line:190 of TTCN3_start script.
The code at this place seems to be like below:# Checking TTCN3_DIR environment variable and setting mctr_cli
if {[info exists env(TTCN3_DIR)]} {
set mctr $env(TTCN3_DIR)/bin/mctr_cli
} else {
puts "ttcn3_start: warning: TTCN3_DIR environment variable is not set"
set mctr mctr_cli
Here it fails on the first check and tries to enter the else part and fails saying that "mctr_cli" is not available. When i give the full path like /opt/TTCN3/bin/mctr_cli in the else part it starts working.
I am not sure what is the difference between the If part and the else part if we end up doing the same thing on both?
Can you clarify?
Mohan Raj
Re: regarding mctr_cli [message #1803086 is a reply to message #1803081] Fri, 22 February 2019 02:44 Go to previous message
Hi Mohan,
you should find the answer in the stackoverflow post below:
https://stackoverflow.com/questions/216202/why-does-an-ssh-remote-command-get-fewer-environment-variables-then-when-run-man
Best regards
Elemer
Previous Topic: Data Type Conversion
Next Topic:The version of the compiler could not be determined
Current Time: Sun Jul 20 20:35:05 EDT 2025
Powered by FUDForum. Page generated in 0.08090 seconds
