regarding mctr_cli [message #1803081] |
Thu, 21 February 2019 19:12  |
Hi Elemer,
I have a query regarding the ttcn3_start executable. The command works perfectly find in an ubuntu server, if we login and start it from the server directly.
But when i tried to remote login via SSH command and tried giving the same command it did not work saying that TTCN3_DIR environment variable is not set and it gave an error pointing to Line:190 of TTCN3_start script.
The code at this place seems to be like below:# Checking TTCN3_DIR environment variable and setting mctr_cli
if {[info exists env(TTCN3_DIR)]} {
set mctr $env(TTCN3_DIR)/bin/mctr_cli
} else {
puts "ttcn3_start: warning: TTCN3_DIR environment variable is not set"
set mctr mctr_cli
Here it fails on the first check and tries to enter the else part and fails saying that "mctr_cli" is not available. When i give the full path like /opt/TTCN3/bin/mctr_cli in the else part it starts working.
I am not sure what is the difference between the If part and the else part if we end up doing the same thing on both?
Can you clarify?
Mohan Raj
FUDForum. Page generated in 1.55957 seconds
