Home » Modeling » TMF (Xtext) » [Formatter2] append newLine + spaces
[Formatter2] append newLine + spaces [message #1803049] Thu, 21 February 2019 08:20 Go to next message
Hi all,
I am trying to achieve alignment with list opening bracket, but I can't.
Here is how I am trying:
Grammar:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
DSL returns XTDSL:
	models+=Model*
Model returns XTModel:
	{XTModel} 'startList' '(' greetings+=Greeting*')'';';
Greeting returns XTGreeting:
	'list' ids_list=identifier_list ':' 'endlist' ';';
identifier_list returns XTIdentifierList:
	ids+=identifier (',' ids+=identifier)*
identifier returns XTIdentifier:
	{XTIdentifier} ID
Formatter:
	def dispatch void format(XTDSL xtdsl, extension IFormattableDocument document) {
		xtdsl.models.forEach[format]
	def dispatch void format(XTModel xtmodel, extension IFormattableDocument document) {
		xtmodel.greetings.forEach[format; append[newLine]]
		xtmodel.regionFor.keyword("startList").append[oneSpace]
		xtmodel.regionFor.keyword("(").append[newLine]
		xtmodel.regionFor.keyword(")").prepend[noSpace]
		xtmodel.regionFor.keyword(";").prepend[noSpace]
		xtmodel.append[newLine]
		alignGreetingsOnOpenBracket(xtmodel.greetings, document)
	def void alignGreetingsOnOpenBracket(EList<XTGreeting> greetings, extension IFormattableDocument document) {
		val precedingString = "startList ("
		for (greeting : greetings) {
			greeting.prepend[space = Strings.repeat(" ", precedingString .length); highPriority]
What happens is:
startList (
list A : endlist;
list B : endlist;
list C : endlist;
While I expect:
startList (
           list A : endlist;
           list B : endlist;
           list C : endlist;
Why does append[newLine] result in ignoring any spaces added after (newLine = newLine and spaces ignored)?
I know that I can use interior[indent], but that would result in indenting using whatever tab width is set, which is not necessarily going to match the width of "startList (".
[Updated on: Sun, 24 February 2019 05:39] by Moderator
Re: [Formatter2] append newLine + spaces [message #1803055 is a reply to message #1803049] Thu, 21 February 2019 09:07 Go to previous messageGo to next message
Please use the indent feature to implement
Indentations
Re: [Formatter2] append newLine + spaces [message #1803161 is a reply to message #1803055] Sun, 24 February 2019 05:37 Go to previous messageGo to next message
I know that I am supposed to use the indent feature.
But the indent feature uses the tab width set by the user.
I want to be able to set the indent width for each type of list to match the (list type + space + open bracket) width.
For example:
greetingsList (
               greeting g1;
               greeting g2;
asdList (
         asd a1;
         asd a2;
You get me?
[Updated on: Sun, 24 February 2019 05:38] by Moderator
Re: [Formatter2] append newLine + spaces [message #1803162 is a reply to message #1803161] Sun, 24 February 2019 05:44 Go to previous messageGo to next message
did you have a look at the example here:
https://de.slideshare.net/meysholdt/xtexts-new-formatter-api
(Page 139)
[Updated on: Sun, 24 February 2019 06:08] by Moderator
Re: [Formatter2] append newLine + spaces [message #1803165 is a reply to message #1803162] Sun, 24 February 2019 08:45 Go to previous messageGo to next message
Well, yes I have.
But that's not what I am talking about I guess.
If I understand correctly, the slide you are talking about adjusts the space width before the '=>' not before each transition (which is what I need).
The slide controls this part (*):
state baz
     1***=> foo;
     12**=> foo;
     123*=> foo;
end
I want to control this part (*):
state baz
*****1   => foo;
*****12  => foo;
*****123 => foo;
end
Let's say my grammar has states and has lists containing transitions. I would like to have the following result:
state baz
*****1   => foo;
*****12  => foo;
*****123 => foo;
end
list bar
****1   => foo;
****12  => foo;
****123 => foo;
end
Am I clear?
Re: [Formatter2] append newLine + spaces [message #1803170 is a reply to message #1803165] Sun, 24 February 2019 10:45 Go to previous messageGo to next message
this looks like a bug to me.
workaround:
def dispatch void format(XTModel xTModel, extension IFormattableDocument document) {
for (xTGreeting : xTModel.greetings) {
xTGreeting.regionFor.keyword("list").prepend[space = "\n "]
alternative solution:
https://stackoverflow.com/questions/45305293/how-to-define-different-indentation-levels-in-the-same-document-with-xtext-forma
can you please create a ticket at github.com/eclipse/xtext-core
Re: [Formatter2] append newLine + spaces [message #1805252 is a reply to message #1803170] Wed, 10 April 2019 08:23 Go to previous messageGo to next message
Done here https://github.com/eclipse/xtext-core/issues/1069.
Re: [Formatter2] append newLine + spaces [message #1837196 is a reply to message #1803049] Sun, 24 January 2021 09:29 Go to previous message
Instead adding spaces after the newline you can add spaces before the list keyword of the lines supposed to be indented.
Previous Topic:Using FQN rule in reference rules does not work as expexcted.
Next Topic:Strange Error Message - no clue what is wrong
Current Time: Mon Jul 21 00:26:49 EDT 2025
Powered by FUDForum. Page generated in 0.25507 seconds
