Home » Newcomers » Newcomers » Trouble Running Oomph Installer(I get redirected to a side that tells me, it did`t find a jre.)
Trouble Running Oomph Installer [message #1802799] Sat, 16 February 2019 05:32 Go to next message
So I wanted to get into java-Programming a little more, and since I have some previous expierience with eclipse, I figured I would use it.
I installed both the Java JDK 8.201 and JRE 8.201, without changing their default installation location. I went to modifying the Path Variable of my System (I am running Win10) and put in the following:
C:\Program Files (x86)\Java\jdk_1.8_201\bin
C:\Program Files (x86)\Java\jre_1.8_201\bin
I checked in the CMD if my PC would recognise them by typing "java" and "javac", and for both, it showed me their commands.
But when I then ran the Oomph installer it redirected me to here:
https://download.eclipse.org/oomph/jre/index-handler.php?vm=1_1_7_0_64_0&pn=Eclipse%20Installer&pu=http://wiki.eclipse.org/Eclipse_Installer&pi=http://download.eclipse.org/oomph/jre/128x128.png
If you need anymore information about my issue, feel free to ask.
I thank you sincerely for trying to help me.
Re: Trouble Running Oomph Installer [message #1802813 is a reply to message #1802799] Sat, 16 February 2019 23:46 Go to previous messageGo to next message
The location of your Java installation makes it clear you installed a 32 bit version of Java. But you downloaded the 64 bit version of the installer. I would highly recommend you install the latest 64 bit version of Java 8 because that version can run any older and newer version of the installer and any older and newer version of the Eclipse applications you install.
Re: Trouble Running Oomph Installer [message #1802820 is a reply to message #1802813] Sun, 17 February 2019 04:18 Go to previous messageGo to next message
So, on this site: https://www.oracle.com/technetwork/java/javase/downloads/jre8-downloads-2133155.html
I have to download "jre-8u201-windows-x64.exe" instead of "jre-8u201-windows-i586.exe" ?
Re: Trouble Running Oomph Installer [message #1802822 is a reply to message #1802820] Sun, 17 February 2019 06:44 Go to previous messageGo to next message
Yes, exactly.
Re: Trouble Running Oomph Installer [message #1802825 is a reply to message #1802820] Sun, 17 February 2019 10:02 Go to previous message
Thank you. It works now.
Previous Topic:Eclipse 2018-12 is saying "No jres found" for JDK 11?
Next Topic:I found something what seems different very strange
Current Time: Mon Jul 21 03:29:55 EDT 2025
Powered by FUDForum. Page generated in 0.13405 seconds
