Home » Newcomers » Newcomers » [SOLVED] Eclipse failed to launch workspace
[SOLVED] Eclipse failed to launch workspace [message #1802540] Mon, 11 February 2019 12:00 Go to next message
When I want to launch any workspace (even an empty one), Eclipse tells me that it can't launch it with an error in a log file. The error in my terminal is
org.eclipse.m2e.logback.configuration: Logback config file: /home/emilien/data/Scoopf/geo/.metadata/.plugins/org.eclipse.m2e.logback.configuration/logback.1.10.0.20181127-2120.xml
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [bundleresource://704.fwk825496893:1/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [bundleresource://704.fwk825496893:2/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
SLF4J: Actual binding is of type [ch.qos.logback.classic.util.ContextSelectorStaticBinder]
org.eclipse.m2e.logback.configuration: Initializing logback
And the log file is attached.
I also tried to remove the plugins directories, but it's the same.
If anyone can help me it would be very nice!
Thanks in advance,
Emilien
[Updated on: Tue, 12 February 2019 08:50] by Moderator
Re: Eclipse failed to launch workspace [message #1802552 is a reply to message #1802540] Mon, 11 February 2019 14:27 Go to previous messageGo to next message
It looks like you'll need to run Eclipse with an earlier JDK (this does not affect coding for Java 11). Some of what you have installed is not compatible with running under JDK11.
Re: Eclipse failed to launch workspace [message #1802597 is a reply to message #1802552] Tue, 12 February 2019 08:50 Go to previous message
Re,
Thanks for reply it now run with the Java 10 (OpenJdk), I tried with the 11 both Oracle and OpenJdk but it didn't work.
Thanks a lot!
Previous Topic:completely new to java, not new to coding
Next Topic:Debugging - Eclipse PTP: cannot open file /usr/local/bin/routes_379c55d4-f04f-4c89-860f-6111983f3f35
Current Time: Sun Jul 20 22:51:35 EDT 2025
Powered by FUDForum. Page generated in 0.33772 seconds
