Home » Newcomers » Newcomers » Eclipse 2018-12 is saying "No jres found" for JDK 11?(Eclipse does not detect jre in JDK 11)
Eclipse 2018-12 is saying "No jres found" for JDK 11? [message #1802472] Sun, 10 February 2019 03:05 Go to next message
Eclipse 2018-12 is saying "No jres found" in JDK 11?
[Updated on: Sun, 10 February 2019 03:07] by Moderator
Re: Eclipse 2018-12 is saying "No jres found" for JDK 11? [message #1802494 is a reply to message #1802472] Sun, 10 February 2019 23:20 Go to previous messageGo to next message
Can you give more details?
Re: Eclipse 2018-12 is saying "No jres found" for JDK 11? [message #1802505 is a reply to message #1802494] Mon, 11 February 2019 03:46 Go to previous messageGo to next message
Go to Window-->Preferences-->Java-->Installed JREs, then click the Search button, select the JDK-11.0.2 home directory. An information box with a progress bar will open, and eventually will display a message that says No JREs found in JDK11
Re: Eclipse 2018-12 is saying "No jres found" for JDK 11? [message #1802622 is a reply to message #1802505] Tue, 12 February 2019 17:22 Go to previous messageGo to next message
What's "the JDK-11.0.2 home" directory? What happens if you search from above it, or try to add that directory itself directly?
Re: Eclipse 2018-12 is saying "No jres found" for JDK 11? [message #1802809 is a reply to message #1802622] Sat, 16 February 2019 21:20 Go to previous message
I tried to do what's described at https://help.eclipse.org/2018-12/index.jsp?topic=%2Forg.eclipse.jdt.doc.user%2FgettingStarted%2Fqs-2.htm&cp=1_1_0_0. There is said "To do so, simply click the Search... button and specify a root folder for the search. " to do.
What I meant JDK-11.0.2 home directory is the JDK-11, root directory, the main directory in which all the other files of JDK-11 are placed.
In Windows, it's C:\Program Files\Java\jdk-11.0.2
What do you mean by "above it"?. Do you mean by going through the search button and selecting the JDK-11 home directory? Well, that's what I have done.
By using the add button and selecting the JDK-11 home directory, adds JDK-11 to the list of Installed list of JREs
[Updated on: Sat, 16 February 2019 21:42] by Moderator
Previous Topic:Importing a project with git-lfs fails with git-lfs not found error
Next Topic:Trouble Running Oomph Installer
Current Time: Thu Jul 31 13:28:56 EDT 2025
Powered by FUDForum. Page generated in 0.10134 seconds
