Suuggestion for Human Machine Interface Software companion with 4DIAC [message #1802448] |
Fri, 08 February 2019 23:49  |
Dear All
I need help for my project. I try to develop physical model for Coal Mill using 4DIAC IDE. At now i try to coding the FB with structure list (ST) so i can made it very compact and more custom.
But i need suggestion for picking software which could act like SCADA system that provide Data Access(DA), Alarm Event (AE), Historical Data (HD), and Build HMI. I've try to use EclipseNeoScada for several month, I did it good for DA purpose, but get stuck when i try to utilize AE and HD. There is unavailable tutorial from the developer. it's just some summary about the structure of the SCADA Software.
Also i think about using scadaBR for replacing it, but the language is not in english, (im Indonesian btw) i think it will consume more time if continuing with scadaBR.
Could you please (4DIAC Developer) suggest me some SCADA softwares compatible to 4DIAC so i can make HMI etc (something like in the image), with enough source for tutorial how to use the software?
Thank you
image source : http://www.elimko.com.tr/tr/sistem/referanslar-1/cimento-sanayii-cement-industry/yibitas-lafarge-corum-cement-factory
Attachment: HMI.PNG
(Size: 104.25KB, Downloaded 227 times)
FUDForum. Page generated in 0.04297 seconds
