Parsing error:coudn't reslolve reference [message #1802125] |
Fri, 01 February 2019 10:27  |
Hi all, I have validation error on the following string (see my grammar bellow)
class test {a: text; b: text; c : text; key a; index b; }
operation createTest() {
create test(a = 'akey', b = 'btext', c = 'ctext');
Quote:java.lang.AssertionError: Expected no errors, but got :ERROR (org.eclipse.xtext.diagnostics.Diagnostic.Linking) 'Couldn't resolve reference to VariableDeclaration 'a'.' on CreateWhatPart, offset 99, length 1
ERROR (org.eclipse.xtext.diagnostics.Diagnostic.Linking) 'Couldn't resolve reference to VariableDeclaration 'b'.' on CreateWhatPart, offset 111, length 1
ERROR (org.eclipse.xtext.diagnostics.Diagnostic.Linking) 'Couldn't resolve reference to VariableDeclaration 'c'.' on CreateWhatPart, offset 124, length 1
But why as I really have the variable declarations?
My grammar is
grammar org.blockchain.rell.Rell with org.eclipse.xtext.common.Terminals
generate rell "http://www.blockchain.org/rell/Rell"
Model:
entities+=(ClassDefinition )*
operations+=(Operation )*;
ClassDefinition:
'class' name=ID ('extends' superType=[ClassDefinition])? '{'
attributeListField+=AttributeListField*
AttributeListField:
mutable=Mutable? key=Key? index=Index? attributeList+=RelAttrubutesList ';';
Operation:
"operation" name=ID "(" parameters=RelAttrubutesList? ")" "{" statements+=Statement* "}";
Statement:
(relation=Relational | variable=OperationVariable|varInitiation=VarInitiation) ';';
VarInitiation:
VariableDeclarationRef ('=' expression=Expression)?
OperationVariable:
assessModificator=(Var | Val) variable=Variable;
Variable:
name=VariableDeclaration (('=' expression=Expression)?);
Relational:
Create ;
Create:
'create' (entity=[ClassDefinition]) '(' (createWhatPart+=CreateWhatPart (','
createWhatPart+=CreateWhatPart)*)? ')';
CreateWhatPart:
(varDeclRef=[VariableDeclaration|ValuableID] '=')?
condition+=Expression;
TupleValue:
'(' members+=TupleValueMember (',' tuplePart+=TupleValueMember)* ')';
ListCreation:
'[' arguments=Arguments ']' ('.' LIST_METHOD listMethodArguments+=ArgumentsInBrackets)*;
MapCreation:
'[' mapPart+=MapCreationPart (',' mapPart+=MapCreationPart)* ']' ('.' MAP_METHOD listMethodArguments+=ArgumentsInBrackets)*
NewListCreation:
List {NewListCreation} (specification=ListSpecification?)
listCreation=ListCreation|
newListCreation=NewListCreation|
newSetCreation=NewSetCreation
')' ('.' LIST_METHOD arguments+=ArgumentsInBrackets)*;
NewMapCreation:
Map {NewMapCreation }specification=MapSpecification? '(' (creation=ListCreation?) ')' ('.' MAP_METHOD arguments+=Arguments )*;
NewSetCreation:
Set {NewSetCreation} (specification=ListSpecification?)
(listCreation=ListCreation|newListCreation=NewListCreation|newSetCreation=NewSetCreation)?
('.' LIST_METHOD arguments+=ArgumentsInBrackets )*;
TupleValueMember:
(name=ValuableID '=')? value=Expression;
ClassMemberDefinition:
(classRef=ClassRef)? "." variableDeclarationRef=VariableDeclarationRef;
ClassRef:
value=[TableNameWithAlias];
TableNameWithAlias:
{ClassRefDecl} (name=ID COLON classDef=[ClassDefinition]) |
{JustNameDecl} name=[ClassDefinition];
VariableDeclarationRef:
decl=[VariableDeclaration|ValuableID];
Arguments:listPart+=Expression (',' listPart+=Expression)*;
ArgumentsInBrackets: '(' {ArgumentsInBrackets} arguments=Arguments? ')';
Expression:
or=Or;
Or returns Expression:
And ({Or.left=current} "or" right=And)*;
And returns Expression:
Equality ({And.left=current} "and" right=Equality)*;
Equality returns Expression:
Comparison ({Equality.left=current} op=(EQUALS | NOT_EQUALS|EQUALSS|NOT_EQUALSS)
right=Comparison)*;
Comparison returns Expression:
PlusOrMinus ({Comparison.left=current} op=(MORE_EQUAL | LESS_EQUAL | MORE | LESS)
right=PlusOrMinus)*;
PlusOrMinus returns Expression:
MulOrDiv (({Plus.left=current} PlusChar | {Minus.left=current} MinusChar)
right=MulOrDiv)*;
MulOrDiv returns Expression:
Primary ({MulOrDiv.left=current} op=(MulChar | DivChar)
right=Primary)*;
Primary returns Expression:
'(' Expression ')' |
{Not} "not" expression=Primary |
Atomic;
Atomic returns Expression:
{IntConstant} value=IntWithMinus |
{StringConstant} value=STRING |
{ByteArrayConstant} value=BYTE_ARRAY_VALUE |
{BoolConstant} value=('true' | 'false') |
{MemberDefinition} value=ClassMemberDefinition |
{CreateAtom} value=Create
| {TupleRes} value=TupleValue
| {ListCreation} value=ListCreation
| {MapCreation} value=MapCreation
| {NewLCreation} value=NewListCreation
| {NewSCreation} value=NewSetCreation
| {NewMCreation} value=NewMapCreation
| {TheNull} value=NULL
|{VariableRef} value=VariableDeclarationRef;
MapCreationPart:exprKey=Expression COLON exprValue=Expression;
RelAttrubutesList:
value+=Variable (',' value+=Variable)*;
VariableDeclaration:
name=ValuableID ((COLON type=TypeReference)?);
TupleVarDeclaration:
(name=ValuableID COLON)? type=TypeReference;
TypeReference:
primitive=PrimitiveType | entityType=ClassType | tuple=TupleType | list=ListType|set=SetType|map=MapType;
ListType:
List ListSpecification;
SetType:
Set ListSpecification;
MapType:
Map MapSpecification;
ListSpecification:
LESS listType=TypeReference (QuestionChar?) MORE;
MapSpecification:
LESS keySpec=TypeReference (QuestionChar?) ',' valSpec=TypeReference (QuestionChar?) MORE;
TupleType:
'(' varDecl+=TupleVarDeclaration (',' varDecl+=TupleVarDeclaration)* ')';
ClassType:
type=[ClassDefinition];
PrimitiveType:
Text | Tuid | Pubkey | Name | Timestamp | Integer | Json | ByteArray | Boolean;
ValuableID:
PrimitiveType | ID;
AmpersandModificator:
PlusChar | MulChar | QuestionChar;
IntWithMinus:MinusChar? INT;
Name:
'name';
Pubkey:
'pubkey';
Timestamp:
'timestamp';
Tuid:
'tuid';
Boolean:
'boolean';
Json:
'json';
Integer:
'integer';
Text:
'text';
ByteArray:
'byte_array';
List:
'list';
Map:'map';
Set:
'set';
Key:
'key';
Index:
'index';
Mutable:
'mutable';
Var:
'var';
Val:
'val';
Ampersand:
QuestionChar:
PlusChar:
MinusChar:
MulChar:
DivChar:
LIST_METHOD:
"add"|"addAll"|"contains"|"containsAll"|"removeAll"|"calculate"|"sub"|"size"|"str"|"remove"|"removeAt"|"clear"|"empty"
MAP_METHOD:"empty"|"size"|"contains"|"get"|"str"|"clear"|"put"|"putAll"|"remove"|"keys"|"values";
//terminal SET_METHOD:LIST_METHOD;
terminal EQUALS:
terminal EQUALSS:
terminal NOT_EQUALS:
terminal NOT_EQUALSS:
terminal MORE_EQUAL:
terminal LESS_EQUAL:
terminal MORE:
terminal LESS:
terminal COLON:
terminal NULL:
'null';
terminal BYTE_ARRAY_CHAR:
'0' | '1' | '2' | '3' | '4' | '5' | '6' | '7' | '8' | '9' | 'a' | 'b' | 'c' | 'd' | 'e' | 'f' | 'A' | 'B' | 'C' | 'D'
| 'E' | 'F';
terminal BYTE_ARRAY_PAIR:
BYTE_ARRAY_CHAR BYTE_ARRAY_CHAR;
terminal BYTE_ARRAY_VALUE:
'x' (('\'' BYTE_ARRAY_PAIR* '\'') | ('"' BYTE_ARRAY_PAIR* '"'));
FUDForum. Page generated in 0.07828 seconds
