Home » Modeling » M2T (model-to-text transformation) » Installing Acceleo on Eclipse 2018-12(Installing Acceleo on Eclipse 2018-12)
Installing Acceleo on Eclipse 2018-12 [message #1801939] Tue, 29 January 2019 11:41 Go to next message
Environment Eclipse 2018-12 (modeling tools)- Java 10 - Windows 10:
Acceleo is not visible on market place for download. However, when I installed it through 'Install New Software' Menu, then examples are not installed. Question:- how to install examples. Hopefully, installed Acceleo 3.7.7 will be compatible with this environment ! Guidance please
Re: Installing Acceleo on Eclipse 2018-12 [message #1802154 is a reply to message #1801939] Sat, 02 February 2019 01:38 Go to previous messageGo to next message
I much prefer downloading and installing the full project ZIPs. (Never use the Marketplace for Eclipse Simultaneous Release components; the Marketplace does not instyall prerequisites automatocally.)
Unfortunately https://www.eclipse.org/acceleo/downloads/ is a 404, so I don't know what to recommend. https://bugs.eclipse.org/bugs/show_bug.cgi?id=544055 raised.
Ed Willink
Re: Installing Acceleo on Eclipse 2018-12 [message #1802155 is a reply to message #1802154] Sat, 02 February 2019 01:57 Go to previous messageGo to next message
Doh! Not thinking. You can fetch code from code https://git.eclipse.org/r/acceleo/org.eclipse.acceleo
or try installing from the Acce;eo-specific repo: http://download.eclipse.org/modeling/m2t/acceleo/updates/releases but that seems to be stale - nothing since 3.4.1 in 2013. https://bugs.eclipse.org/bugs/show_bug.cgi?id=544056 raised.
GIT seems your only official option for now.
I've found a 3.7.3 ZIP on my computer. You may access it for a few days from https://www.dropbox.com/s/xzicufryar5m8no/acceleo-update-3.7.3.zip?dl=0 It doesn't seem to install directly. Try downloading it to your disk then installing from your local copy.
Ed Willink
Re: Installing Acceleo on Eclipse 2018-12 [message #1802156 is a reply to message #1802155] Sat, 02 February 2019 02:38 Go to previous messageGo to next message
Thanks. 3 Examples Installed. However, while running the UML to Java Example it gives Error, that I am posting as new topic
Re: Installing Acceleo on Eclipse 2018-12 [message #1802409 is a reply to message #1802156] Fri, 08 February 2019 07:31 Go to previous messageGo to next message
Fixing https://bugs.eclipse.org/bugs/show_bug.cgi?id=543026 introduced me to some more Acceleo locations.
A 3.7.7 release with a fix for Bug 543026 is available from
https://ci.eclipse.org/acceleo/job/master-gerrit/1346/PLATFORM=platform-photon,jdk=jdk1.8.0-latest/artifact/releng/org.eclipse.acceleo-updatesite/target/org.eclipse.acceleo-3.7.7.201902081132.zip
Ed Willink
Re: Installing Acceleo on Eclipse 2018-12 [message #1802892 is a reply to message #1802409] Mon, 18 February 2019 09:42 Go to previous messageGo to next message
The Acceleo download page can be found through the acceleo website. As identified by Ed through bug 543026, the current latest is not compatible with 2018-12 because of EMF changes. The patch has been pushed to master and will be available in 2019-12.
Laurent Goubet
Obeo
Re: Installing Acceleo on Eclipse 2018-12 [message #1804875 is a reply to message #1802154] Tue, 02 April 2019 11:08 Go to previous message
https://www.eclipse.org/acceleo/download.html
works :)
as well as:
https://wiki.eclipse.org/Acceleo/Installation
Tomek
Previous Topic:Errors running builder 'Acceleo Builder'
Next Topic:Does the Acceleo model-to-text transformation support different kind of input models in .mtl file?
Current Time: Mon Jul 21 00:52:59 EDT 2025
Powered by FUDForum. Page generated in 0.04905 seconds
