Home » Eclipse Projects » Sirius » Table column derivation and if else(Table column derivation and ( if else))
Table column derivation and if else [message #1802151] Fri, 01 February 2019 22:52 Go to next message
When declaring derived attributes in my table it is working
and even when I'm using derived values whith (if else if else) the value computed is correcte but not displayed
What is the problem? :'(
should I use conditional background even if all is defined in the meta-model??????
Thanks in advance
[Updated on: Sat, 02 February 2019 21:13] by Moderator
Re: Table column derivation and if else [message #1802214 is a reply to message #1802151] Mon, 04 February 2019 05:57 Go to previous messageGo to next message
Hello
I can't seem to understand your issue.
Do you intend to display the value of aderived attribute(declared so in your meta-model) in a cell of a Sirius Table or Cross-table.
Please provide a scenario with detailed steps and extracts of your odesign if necessary
regards
Laurent
Re: Table column derivation and if else [message #1802218 is a reply to message #1802214] Mon, 04 February 2019 08:37 Go to previous message
yeah exactly
I declared for a class a derived value in the form:
if else if else endif endif;
that means three cases
in the table of sirius, It displays the correct values but hidden
I have to clic on each cell to see the value
(class test
attribute derivedValue: String
{ derivation: if(cond1) then value 1 else (if(cond2) then value 2 else value3) endif) endif;}
In sirius I just used derivedValue as the table is defined for the class test
[Updated on: Mon, 04 February 2019 08:38] by Moderator
Previous Topic:How to enable and disable Node from Palette
Next Topic:"diagram" variable is gone
Current Time: Thu Jul 24 21:54:30 EDT 2025
Powered by FUDForum. Page generated in 0.04355 seconds
