Home » Modeling » TMF (Xtext) » Parsing error:coudn't reslolve reference
Parsing error:coudn't reslolve reference [message #1802125] Fri, 01 February 2019 10:27 Go to next message
Hi all, I have validation error on the following string (see my grammar bellow)
class test {a: text; b: text; c : text; key a; index b; }
			operation createTest() {
			    create test(a = 'akey', b = 'btext', c = 'ctext');
java.lang.AssertionError: Expected no errors, but got :ERROR (org.eclipse.xtext.diagnostics.Diagnostic.Linking) 'Couldn't resolve reference to VariableDeclaration 'a'.' on CreateWhatPart, offset 99, length 1
ERROR (org.eclipse.xtext.diagnostics.Diagnostic.Linking) 'Couldn't resolve reference to VariableDeclaration 'b'.' on CreateWhatPart, offset 111, length 1
ERROR (org.eclipse.xtext.diagnostics.Diagnostic.Linking) 'Couldn't resolve reference to VariableDeclaration 'c'.' on CreateWhatPart, offset 124, length 1
But why as I really have the variable declarations?
My grammar is
grammar org.blockchain.rell.Rell with org.eclipse.xtext.common.Terminals
generate rell "http://www.blockchain.org/rell/Rell"
Model:
	entities+=(ClassDefinition )*
	operations+=(Operation )*;
ClassDefinition:
	'class' name=ID ('extends' superType=[ClassDefinition])? '{'
	attributeListField+=AttributeListField*
AttributeListField:
	mutable=Mutable? key=Key? index=Index? attributeList+=RelAttrubutesList ';';
Operation:
	"operation" name=ID "(" parameters=RelAttrubutesList? ")" "{" statements+=Statement* "}";
Statement:
	(relation=Relational | variable=OperationVariable|varInitiation=VarInitiation) ';';
VarInitiation:
	VariableDeclarationRef ('=' expression=Expression)?
OperationVariable:
	assessModificator=(Var | Val) variable=Variable;
Variable:
	name=VariableDeclaration (('=' expression=Expression)?);
Relational:
	 Create ;
Create:
	'create' (entity=[ClassDefinition]) '(' (createWhatPart+=CreateWhatPart (','
	createWhatPart+=CreateWhatPart)*)? ')';
CreateWhatPart:
	(varDeclRef=[VariableDeclaration|ValuableID] '=')?
	condition+=Expression;
TupleValue:
	'(' members+=TupleValueMember (',' tuplePart+=TupleValueMember)* ')';
ListCreation:
	'[' arguments=Arguments ']' ('.' LIST_METHOD listMethodArguments+=ArgumentsInBrackets)*;
MapCreation:
	'[' mapPart+=MapCreationPart (',' mapPart+=MapCreationPart)* ']' ('.' MAP_METHOD listMethodArguments+=ArgumentsInBrackets)*
NewListCreation:
	List {NewListCreation} (specification=ListSpecification?)
				listCreation=ListCreation|
				newListCreation=NewListCreation|
				newSetCreation=NewSetCreation
		')' ('.' LIST_METHOD arguments+=ArgumentsInBrackets)*;
NewMapCreation:
	Map {NewMapCreation	}specification=MapSpecification? '(' (creation=ListCreation?) ')' ('.' MAP_METHOD arguments+=Arguments )*;
NewSetCreation:
	Set {NewSetCreation} (specification=ListSpecification?)
			(listCreation=ListCreation|newListCreation=NewListCreation|newSetCreation=NewSetCreation)?
	('.' LIST_METHOD arguments+=ArgumentsInBrackets )*;
TupleValueMember:
	(name=ValuableID '=')? value=Expression;
ClassMemberDefinition:
	(classRef=ClassRef)? "." variableDeclarationRef=VariableDeclarationRef;
ClassRef:
	value=[TableNameWithAlias];
TableNameWithAlias:
	{ClassRefDecl} (name=ID COLON classDef=[ClassDefinition]) |
	{JustNameDecl} name=[ClassDefinition];
VariableDeclarationRef:
	decl=[VariableDeclaration|ValuableID];
Arguments:listPart+=Expression (','  listPart+=Expression)*;
ArgumentsInBrackets: '(' {ArgumentsInBrackets} arguments=Arguments? ')';
Expression:
	or=Or;
Or returns Expression:
	And ({Or.left=current} "or" right=And)*;
And returns Expression:
	Equality ({And.left=current} "and" right=Equality)*;
Equality returns Expression:
	Comparison ({Equality.left=current} op=(EQUALS | NOT_EQUALS|EQUALSS|NOT_EQUALSS)
	right=Comparison)*;
Comparison returns Expression:
	PlusOrMinus ({Comparison.left=current} op=(MORE_EQUAL | LESS_EQUAL | MORE | LESS)
	right=PlusOrMinus)*;
PlusOrMinus returns Expression:
	MulOrDiv (({Plus.left=current} PlusChar | {Minus.left=current} MinusChar)
	right=MulOrDiv)*;
MulOrDiv returns Expression:
	Primary ({MulOrDiv.left=current} op=(MulChar | DivChar)
	right=Primary)*;
Primary returns Expression:
	'(' Expression ')' |
	{Not} "not" expression=Primary |
	Atomic;
Atomic returns Expression:
	{IntConstant} value=IntWithMinus |
	{StringConstant} value=STRING |
	{ByteArrayConstant} value=BYTE_ARRAY_VALUE |
	{BoolConstant} value=('true' | 'false') |
	{MemberDefinition} value=ClassMemberDefinition |
	{CreateAtom} value=Create
	| {TupleRes} value=TupleValue
	| {ListCreation} value=ListCreation
	| {MapCreation} value=MapCreation
	| {NewLCreation} value=NewListCreation
	| {NewSCreation} value=NewSetCreation
	| {NewMCreation} value=NewMapCreation
	| {TheNull} value=NULL
	|{VariableRef} value=VariableDeclarationRef;
MapCreationPart:exprKey=Expression COLON exprValue=Expression;
RelAttrubutesList:
	value+=Variable (',' value+=Variable)*;
VariableDeclaration:
	name=ValuableID ((COLON type=TypeReference)?);
TupleVarDeclaration:
	(name=ValuableID COLON)? type=TypeReference;
TypeReference:
	primitive=PrimitiveType | entityType=ClassType | tuple=TupleType | list=ListType|set=SetType|map=MapType;
ListType:
	List ListSpecification;
SetType:
	Set ListSpecification;
MapType:
	Map MapSpecification;
ListSpecification:
	LESS listType=TypeReference (QuestionChar?) MORE;
MapSpecification:
	LESS keySpec=TypeReference (QuestionChar?) ',' valSpec=TypeReference (QuestionChar?) MORE;
TupleType:
	'(' varDecl+=TupleVarDeclaration (',' varDecl+=TupleVarDeclaration)* ')';
ClassType:
	type=[ClassDefinition];
PrimitiveType:
	Text | Tuid | Pubkey | Name | Timestamp | Integer | Json | ByteArray | Boolean;
ValuableID:
	PrimitiveType | ID;
AmpersandModificator:
	PlusChar | MulChar | QuestionChar;
IntWithMinus:MinusChar? INT;
Name:
	'name';
Pubkey:
	'pubkey';
Timestamp:
	'timestamp';
 Tuid:
	'tuid';
Boolean:
	'boolean';
Json:
	'json';
Integer:
	'integer';
Text:
	'text';
ByteArray:
	'byte_array';
List:
	'list';
Map:'map';
Set:
	'set';
Key:
	'key';
Index:
	'index';
Mutable:
	'mutable';
Var:
	'var';
Val:
	'val';
Ampersand:
QuestionChar:
PlusChar:
MinusChar:
MulChar:
DivChar:
LIST_METHOD:
	"add"|"addAll"|"contains"|"containsAll"|"removeAll"|"calculate"|"sub"|"size"|"str"|"remove"|"removeAt"|"clear"|"empty"
MAP_METHOD:"empty"|"size"|"contains"|"get"|"str"|"clear"|"put"|"putAll"|"remove"|"keys"|"values";
//terminal SET_METHOD:LIST_METHOD;
terminal EQUALS:
terminal EQUALSS:
terminal NOT_EQUALS:
terminal NOT_EQUALSS:
terminal MORE_EQUAL:
terminal LESS_EQUAL:
terminal MORE:
terminal LESS:
terminal COLON:
terminal NULL:
	'null';
terminal BYTE_ARRAY_CHAR:
	'0' | '1' | '2' | '3' | '4' | '5' | '6' | '7' | '8' | '9' | 'a' | 'b' | 'c' | 'd' | 'e' | 'f' | 'A' | 'B' | 'C' | 'D'
	| 'E' | 'F';
terminal BYTE_ARRAY_PAIR:
	BYTE_ARRAY_CHAR BYTE_ARRAY_CHAR;
terminal BYTE_ARRAY_VALUE:
	'x' (('\'' BYTE_ARRAY_PAIR* '\'') | ('"' BYTE_ARRAY_PAIR* '"'));
Re: Parsing error:coudn't reslolve reference [message #1802127 is a reply to message #1802125] Fri, 01 February 2019 10:41 Go to previous messageGo to next message
you should implement scoping to get this running
Re: Parsing error:coudn't reslolve reference [message #1802194 is a reply to message #1802127] Sun, 03 February 2019 13:23 Go to previous messageGo to next message
Ok, so without scoping it will not work?
Re: Parsing error:coudn't reslolve reference [message #1802197 is a reply to message #1802194] Sun, 03 February 2019 16:44 Go to previous message
Yes and no. You can implement name provider eg binding SimpleNameProvider and thus affect scoping indirectly but the result may not be as expected if you have many classes
Previous Topic:NoSuchMethodError when running Maven
Next Topic:Xtext & Xtend 2.17.0.M2 + MWE 2.10.M2
Current Time: Mon Jul 21 07:51:12 EDT 2025
Powered by FUDForum. Page generated in 0.03552 seconds
