Home » Modeling » Papyrus » New Papyrus Model Wizard Won't Close On Finish(Window won't close when clicking "finish" and no new model generated)
New Papyrus Model Wizard Won't Close On Finish [message #1781147] Thu, 01 February 2018 21:48 Go to next message
Hello Everyone,
I have encountered an odd issue very recently with Papyrus Neon. I have been able to generate new Papyrus models in the past several months, but recently cannot add new models. Each time I click the finish button when creating a new model, the window does not close and no new models are generated. I have tried it again through creating a new Papyrus project folder as well, but have received the same issue and only the project folder had been created, with no model in it. I previously reverted my updates to a time prior to the issue and have updated everything again, with the same results for both cases. I am wondering if I will have to reinstall Papyrus or if there is another solution?
Thank you,
Ioannis
Re: New Papyrus Model Wizard Won't Close On Finish [message #1801513 is a reply to message #1781147] Mon, 21 January 2019 08:18 Go to previous messageGo to next message
I have the same problem. where is the answer to your question????? no one reply you????? did you find a fix for that problem????????????????
[Updated on: Mon, 21 January 2019 08:20] by Moderator
Re: New Papyrus Model Wizard Won't Close On Finish [message #1801675 is a reply to message #1801513] Thu, 24 January 2019 11:13 Go to previous messageGo to next message
In order to analyse the problem it would be helpful to see an eventual error message (Show View -> Error log), seeing lots of question-marks is not. Other things to try out is to start with a fresh workspace and check whether the issue is reproducible there.
Besides of that, Papyrus on Eclipse Neon is no longer supported and you should (if possible) migrate to a newer version of Eclipse.
Re: New Papyrus Model Wizard Won't Close On Finish [message #1801748 is a reply to message #1801675] Fri, 25 January 2019 10:21 Go to previous messageGo to next message
I'm using Neon because I want to use DICE simulation tool and it works with neon only, so instead of being bothered from my question marks :( help me with this problem if you can.
Re: New Papyrus Model Wizard Won't Close On Finish [message #1801861 is a reply to message #1801748] Mon, 28 January 2019 10:21 Go to previous messageGo to next message
The problem is not reproducible in a standard neon installation (just tested with a fresh installation). I already suggested two things to try out. Another thing would be to make sure that only Papyrus itself and not the add-ons (extra-plugins) are installed. If you have an exception in the log, you should post it here - otherwise we can't help you.
Re: New Papyrus Model Wizard Won't Close On Finish [message #1801902 is a reply to message #1801861] Tue, 29 January 2019 08:10 Go to previous messageGo to next message
Thanks for your help.
I've tried to remove all the old installation and start fresh ones, This is the setup file I used "eclipse-jee-neon-3-win32-x86_64" but I got an error.
Attached the log file
  • Attachment: .log
    (Size: 6.05KB, Downloaded 77 times)
Re: New Papyrus Model Wizard Won't Close On Finish [message #1801906 is a reply to message #1801902] Tue, 29 January 2019 08:25 Go to previous messageGo to next message
I guess that neon packages only run with java 8 (but I'm don't really know)
Re: New Papyrus Model Wizard Won't Close On Finish [message #1801968 is a reply to message #1801906] Wed, 30 January 2019 01:09 Go to previous message
Missing javax.annotation is the delight of moving to Java 10. But clearly nothing to do with the start of this thread.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=539038
For now just add a require bundle for it in your test. But if you are really using Papyrus as you suggest then that is not an option for you. You need to produce a much more accurate repo.
Ed Willink
Previous Topic:How to get default values defined in profile in a model
Next Topic:Unable to Create Activity Diagram
Current Time: Mon Jul 21 09:23:31 EDT 2025
Powered by FUDForum. Page generated in 0.09681 seconds
