Home » Modeling » Epsilon » Feature not found.
Feature not found. [message #1801265] Tue, 15 January 2019 23:18 Go to next message
Hello
I am using standalone epsilon 1.4.
After modification of my model ( I have removed attribute from a class) during model loading got following exception. :
 org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Feature 'artifactExecutionString' not found.
to load modele I am using following code
	protected EmfModel createEmfModelByURI(String name, String model, String metamodel, boolean readOnLoad,
			boolean storeOnDisposal) throws EolModelLoadingException, URISyntaxException {
		EmfModel emfModel = new EmfModel();
		StringProperties properties = new StringProperties();
		properties.put(EmfModel.PROPERTY_NAME, name);
		properties.put(EmfModel.PROPERTY_METAMODEL_URI, metamodel);
		properties.put(EmfModel.PROPERTY_MODEL_URI, getFileURI(model).toString());
		properties.put(EmfModel.PROPERTY_READONLOAD, readOnLoad + "");
		properties.put(EmfModel.PROPERTY_STOREONDISPOSAL, storeOnDisposal + "");
		emfModel.load(properties, (IRelativePathResolver) null);
		return emfModel;
How to configure loader to ignore this error
Arseniy Isakov
[Updated on: Tue, 15 January 2019 23:25] by Moderator
Re: Feature not found. [message #1801291 is a reply to message #1801265] Wed, 16 January 2019 03:49 Go to previous message
Hi Arseniy,
XMLResource's OPTION_RECORD_UNKNOWN_FEATURE [1] loading option should help here. You'll need to use the EMF API to load your model (resource) with this option and then wrap it in an InMemoryEmfModel [2] before passing it to Epsilon.
Dimitris
[1] https://download.eclipse.org/modeling/emf/emf/javadoc/2.4.2/org/eclipse/emf/ecore/xmi/XMLResource.html
[2] https://www.eclipse.org/epsilon/doc/articles/in-memory-emf-model/
Previous Topic:[EGX] using parameters to set template string
Next Topic:Problems with allInstances()
Current Time: Mon Jul 21 05:51:53 EDT 2025
Powered by FUDForum. Page generated in 0.14609 seconds
