xtend-maven plugin does not work in 2.12.0 release [message #1801248] |
Tue, 15 January 2019 14:10  |
Hi All,
I am facing the issue that was reported in bug 432488 [0]. The plugin fails to compile Xtend files that have references to Java code. As an experiment, I tried converting the problematic Xtend code to Java in one of my projects, and it worked (only a subset of Xtend code was changed, not all). However, I cannot afford to do this as I have quite a bit of xtend code in my projects.
I did try adding dependencies to 'o.e.jdt.core', 'jdt.compiler.apt', 'jdt.compiler.tool', 'emf.codegen' as suggested by Sven and cdietrich in their comments here [1], but that didn't help.
Is there anything else that I can try? It is crucial for us to get past this issue. Any hints/pointers are highly appreciated.
PS: Please note that the builds started failing abruptly. Also, I would like to mention that we have configured the outputDirectory in the xtend-maven-plugin configuration to generated code in a different folder and not xtend-gen.
Eclipse: Oxygen Release (4.7.0), Build id: 20170620-1800
Xtext: 2.12.0
EMF: 2.13.0
[0] https://bugs.eclipse.org/bugs/show_bug.cgi?id=432488
[1] https://github.com/eclipse/xtext-xtend/issues/116
[2] https://github.com/crapo/sadlos2/commit/0f352f378e5dc3a3a27524521a6abbd5dac59787
PFA log for reference.
Tx in advance
Attachment: error.txt
(Size: 5.57KB, Downloaded 93 times)
FUDForum. Page generated in 0.04283 seconds
