Home » Modeling » TMF (Xtext) » How can i disable backtracking ?(I thought that using the code mentioned below in mwe2 code the backtracking will be disabled.)
How can i disable backtracking ? [message #1801151] Mon, 14 January 2019 11:52 Go to next message
But after debugging the InternalDSLParser class in antlr.internal package, i found that state.backtrack = 2
And i found this comment in RecognizerSharedState class :
/** If 0, no backtracking is going on. Safe to exec actions etc...
* If >0 then it's the level of backtracking.
public int backtracking = 0;
so backtrack is enabled, right?
how can i disable it?
mew2 file :
fragment = parser.antlr.ex.rt.AntlrGeneratorFragment {
options = {
backtrack = false
classSplitting = true
fieldsPerClass = "500"
ignoreCase = true
//kAsString="1"
memoize=true
fragment = org.eclipse.xtext.generator.parser.antlr.ex.ca.ContentAssistParserGeneratorFragment {
options ={
backtrack = false
memoize=true
ignoreCase = true
//kAsString="5"
Re: How can i disable backtracking ? [message #1801153 is a reply to message #1801151] Mon, 14 January 2019 11:55 Go to previous messageGo to next message
0 = no backtracking
Re: How can i disable backtracking ? [message #1801158 is a reply to message #1801153] Mon, 14 January 2019 12:17 Go to previous messageGo to next message
by debugging in InternalDSLParser.java i found that state.backtracking = 2 not zero
so i think there is something i am missing in disabling the backtracking
I know that zero means no backtracking but the value is not equal to zero!!
public final EObject entryRuleprimary() throws RecognitionException {
EObject current = null;
int entryRuleprimary_StartIndex = input.index();
EObject iv_ruleprimary = null;
try {
if ( state.backtracking>0 && alreadyParsedRule(input, 409) ) { return current; }
[Updated on: Mon, 14 January 2019 12:18] by Moderator
Re: How can i disable backtracking ? [message #1801160 is a reply to message #1801158] Mon, 14 January 2019 12:33 Go to previous messageGo to next message
Maybe there is something in your grammar
Re: How can i disable backtracking ? [message #1801162 is a reply to message #1801160] Mon, 14 January 2019 13:11 Go to previous messageGo to next message
that what i am asking about, is there is something known in xtext that will enable the backtracking and i wrote it by mistake given that i disabled it in mwe2?
are you sure that if "state.backtracing" variable in InternalDSLParser class equals 2 means that backtracking is enabled?
Re: How can i disable backtracking ? [message #1801164 is a reply to message #1801162] Mon, 14 January 2019 13:15 Go to previous messageGo to next message
yes this means backtracking. but i dont think its related to the global backtracking option for ambiguities.
is there any specific reason you ask?
Re: How can i disable backtracking ? [message #1801170 is a reply to message #1801164] Mon, 14 January 2019 15:02 Go to previous messageGo to next message
Yes i am suffering from performance problem, and i am really frustrated because i think i am disabling backtracking while its seems its enabled.
the comment in the code is clear,since backtracking variable is not equal zero so it means i am enabling backtracking.
Do you know how to disable it?
Re: How can i disable backtracking ? [message #1801174 is a reply to message #1801170] Mon, 14 January 2019 15:22 Go to previous messageGo to next message
can you debug where it is set to != 0
Re: How can i disable backtracking ? [message #1801175 is a reply to message #1801174] Mon, 14 January 2019 15:26 Go to previous messageGo to next message
it was my next step, but i found that it's used widely in the code so i was looking for hints about the locations where its value got changed, if you have information about that
Re: How can i disable backtracking ? [message #1801176 is a reply to message #1801175] Mon, 14 January 2019 15:32 Go to previous messageGo to next message
you know you can set a breakpoint on a field and configure it to match modifications
Re: How can i disable backtracking ? [message #1801177 is a reply to message #1801176] Mon, 14 January 2019 15:39 Go to previous messageGo to next message
Thanks alot :)
I will check that and return back to this thread with the results
[Updated on: Mon, 14 January 2019 15:39] by Moderator
Re: How can i disable backtracking ? [message #1801224 is a reply to message #1801177] Tue, 15 January 2019 10:46 Go to previous messageGo to next message
I found the modification in state.baacktracking happens in functions with this name
public final boolean synpred27_InternalDSLParser() {
state.backtracking++;
int start = input.mark();
try {
synpred27_InternalDSLParser_fragment(); // can never throw exception
} catch (RecognitionException re) {
System.err.println("impossible: "+re);
boolean success = !state.failed;
input.rewind(start);
state.backtracking--;
state.failed=false;
return success;
also it happens in many functions start with the same prefix "synpred".
Do you know what does it means?
[Updated on: Tue, 15 January 2019 10:50] by Moderator
Re: How can i disable backtracking ? [message #1801230 is a reply to message #1801224] Tue, 15 January 2019 11:06 Go to previous messageGo to next message
you you have a predicate in your grammar
=> or ->
Re: How can i disable backtracking ? [message #1801231 is a reply to message #1801230] Tue, 15 January 2019 11:11 Go to previous messageGo to next message
yes, does it enable backtracking?
and if it does, what can i do to avoid that?
Re: How can i disable backtracking ? [message #1801239 is a reply to message #1801231] Tue, 15 January 2019 12:12 Go to previous messageGo to next message
semantic predicates do local backtracking and you cannot avoid it unless you dont use the predicate
Re: How can i disable backtracking ? [message #1861604 is a reply to message #1801239] Sat, 21 October 2023 17:18 Go to previous message
I don't know how this tale turned out in the end, but I just banged my head against a very similar problem where my backtracking setting had no effect.
After hours of debugging I realized that further down in my MWE2 configuration there was another parserGenerator = {debugGrammar=true} entry that overwrote the parser generator configuration that enabled the backtracking.
So keep in mind that there is no checking for duplicate entries, and that entries further down apparently overwrite earlier entries (so there is no merging of configurations either; this is as of Xtext 2.30/MWE2 2.14, not sure if this was fixed in the meantime).
Previous Topic:Large if-then-else results in stack overflow in ANTLR parser
Next Topic: Xtext 2.33.0.M2 is out
Current Time: Mon Oct 27 23:40:06 EDT 2025
Powered by FUDForum. Page generated in 0.06173 seconds
