Cloud connections for industrial devices [message #1801139] |
Mon, 14 January 2019 09:50  |
There are several connections that are provided as cloud connections via Camel (REST, IEC 60870-5-104, OPC DA, etc.) and are not available as drivers but only to be used under a publication/subscription paradigm.
However, there are some approaches in which those protocols are used to communicate with industrial devices and the structure of Drivers/Assets is much more useful.
My questions are:
- ¿Is the creation of these drivers in the current roadmap of the project?
- If it isn't, does it make sense to configure the industrial devices as cloud connections as a definitive solution or should the driver be made?
- If cloud connection is the definitive solution for this use case, will it be considered a more asset/variable-oriented approach usage of the Camel broker for these situations?
FUDForum. Page generated in 0.44849 seconds
