Preview Tab Missing In Designer [message #1801046] |
Fri, 11 January 2019 11:14  |
Hello all,
I downloaded the latest (currently 4.7.0) package of the Eclipse BIRT Designer, installed it and followed the tutorial to run the default sample (Customers) report. I did everything correctly without any problems but I am actually missing the Preview Tab. Additionally, I noticed I have an entry in the Error Log View that the following path is invalid:
...\eclipse-workspace\birt\.metadata\.plugins\org.eclipse.birt.report.data.oda.jdbc.dbprofile.sampledb\db\META-INF\MANIFEST.MF
I manually created the path, and created an empty MANIFEST.MF file. Then I restarted Eclipse. But, now I have the following in the Error Log View:
!SESSION 2019-01-11 15:55:45.308 -----------------------------------------------
eclipse.buildId=4.10.0.I20181206-0815
java.version=1.8.0_191
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.reporting.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.reporting.product
!ENTRY org.eclipse.jface.text 2 0 2019-01-11 15:56:22.202
!MESSAGE Duplicate template id: 'org.eclipse.wst.xslt.templates.xpath.boolean'
!ENTRY org.eclipse.oomph.setup.core 2 0 2019-01-11 15:56:44.708
!MESSAGE C:\Users\A00006075\.eclipse\org.eclipse.oomph.setup\cache\http___www.eclipse.org_setups_setups.zip (The system cannot find the path specified)
!STACK 0
java.io.FileNotFoundException: C:\Users\A00006075\.eclipse\org.eclipse.oomph.setup\cache\http___www.eclipse.org_setups_setups.zip (The system cannot find the path specified)
at java.io.FileInputStream.open0(Native Method)
at java.io.FileInputStream.open(FileInputStream.java:195)
at java.io.FileInputStream.<init>(FileInputStream.java:138)
at org.eclipse.emf.ecore.resource.impl.FileURIHandlerImpl.createInputStream(FileURIHandlerImpl.java:99)
at org.eclipse.oomph.setup.internal.core.util.SetupCoreUtil$2.createInputStream(SetupCoreUtil.java:386)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:360)
at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl$InputStreamConnectionHandler.handleCache(ECFURIHandlerImpl.java:1809)
at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl$InputStreamConnectionHandler.handleCache(ECFURIHandlerImpl.java:1)
at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl$ConnectionHandler.process(ECFURIHandlerImpl.java:1744)
at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl.createInputStream(ECFURIHandlerImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1314)
at org.eclipse.oomph.setup.internal.core.util.SetupCoreUtil.handleArchiveRedirection(SetupCoreUtil.java:546)
at org.eclipse.oomph.setup.internal.core.util.SetupCoreUtil.configureResourceSet(SetupCoreUtil.java:348)
at org.eclipse.oomph.setup.internal.core.util.SetupCoreUtil.configureResourceSet(SetupCoreUtil.java:174)
at org.eclipse.oomph.setup.internal.core.util.SetupCoreUtil.createResourceSet(SetupCoreUtil.java:168)
at org.eclipse.oomph.setup.ui.recorder.RecorderManager.<clinit>(RecorderManager.java:120)
at org.eclipse.oomph.setup.ui.SetupUIPlugin.performStartup(SetupUIPlugin.java:204)
at org.eclipse.oomph.setup.ui.EarlyStartup.earlyStartup(EarlyStartup.java:22)
at org.eclipse.oomph.internal.ui.EarlyStart.run(EarlyStart.java:112)
at org.eclipse.oomph.internal.ui.EarlyStart$1.run(EarlyStart.java:91)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
!ENTRY org.eclipse.oomph.setup.core 2 0 2019-01-11 15:56:44.793
!MESSAGE The Eclipse Git-hosted URI 'http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/org.eclipse.setup' is blocked for direct access.
Please open a Bugzilla to add it to an official Oomph catalog.
For initial testing, use the file system local version of the resource.
Alternatively, run the setup archiver application as follows:
C:\Development\_BIRT_PROJECT\eclipse\eclipsec.exe -application org.eclipse.oomph.setup.core.SetupArchiver -consoleLog -noSplash -uris http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/org.eclipse.setup
!ENTRY org.eclipse.oomph.base 2 0 2019-01-11 15:56:44.795
!MESSAGE java.io.IOException: Eclipse Git access blocked: http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/org.eclipse.setup
!STACK 0
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: java.io.IOException: Eclipse Git access blocked: http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/org.eclipse.setup
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$ResourceLocator.demandLoadHelper(ResourceSetImpl.java:804)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$MappedResourceLocator.getResource(ResourceSetImpl.java:1204)
at org.eclipse.oomph.setup.internal.core.util.SetupCoreUtil$1.getResource(SetupCoreUtil.java:336)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:352)
at org.eclipse.oomph.base.util.BaseUtil.loadResourceSafely(BaseUtil.java:88)
at org.eclipse.oomph.setup.internal.core.SetupContext.getInstallation(SetupContext.java:670)
at org.eclipse.oomph.setup.internal.core.SetupContext.create(SetupContext.java:281)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.createForIDE(SetupTaskPerformer.java:3874)
at org.eclipse.oomph.setup.ui.SetupUIPlugin.performStartup(SetupUIPlugin.java:638)
at org.eclipse.oomph.setup.ui.SetupUIPlugin.access$5(SetupUIPlugin.java:415)
at org.eclipse.oomph.setup.ui.SetupUIPlugin$1$1.run(SetupUIPlugin.java:252)
Caused by: java.io.IOException: Eclipse Git access blocked: http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/org.eclipse.setup
at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl$InputStreamConnectionHandler.handleEclipseGit(ECFURIHandlerImpl.java:1821)
at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl$InputStreamConnectionHandler.handleEclipseGit(ECFURIHandlerImpl.java:1)
at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl$ConnectionHandler.process(ECFURIHandlerImpl.java:1473)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 12 more
!ENTRY org.eclipse.core.net 1 0 2019-01-11 16:03:14.221
!MESSAGE System property http.proxyHost is set to XXXXXXXXXXX but should not be set.
Is the problem actually, that I am behind a proxy? I managed to connect to the sample Customers database and ran the SQL query with test results successfully.
Any help would be appreciated! Thanks!
FUDForum. Page generated in 0.24654 seconds
