Home » Modeling » Papyrus » How to customize SysML transitions?(How to customize SysML transitions?)
How to customize SysML transitions? [message #1801040] Fri, 11 January 2019 09:33 Go to next message
before asking my question, i would say thanks for providing Papyrus. It's a very useful tool for me to model complex systems and seems to be a serious alternative to some commercial tools.
I'm mainly using Papyrus to create SysML-models and -diagrams. During creation of a Block Definition Diagram (bdd) with composite association i'm unsatisfied with the representation with a lot of labels. These are making my diagram very confusing. I'm wondering if there is a way to customize the appearance in order to make the labels invisible so than only the line is visible? I've read about css stylesheets but i don't understand how to write and apply them.
this way the transition is currently represented:
index.php/fa/34652/0/
and this way it should be for me:
index.php/fa/34653/0/
Thanks for your help.
akka
  • Attachment: bdd.png
    (Size: 14.13KB, Downloaded 436 times)
  • Attachment: bdd2.png
    (Size: 13.67KB, Downloaded 373 times)
Re: How to customize SysML transitions? [message #1801181 is a reply to message #1801040] Mon, 14 January 2019 16:47 Go to previous messageGo to next message
Check this: https://wiki.eclipse.org/MDT/Papyrus/UserGuide/CSS
Re: How to customize SysML transitions? [message #1801191 is a reply to message #1801181] Tue, 15 January 2019 01:20 Go to previous messageGo to next message
If you want such thing to be applied as default setting, CSS is the way to go. If you want it just for a single or some occurrences, you can just click the respective label(s) to select them and hit "delete" on your Keyboard. That will remove the labels from your diagram.
Re: How to customize SysML transitions? [message #1801195 is a reply to message #1801191] Tue, 15 January 2019 02:12 Go to previous messageGo to next message
thank you for your quick answering.
@Benedikt Bauder
i've tried your suggestion and it works if i use "delete from diagram". if i use "delete selected item" the whole transition will be deleted.
@Adriano Carvalho
if i find some more time, i will look into the usage of css. it seems to be a little more complex.
I've found still another way to hide some labels and elements from diagrams by using the filter functionality. right-click on transition->filters->Show/Hide Labels. it works very good for me because i can easily select which labels to show and which to hide.
Re: How to customize SysML transitions? [message #1801197 is a reply to message #1801195] Tue, 15 January 2019 03:06 Go to previous messageGo to next message
For the CSS, you can create for example a "style.css" file in the Eclipse project. For your case, add the following css to the file
Association > Label {
	visible : false;
Then apply this css file to a diagram by selecting a diagram, select style, "+" button in "diagram style sheets" field. You can also apply to it to the full model.
Yoann.
Re: How to customize SysML transitions? [message #1801223 is a reply to message #1801040] Tue, 15 January 2019 10:36 Go to previous message
You can also
1. click on the association on the diagram to select it
2. select "Filters" --> "Hide All Labels" in the context menu
to change the appearance.
But this only alters the appearance of the individual association.
/Carsten
Previous Topic:SysML Substitution relation - not visible in diagrams and palette
Next Topic:How to duplicate model
Current Time: Thu Jul 17 19:14:53 EDT 2025
Powered by FUDForum. Page generated in 0.04811 seconds
