Home » Eclipse Projects » Oomph » Eclipse Installer exe creation code
Eclipse Installer exe creation code [message #1800656] Fri, 04 January 2019 09:42 Go to next message
Hi guys,
Where is the code which creates the self extracting installer files (exe and dmg) , cannot find it anywhere.
Thanks!
Re: Eclipse Installer exe creation code [message #1800771 is a reply to message #1800656] Mon, 07 January 2019 23:17 Go to previous message
For Windows, the self-extracting installer is created like this:
https://wiki.eclipse.org/Eclipse_Oomph_Authoring#How_to_extract_the_constituent_parts_that_comprise_the_Windows_self-extracting_installer_executable
Creating a signed dmg is a service provided by the Eclipse Foundation that we can invoke like this:
curl -o eclipse-inst-mac64.dmg --write-out '%{http_code}\n' -F sign=true -F source=@eclipse-inst-mac64.tar.gz http://build.eclipse.org:31338/dmg-packager
You can find Oomph's build here:
https://ci.eclipse.org/oomph/
This build repackages the results of an existing build to produce so-called filtered installers:
The build steps should give you more information:
https://ci.eclipse.org/oomph/job/build-filtered-installer/configure
Some of the shell scripts used are only visible on build.eclipse.org, so you can only see them if you have access rights.
Previous Topic:Oomph installer failed installing Papyrus-RT Developer Environment
Next Topic:Avoid Download Failure
Current Time: Mon Jul 21 11:33:23 EDT 2025
Powered by FUDForum. Page generated in 0.05427 seconds
