Indexing problem after debugging [message #1800609] |
Thu, 03 January 2019 09:32  |
I am working on a simple c++ project, (mnist project that uses libtorch library) using a version of eclipse installed in Ubuntu 18.04:
Eclipse IDE for C/C++ Developers
Version: 2018-09 (4.9.0)
Build id: 20180917-1800
I imported a CMake project, generated using cmake-gui ide. Initially the indexing was working fine, and I could build and run my project.
Once I entered the debug mode, almost all indexing are broken. I tried index->rebuild, but it did not help. Indeed, I noticed that, during the indexer rebuild, some progress bar was shown, and now, when I execute the index->rebuild, the progress bar is not shown. I did not changed any project/workspace/index settings, at least not on purpose anyway. I searched about this and the only solution that I found is suggests to delete the project and create it again, which does not make sense to do every time that this problem happens. I need to add that I still can build and run the project, though indexing is not working. I also looked through ~/eclipse-workspace/.metadata/.log (see the attached file), but nothing helpful.
I appreciate any help or comment.
Re: Indexing problem after debugging [message #1844146 is a reply to message #1800743] |
Thu, 02 September 2021 22:13  |
I get the following error
Indexed 'uart_echo' (5 sources, 2 headers) in 0.046 sec: 46 declarations; 620 references; 5 unresolved inclusions; 0 syntax errors; 14 unresolved names (2.1%)
Again, no errors before I started JTAG debugging.
Could it be something with the way include files paths are specified?
FUDForum. Page generated in 0.20796 seconds
